Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: RR - Chinese Unicode issue - SOLVED
  1. #21
    MySQL Error
    Oct 2004
    you should never do id3taging while driving....
    just what do you want TAGTITLE to be when you have no id3tag?
    you can always use titlesafter= and that will work...
    filenames have to be then with the char you want to split at...
    no change has been done to how tags are generated....
    example file name is: Dream Theater - As I am.wav
    when setting titlesafter=-
    TAGTITLE will be " As I am"
    simple...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    Aug 2006
    Hong Kong
    I use Traditional Chinese, I have no problem in all ID tag when changed to Unicode, but sometime the character changed to ?? in each chinese word in playlist, I need to reload the playlist again.
  3. #23
    MySQL Error
    Oct 2004
    ? is usually there if a font subtituion cant be made... remember with unicode, your font has to support it...
    and most dont, so windows will subititute, also if some other external application is working with the playlist
    and its in vb6 it may not be unicode.... and corrupt the data
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #24
    May 2005
    Quote Originally Posted by WolfSkin View Post
    Now that you mention, yes I do experience this problem (I am using Simplified Chinese) occasionally. After selecting the songs I wanna hear, it shows up ok as expected.
    Shutdown the PC (ie, turn off the car) and the next time RR boots up, the playlist shows ??.
    Not sure if it's a problem cause by Winamp or RR. And you are right, reloading the playlist fix the problem.
  5. #25
    MySQL Error
    Oct 2004
    winamp hu, my suggestion, is not to have winamp fetch tags!!!!
    let RR do it!!
    go with this setting, and test.... then if u still have the problem
    test with carwings, and come up with a method to reproduce
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #26
    MySQL Error
    Oct 2004
    remeber when you exit rr, rrpl is saved out, along with tagcache, when rr restarts
    rrpl is reloaded, and tagcache is used for tags
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Long standing sleep/wake issue solved?
    By iamgnat in forum MacCar
    Last Post: 10-28-2008, 08:18 PM
  2. Replies: 0
    Last Post: 11-04-2005, 05:20 AM
  3. Replies: 4
    Last Post: 04-19-2005, 08:08 PM
  4. cranking issue solved?
    By Dracos in forum Power Supplies
    Last Post: 10-24-2004, 08:27 AM
  5. Laptop remote on/off issue -- SOLVED: s2000 carputer
    By skybolt in forum General Hardware Discussion
    Last Post: 09-20-2004, 10:52 PM
