i had garmin before but they have stopped supporting it and there was only one way to get updated maps... buy new license
Printable View
That's not correct (about maps)... Just downloaded 2012 european map set (and i'm using 2011 european map set)
Inviato dal mio GT-I9100 usando Tapatalk
Will check for "MAPPOINTCONTROL.OCX" this evening when I get back from work, I must be missing something off my system if you have it all working. I've done two clean installs ofwindows 7 home premium x86 SP1 , and tried 3 versions of mappoint which all give the same result. I take it I don't need any other office apps installed to make this work?
Standalone mappoint runs fine and I've test out the GPS receiver and it finds 9 satellites and pin points my location fine (not tested on the move)
I'll spend a little more time trying to get mappoint working, as I would like to see a GPS only device working in the car, as I'm used to the Audi RNS-E/MMI systems that intergrate with the CAN-BUS system, for speed & sterring angle etc. This is the first time I've gone down the custom ICE solution, I could have just retroffited the Audi nav system but fancied a change and challenge in get a CarPC working.
yea... it should just work.... i didnt do anything special, but install mappoint... then install the rr plugin...
With help from mitch I finaly got mappoint 2011 to work, I think the fault could have been down to me installing the plugin before mappoint and how the mappointcontrol.ocx control was registered. Also in the rr.ini under extras i had mappointmap=1 when from what I understand mappointmap=2 if your running the euro version which I found from an old post back in 2005 http://www.mp3car.com/road-runner/47...embedding.html
One more item off the todo/fix list.
hi, sorry but have been looking for some nav software to work with RR. is there any links to download mappoint or garmin ect, with out big fee's
thanks daveo
