Results 1 to 4 of 4
Thread: Problem with Directed HD Radio and RR November 2011
    Dec 2010
    I have an odd issue.
    I'm using Windows 7 x86
    hdradio is connected to a real serial port
    Running the PCR software the radios works fine. Actually works fine with Centrafuse as well but I dont want to run that.
    Load up RR and the radio works fine. I have stored 11 presets all is well and good. Close RR and reopen and the presets are all gone but the Number 1. with no ID. None of the buttons do anything.
    Now here is the weird part. If I open config and just hit the Save and Restart RR then I have radio every time. I haven't used older versions so I dont know if they worked.
    I have uninstalled the program and deleted the RideRunner folder out of Program Files and My Documents. I even deleted it out of the registry and then reinstalled with the same problem.
    Any ideas?
    Thanks,
    PCPackrat
    MySQL Error
    Oct 2004
    in RR.ini edit
    ResumeMusic=1
    or set it in rrconfig... under music->modes->Resume Mode: Start/Hibernate
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Dec 2010
    so what does that do? it did fix the problem and for that I thank you.
    -PCP
    MySQL Error
    Oct 2004
    it tells rr, to play that source when you start rr...
    there is actually a bug when its 0 (fixed in next release)
    but in my opinion, it should never be 0 anyway
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Directed HD Radio Causing static in factory radio
    By bchiang in forum Input Devices
    Last Post: 09-28-2011, 07:10 PM
  2. I am lost with Directed HD Radio
    By Miguel_R1 in forum Road Runner
    Last Post: 02-18-2010, 10:19 PM
  3. Directed HD Radio Tuning
    By mattstevenson in forum Road Runner
    Last Post: 05-05-2009, 04:24 PM
  4. Directed Electronics HD Radio
    By DaveDog in forum General Hardware Discussion
    Last Post: 05-23-2007, 10:06 AM
