Results 1 to 5 of 5
Thread: Fresh RR install + working GPS = Need help getting weather info to show up
    Jul 2008
    Hey everyone! I just installed RR and need some help getting the weather info populated at all. Currently I have installed the BU-353 USB GPS Receiver and verified that it is functional with the utility that came with it. I need some guidance on how to get the GPS and Ride Runner to talk. I have already setup RRconfig to read the correct com port. Also have downloaded zips.dat and placed it in the Program Files\ride runner folder.
    Running Windows 7 32bit SP1
    No AV or anything else installed that could be conflicting (that I know about)
    Am I missing something? Any guidance would be appreciated.
    Jun 2011
    PA
    RR Weather does not need GPS, it needs internet. Using a gps will only allow you to load weather based off of your gps position, but you still need internet.
    Jul 2008
    Quote Originally Posted by dlane2155 View Post
    I was able to get the weather to show last night. I had to follow this guide to get the weather to show.
    My question is will it automatically change as I drive through different Cities? given there is an active internet connection AND gps signal?
    Jun 2011
    PA
    I don't think it will automatically change. You could create a button to refresh the weather with a command that will set the location to your gps position. I think you need the GPS to city app.
    Feb 2012
    also have same question, how to set the weather info, anybody can help us?
  1. Fresh Install of OS and RR - Problems
    By kbreeden in forum Road Runner
    Last Post: 04-25-2010, 01:31 PM
  2. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 10:33 AM
  3. Crashes on start after fresh install of XP & SD
    By bigpimpn79 in forum StreetDeck Bug Reports
    Last Post: 03-21-2007, 07:08 AM
  4. Weather wont show up
    By mick0uziel in forum Road Runner
    Last Post: 05-02-2006, 02:33 AM
  5. Fresh install uses 100% system resources
    By relay700 in forum RR Bug Tracker
    Last Post: 03-08-2005, 07:38 AM
