Hello all, Maybe someone can help me.
I was using an older PC with an older version of RideRunner, it was running XP SP3, and I had almost no problems getting it set up and working properly.
I've decided to upgrade, I bought a new motherboard, case, M2-ATX, 4GB Memory, 120GB Intel SSD, and Windows 7 64Bit SP1 operating system.
I'm currently using an AC power supply in the house, it's cold outside!
I installed all the latest Motherboard drivers and windows update stuff.
I installed the latest Flash and Adobe Reader.
I downloaded the latest RR from NISU, 2/5/12, followed the instructions(Winamp - latest version, GPSgate as Xport does not work on 64bit).
I've stuck with Carwings until I get at least the basic stuff working.
I did get my Streets & Trips 2007 to install and I can get it to embed.
The "More" button works, and the "Dimmer" button works, "Pictures" button works.
"Weather" loads the skin, but does not populate.
"Exit" works, as long as the system is not locked up.
1. How can I prevent the UAC Nag screen from asking me if it's OK to run RR every time? And how do I get RR to start on Boot-Up?
2. When I press Music, the system locks up, I have to force it to close. I've set the music path and playlist path in RRConfig.
I am not explicitly familiar with Win 7 yet, so that may be part of my problem.
Anybody got any ideas/guides for setting up with Win7?
Thanks,
Jason
