Results 1 to 10 of 20
Thread: windows8+riderunner
    Jun 2007
    windows8+riderunner
    boot faster
    http://www.youtube.com/watch?v=MWXyXTW8VPw
    system
    -windows8 developer preview
    -asus e350 m1-m pro
    -ram 4 gb/1066
    -sumsung n/b 5400 rpm
    Feb 2011
    MD
    I can do that with Win7 with a SATA3 SSD. That is impressive off a 5400rpm. Is your bios that fast or did you start the video a few seconds after pressing the power button.
    Jan 2012
    My desktop BIOS is faster then that, most modern motherboards have an option for quick boot or something similar. Windows 8 definitely boots faster though which is certainly welcomed!
    Jan 2012
    Indianapolis, Indiana
    Are you running the win 8 as installed or have you tweaked the startup and taken out the stuff that is not needed? I have not tried win 8 yet, I have a tablet that I am wanting to try it on, but havent made that leap of faith yet.
    Jun 2007
    Quote Originally Posted by Kazimir View Post
    sure SSD faster than HDD..
    Jun 2007
    Quote Originally Posted by hotwired_1 View Post
    no tweaked.. I turn off Metro UI start menu only
    Sep 2012
    Germany - Munich
    hi
    i have installed windows 8 on my car pc. in first steps, riderunner is running fine.
    there is also a option to run directly an other program.
    http://myxbmc.bplaced.net/blog/?p=522
    i tested some methods. but no success.
    i think win 8 alows only programs, wich don't need adminrights to start.
    i don't know how difficult it is to program RideRunner, that is possible a start without adminrights.
    @coders: is there a way?
    Variable Bitrate eugenweij's Avatar
    Aug 2010
    Rozenburg, Netherlands
    you can select the option run as administrator in the properties of the .exe , that should solve it
    View my worklog here
    Sep 2012
    Germany - Munich
    the option is already selected. same problem. UAC is also off.
    if i start RR fron desktop, it runs without problem.
    but i stopped the time for system startup. my xp needs the same time to start. nearly 30 - 35 seconds. my systemdrive is a SSD.
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    I also am unable to get RR to run from startup.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
  1. TicTacToe for RideRunner
    By pierrotm777 in forum RR Plugins
    Last Post: 08-31-2010, 01:09 PM
  2. New to RideRunner
    By themlruts in forum Road Runner
    Last Post: 07-13-2010, 01:37 AM
  3. Not able to exit RideRunner...??
    By arb004 in forum Road Runner
    Last Post: 01-04-2010, 11:44 AM
  4. RideRunner Help
    By Joshc8503 in forum Road Runner
    Last Post: 11-30-2009, 01:10 PM
  5. riderunner phone help
    By danchappers in forum Road Runner
    Last Post: 05-17-2009, 03:28 AM
