Results 1 to 5 of 5
Thread: Variables are not updated in the actual screen
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Unhappy Variables are not updated in the actual screen
    I have an issue with the variables (labels).
    When i change the variable's value the label is not immediately updated into the actual screen .
    If i want to see the good value , i must to change to screen and return after that to my first screen .
    My code is like that:
    Code:
    L,18,504,291,25,255,255,255,14,"Arial:BI","=$GOADDRESS$","LEFT",,"DS=3,3,0,0,0"
    How can i change that please ?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Use the RELOADSCREEN Command
    "RELOADSCREEN" - Reloads current .skin file (screen)
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Hmmm I have never had to use any type of reloading the screen... I have used Variables with AutoIt scripts in the past. Soon as the script updates the variable, the label updates instantly in the skin..... I will test that when I get back home after work, just to see.
    My Fiero Build Thread
    May 2008
    Bordeaux, France
    No , the RELOADSCREEN don't solve my issue !
    That is curious is that a variable is not update , but a label defined into my plugin ,yes , my solution would be , i think to define a label with this variable ! No ?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Ok, I just confirmed... When I put a variable into the skin, and use the skin tool to set the variable, it changes instantly in RR.
    (This is using the December 2011 RideRunner)
    This is the variable line in the skin:
    L,210,200,276,20,255,255,255,24,"Arial","=$TestVar $",,
    This is the line I put in the skin tool to set the variable:
    setvar;testvar;This test is working
    Here are a couple screen shots of the variable being set:
  1. 10" actual screen dimensions
    By naiku in forum LCD/Display
    Last Post: 09-16-2009, 09:10 AM
  2. Newbie- Actual amp power
    By rangerrick in forum Car Audio
    Last Post: 07-30-2007, 11:10 PM
  3. Actual work-in-progress
    By netsuo in forum NeoCar Media Center
    Last Post: 04-16-2005, 01:19 PM
  4. Need dimensions of ACTUAL screen of lilliput
    By ummagawd in forum LCD/Display
    Last Post: 10-28-2004, 10:23 PM
  5. Replies: 4
    Last Post: 10-25-2003, 05:29 AM
