The custom list is just that, a generic list that you can put anything you want in it. Before it was added, all the lists in RR were each tied to a specific feature and couldn't be re purposed for anything custom. And because its a custom list, means that you have to write all the code to do whatever is the list is supposed to do. Like in your example, when you have a item in your custom list that you would like to "browse" into, you would need your own browse cmd that would save out the current list to a temp location to be able to reload if/when you need to go back, then you create and load another list that would contain the contents of the item that was browsed into. RR doesn't know what you want it do with your list or its items, that's all up to you.
Custom lists lines begin with either LST or IMG only, and the top line being the item you want selected when RR loads the CL with your text file.
** Also, please refrain from asking the same question in two different threads, it is highly frowned upon in this forum...
LinkBack URL
About LinkBacks
