Results 1 to 10 of 11
Thread: Some user interface problems in RRConfig
    Jun 2007
    Hi guys,
    i notice some problems with the last RRConfig version...
    when i click on "Launch RRReg", i get this error
    Plugin section doesn't show anything
    Component used to set start/end time of skin changing, doesn't show the time, but only the date (calendar format)
    is there already a new fixed version ?
    hope to help you to improve RideRunner
    Apr 2006
    The dll registartion problem is talked about here http://www.mp3car.com/rr-faq/137616-...er-screen.html
    Hopefully someone can add to the plugin problem because I have the same issue and couldn't tell if I was doing something wrong or if it was a bug.
    Jun 2007
    Ok...
    ok, i solved the problem with mswinsck.ocx ...now i'm able to use "Launch RRReg" without problem....
    the right folder where to put mswinsck.ocx, on Windows 7 64 bit systems, is "C:\Windows\SysWOW64"
    i know that probably no one CarPc uses 64 bit Operative System, but maybe some user makes RideRunner's test on that system....
    maybe Guino can update "Faq 3d" with this information
    for the other points, no idea?
    MySQL Error
    Oct 2004
    plugins wont show ANYTHING unless there is a PLUGIN that supports RRCONFIG...and only 1 does MY MJS UAS4, i actually never released any details one how one would create a settings option, cause each programmer of thier own plugins have thier own setups... usually edited a .ini file
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    as for the time...edit it manually
    and ill eventully look at fixing it to a time picker
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jun 2007
    Quote Originally Posted by mitchjs View Post
    sure, i understand...
    I don't thought about that...;-)
    Inviato dal mio GT-I9100 usando Tapatalk
    Jun 2007
    Yes, i edited manually... that's was just a notification ;-)
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    How are plugins supposed to support RRCongig?
    MySQL Error
    Oct 2004
    e, its hard to explain... you know us programmers...no documentation...
    but we put the support in to RRConfig...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    tommy all fixed... thanks pAL!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Define User Interface
    By UnusuallyGenius in forum Software & Software Development
    Last Post: 01-22-2010, 04:12 AM
  2. user interface for xp
    By lloray in forum Software & Software Development
    Last Post: 02-18-2008, 09:04 AM
  3. User interface examples
    By Jirka Jirout in forum QCar
    Last Post: 02-05-2008, 06:22 AM
  4. User interface changes
    By Jirka Jirout in forum MacCar
    Last Post: 03-10-2006, 06:07 AM
  5. the Audio User Interface
    By thecapitalizt in forum Software & Software Development
    Last Post: 01-05-2005, 09:52 PM
