Results 1 to 9 of 9
Thread: RR 12-17-2011 Release
    MySQL Error
    Oct 2004
    Oh man where has the year gone! (didnt i just ask this)
    Download Here: http://www.nisuautomotive.com
    i didnt want to make every 1st time user of RR, have the issue of no Cache Folder...
    so here is a mid month release
    THANKS TO RIKI for spending a few minutes with me on skype...
    Notes:
    FLASH 11.1.102.55 has been released by adobe, and its is compatable with RR's transparency.
    HISTORY:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    12/17/2011
    # fix for check for Cache folder existence, would fail to create on FRESH installs
    12/16/2011
    # Tweaks to Video load, added checks for missing or empty "videos.m3u8".
    + ONEvents; "ONLBLPRESS", "ONINDPRESS", "ONSLDPRESS".
    + User Var; "RRScreenObjectID" contains the resulting Screen Object (button, label, indicator, slider) ID.
      when OnEvent "ONBTNPRESS", "ONLBLPRESS", "ONINDPRESS", "ONSLDPRESS" is fired.
    12/14/2011
    + New option "OPT_NOFOCUS" for Screen Object Definition "AX", this will cause the embedded window
      to keep its focus even when RR skin is clicked on (no flashing of embedded window)
      ex. AX,0,0,800,450,"OPT_NOFOCUS"
          this will embedd the window at (0,0) 800 wide, 450 tall, with the NO_FOCUS option.
    + New option "OPT_BACKCOLOR#RRGGBB" for Screen Object Definition "AX", this will cause the embedded window
      background color to be set. (in most cases this is not needed)
      ex. AX,0,0,800,450,"OPT_BACKCOLOR#000000"
          this will embedd the window at (0,0) 800 wide, 450 tall, with the Black Background
    + Screen Object Definition; AX, eXtended Application embed area define
       ex. AX,0,0,800,450, "optionlist"
       options;
          OPT_NOTOUCH - do not remove window boarders
    	  OPT_NOFOCUS - do not lose focus on application when RR screen elements are clicked.
    	  OPT_BACKCOLOR#RRGGBB - set background window color to RRGGBB.
    	  OPT_PARENT  - embedded window parent window set to RR. (advanced)
    	  OPT_ATTACHINPUT - sets the embedded windows input proccessing to RR's. (advanced)
    	ex. AX,0,0,800,450,"OPT_NOTOUCH,OPT_NOFOCUS"
    12/10/2011
    # tweaks to TagToTitle, for when tag data is missing
    + On error screen, pressing any key will exit the error screen
    12/9/2011
    # ML if tags data is missing, resulted in blank line (aka .cda files)
    # In All VB6 based Radio Modules, fixed bad reference to textbox object on numosk/osk skin
    12/5/2011
    # Custom source properly deactivated on suspend
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2008
    Ireland
    Code:
    Related to the above, when RR starts and loads the plugins, if the plugin trows an error and uses the RR error screen to show a message then RR hangs/stops loading.
    We need a way to dismiss the error screen by click or keyboard.
    At the moment an error like that could render a setup useless if you have RR auto-start with windows. The only way to get back to the desktop in a typical setup would be to force-restart windows.
    Edit:
    Also just remembered, regarding Label Effects, I like how you can apply a shadow, but are there any other opptions? Would like an 'Alpha' option to set transparency to labels.
    Thanks.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Same is the case if XM throws an error. Error screen displays behind the RR Loading splash and you have to Alt-Ctrl-Delete to close RR
    Quote Originally Posted by dan32500 View Post
    Code:
    Edit:
    Thanks.
    Live mp3Car Facebook Chat
    MySQL Error
    Oct 2004
    no other effects for labels...
    as for a plugin using the error screen when a splash is up...
    i guess its one of those things annoying things about a window
    that is set to be on top... my guess.. the splash goes i away at some point
    i dont know, i never seen this happen...
    sonic,
    and when my disconnected radio, throws an error, its after the splash
    i would suspect xm too..
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Woodbridge, VA
    Blog Entries
    41
    Quote Originally Posted by mitchjs View Post
    sonic,
    can you close the error screen and continue loading RR?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Code:
    12/14/2011
    How does this affect keyboard commands?
    ie for skins which are built around using left and right arrows (or simulated using those rotating devices) to move between the different buttons.
    MySQL Error
    Oct 2004
    i dont know... and im not sure what your refferring to, other than quoting my history...
    besides no "keys should be simulated" to move between buttons with out directly sending them to RR
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Sorry top bit should have been chopped as well, it the opt-nofocus bit.
    Well yes the simulated keys are sent to RR.
    But I am on about normal keystrokes, will they still go to RR or to the embedded app which I read from the option (if used in the skin) will take focus.
    MySQL Error
    Oct 2004
    the go to the embedded app, the embedded app has focus
    so you can type a letter in note pad and crash your car all at the same time
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 07-01-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 10-06-2011, 07:32 PM
  2. RR 08-01-2011 Release
    Last Post: 08-28-2011, 02:41 PM
  3. RR 06-01-2011 Release - its already too HOT
    Last Post: 06-26-2011, 12:30 PM
  4. Replies: 21
    Last Post: 04-01-2011, 08:59 AM
  5. RR 02-01-2011 Release
    Last Post: 02-22-2011, 04:46 PM
