Results 1 to 8 of 8
Thread: Multiple Music Paths across multiple drives
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I've looked through RR and cannot find a way to set more then one music path in roadrunner. I tried separating by , ; no luck. I must be an idiot becuse there has to be some way to do this if you have music stored on one drive and have a removable for extra stuff. Anyone have an idea or am I blind and completely missed how this can be done?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Take a look at this.......MEDIA LAUNCH.......http://n8sgarage.com/download/chevyn8/
    Sep 2006
    I sort of remember this from 4 years ago now. I hadn't really thought of this. I have been using John's original autolaunch.
    http://www.mp3car.com/rr-plugins/109...ve-letter.html
    Thanks I need to catch up. Guess RR is just passing a string along and it's not possible for built in support.
    MySQL Error
    Oct 2004
    you can have multiple paths.... kinda, using Browse file...
    Browse.RRL
    inside that file is
    PATH;viewing text
    example
    D:\Music;D Drive Music
    and put this browse.rrl file in the main music path...
    can you have multiple lines in browse.rrl? i dont know try...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Jun 2007
    Quote Originally Posted by mitchjs View Post
    Browse.RRL
    inside that file is
    PATH;viewing text
    example
    Could be this a BUG of Browse.rrl / Directory Browser Component????
    look...
    Skin: Carwings
    RRVersion: latest
    Default Music path: C:\Music
    I created Browse.rrl file like this:
    L:\Test\Source1; L Source1
    L:\Test\Source2; F Source2
    RR Shows that paths when library will load
    if double clicks on one of them...RR opens the correct folder....
    but once in....
    if i press BACK button, i'll go to L:\test (showing source1 and source2 )....and if pressed again....L:\...showing all other folders of my usb HDD.... ( independent from "Limit browser path from backing....." is or not enabled)
    so....not gone back to Home Music Path (C:\Music)
    to do that, i have to click HOME button and then RR goes back at C:\Music, showing the list like 1 picture (including Source1 and Source2 "folders")....
    but i think that's not correct...if i click BACK button from the "ROOT" specified by Browser.rrl (source1 or source2), i suppose i have to go back in Home Music Path....
    or not??
    (sorry if it's not really clear and for my bad english xD )
    MySQL Error
    Oct 2004
    yes.. HOME
    there is no cookie around to know where to go back too... once you go into an alternative path
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jun 2007
    And if you save the current path folder once in somewhere, and when back event is fired, you'll check
    if path is the one of alternative roots specified in browse.rrl then execute HOME
    if not, just execute BACK command...
    Inviato dal mio GT-I9100 usando Tapatalk
  1. Music path, Playlist path, Winamp
    By tmar89 in forum Road Runner
    Last Post: 09-12-2006, 07:56 AM
  2. ewf on multiple drives
    By dcdc in forum WinNT Based
    Last Post: 07-08-2006, 06:35 AM
  3. Centrafuse Music Path
    By black06stang in forum Newbie
    Last Post: 05-30-2006, 06:49 PM
  4. multiple drives for music path?
    By glennwoudenberg in forum CF Bug Reports
    Last Post: 04-20-2005, 06:40 AM
  5. mpxf multiple playlist path
    By redscar in forum Software & Software Development
    Last Post: 08-17-2002, 04:03 PM
