Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: RR 02-05-2012 Release
  1. #21
    MySQL Error
    Oct 2004
    i did a test with 590 songs, and i playing a chinese on, i exit, i restart... it resumes fine
    since i cannot reproduce any issue...
    oh, u know.. pm, i want you to have a newer RR
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    May 2006
    Markham, Ontario, Canada
    Hi Mitch,
    I don't know what you did to the latest version of RR you pm me to download, but the problem is fixed with this version!!. I even uninstall it and re-install the 02-05 version and I can assure you the problem only exist it the older one. I also tried your new version with my favorite Elite 1.6.6 and Elite 2 skins and no problem resume playing Chinese songs after restart the program or even reboot the CarPC. The only issue is it doesn't resume playing everytime I switch to another skin. To me it's no big deal as I don't change skin very often. Thanks so much for help and I will keep update the program every month; but I also keep this version's setup file myself as a backup.
    Jguy_ca
  3. #23
    MySQL Error
    Oct 2004
    when you switch skins, and its playing, it shouldnt stop playing... how do u switch skins? if you use RRCONFIG, rrconfig, deletes the Resume.ini info
    so its all fresh
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #24
    Constant Bitrate Stealth915's Avatar
    Bay Area, CA
    I'm still having a problem with the music tags in eLite 2. Nothing except the bitrate is showing up when I load a playlist. They only show up if I exit out of RR and launch it again. But if I load a different playlist, the tags disappear again and I have to relaunch RR to see them. It worked fine in the 12/2011 version but I guess something between now and then broke it.
    2004 Mazda3 Carputer Worklog - Update 5/17/11: Carputer 2.0 Hardware Selection
  5. #25
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have a little issue into a RR plugin .
    I use this RR command into a screen , but the command seen is always the second "gmaps_placetypetosearch"
    Code:
                Case "gmaps_whatdoyouwant"
                    SDK.Execute("BYVARX;WhatdoYouWant;(OSKTOVAR;GOADDRESS<<gmaps_placetypetosearch)")
                    ProcessCommand = 2
    May be that is use well this option ?
    But, if i use directly the command "BYVARX;WhatdoYouWant;(OSKTOVAR;GOADDRESS<<gmaps_p lacetypetosearch)" into my screen, all is ok !
  6. #26
    May 2006
    Quote Originally Posted by mitchjs View Post
    so its all fresh
    You're right I switch skin in RRConfig; not in RR while music is playing. So everything is back to normal now. Thank you for your help.
    Jguy_ca
  1. RR 01-01-2012 Release - Happy New Year
    By mitchjs in forum Road Runner
    Last Post: 02-16-2012, 05:37 PM
  2. Replies: 2
    Last Post: 01-17-2012, 03:01 PM
  3. Happy New year for 2012
    By pierrotm777 in forum Road Runner
    Last Post: 01-02-2012, 08:20 AM
  4. CES 2012 will be here before you know it!
    By Sonicxtacy02 in forum MP3Car Gatherings
    Last Post: 12-28-2011, 10:47 AM
  5. Latest Build - 2014-06-11
    By ClockWorK in forum Driveline
    Last Post: 06-11-2009, 04:29 PM
