Updated for embedding of iGuidance (4.x tested)
ALSO an internal change on how "back" and ".." work when browsing files...
(allows for better browse.rrl experiences)
Download Here: http://www.nisuautomotive.com
Fixed a bunch of little things, thanks to tommy in italy! (tommy_xx84)
some minor fixes in RRConfig too
dont forget read the history!
History:
Code:LEGEND:
- = Removed
+ = Added
* = Changed
! = Major code change
# = Bug fix
^ = Note
02/05/2012
# Issue fixed for finding iGuidance window
! Fundamental change in how ".." / "back" command works in file browser
02/2/2012
+ Screen Object; Textbox now supports alignment. "left" (default), "center", "right"
ex.T01,225,25,350,56,0,0,0,200,200,200,38,"Arial Narrow:B","TEXTBOX","CENTER"
02/1/2012
# XML file issue in weather plugin, now properlly saves unicode files
01/28/2012
* Tweaks to OPT_PARENT for keeping application visable when a MENU POPUP happens
01/26/2012
+ Skin Command; "ACTIVATE" (no arugments) Activates the current screen's embedded application
+ UserVar; "RRAppHwnd" is the window handle of the current screen's embedded application
+ Skin Label; "RRAppHwnd" shows the window handle of the current screen's embedded application
01/24/2012
# Custom Source issue when more than 1 custom source
01/21/2012
* Skin Indicator "heading" changed to "RRGPSHeading"
+ Skin Label; "RRGPSHeading" shows "N", "NE", "E", "SE", "S", "SW", "W", "NW"
01/17/2012
+ Tweak to Tag reading when song changes
# Fixed incorrect Title data in Playlist(), cause no tags from being read in
01/16/2012
+ Tweak to iList Memory usage
01/11/2012
+ Some minor debug.txt additions + a slight look change to some entries (testing)
01/09/2012
* Tweak for embedding of windows in skin, to allow for when a skin is a centered popup menu
01/08/2012
* Updated the SkinTool, see its history file for details
