Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: windows8+riderunner
  1. #11
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Nothing to do with RR but I've been testing a New CAR-PC running Win-8 for a few weeks on the bench. I've noted that Win8 delays the launch (or low prioritises) apps listed in auto start. (Task Manager - Start-up) I found that making a logon task to launch my FE is a lot faster. I've encounter no unusual problems compared to Win7 with any app with respect to admin rights.
    To clarify my setup, my desktop is useable within 14 seconds from power on "cold boot" - Click my FE icon at that point and it loads instantly (1 second to FE welcome message). Make the FE app auto-run and its delayed up to 15 seconds after desktop appears. Start it as a task and it loads in 3 to 4 seconds after desktop (or Metro) appears.
    I still feel that in Win8, non system apps load at a much lower priority (longer app initialisation and not just a delayed start up.) Anyone dug deeper into this?
    Palm sized ainol MiniPC, 8" Transreflective PRO, Win10, Reverse camera, Dual 10HZ GPS RX's for Speed Display & Sat Nav, FM-DAB & Phone Modules, iDrive interface. T-Screen HVAC control, custom microcontrollers, microcode and FE.
  2. #12
    Sep 2012
    Germany - Munich
    what is FE?
    i don't want to see the desktop or metroscreen. and don't want skip them.
    if i config the userdefined start-app to firefox, win8 starts up and just run firefox.
    but RR not.
  3. #13
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by harryberlin View Post
    what is FE?
    but RR not.
    FE = Front End
    I'll try setting my startup app to Firefox and see if that works, RR definitely does not.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  4. #14
    Sep 2012
    Germany - Munich
    it also work with xbmc: http://myxbmc.bplaced.net/blog/?p=522
  5. #15
    Mar 2004
    Greenacres, WA
    Firefox will start, but the system still boots to metro, then I have to click desktop pane to see Firefox, no sign of RR
    a lot of the tricks for application startup listed on the web will not work for Win8 home edition
    So I'm thinking of going to Win8 professional, but I may not want to continue down the pioneer path and go back to Win 7 instead
  6. #16
    Sep 2012
    Germany - Munich
    the problem is RideRunner need admin rights. FireFox or XBMC don't need it to start.
  7. #17
    May 2012
    For RR in Admin mode you need to disable UAC, do so by going into the registry - "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\Cur rentVersion\policies\system" look for "EnableLUA" and set it to "0"
    And for the Metro issue, I use Classic Shell to remove the pesky Metro, no more Metro unless you want it
  8. #18
    Mar 2004
    Greenacres, WA
    ok, using task scheduler, I was able to get RR to run on start by configuring the task to run RR as admin, however, when the PC boots up, it still goes to the metro interface, and you cannot see that RR is running until you click on the desktop pane.
    I'm really starting to think that Win8 will not be a viable option for RR use.
  9. #19
    FLAC Mickz's Avatar
    Sep 2009
    Australia
    Using Task scheduler to launch an App with "Run at Highest privileges" selected will also override UAC. There is a simple script to make W8 switch to the desktop at start. There is also a small file around that kills off Metro for each session.
    I use the Metro interface as a Touch screen Start menu and program launcher so I've kept it in my new Car PC. You can also make another task and type --- explorer --- in the application to start text box. It should switch to the desktop at start up.
  10. #20
    Jun 2010
    Syd, Australia
    win8.1 now supports going straight to Desktop after login rather than metro:
    * on taskbar>right click>properties
    * on navigation tab, tick "When I sign in or close all apps on a screen, go to the desktop instead of Start"
    * Apply>Ok
  1. TicTacToe for RideRunner
    By pierrotm777 in forum RR Plugins
    Last Post: 08-31-2010, 01:09 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. Not able to exit RideRunner...??
    By arb004 in forum Road Runner
    Last Post: 01-04-2010, 11:44 AM
  4. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  5. riderunner phone help
    By danchappers in forum Road Runner
    Last Post: 05-17-2009, 03:28 AM
