Results 1 to 8 of 8
Thread: Exception in DeserializeFromINI() Box - Can't open RR config
    Dec 2007
    Mohnton, PA
    so...this just started popping up after I tried to reinstall RR in regular mode instead of profile mode on windows 7. Google search turns up 4 results which mean nothing to me.
    I've tried full uninstall and manually removing reg keys and folders, rebooting, and then reinstalling. Same error. This box pops up as soon as I open rrconfig and doesn't let me in. D'oh!
    Dec 2007
    Mohnton, PA
    So I have to run it as administrator now. lol
    MySQL Error
    Oct 2004
    on windows 7 with UAC ON applications are not allowed to write into program files folder...
    you might be the 1st person and ONLY who is running this way... why i dont know... just go profile
    or if this is the carpc...who needs UAC anyway..turn that off... desktop pc, ok keep it on, but go profile...
    RR will ask for elevation
    id love to see the stack trace so i can fix the bug...since i dont think it should happen, till you save
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Dec 2007
    Mohnton, PA
    I tried to go back to profile mode, but it still needs admin rights. Not a big deal...i'll just set the permissions for that file.
    MySQL Error
    Oct 2004
    yes you do need admin rights... cause your violating UAC rules...and writing to Program Files folders, the 1st thing RRConfig does, is backup your rr.ini
    so that will faill
    something isnt right, when you "go back" to profile mode how are u doing that, without a complete uninstall / DELETE FILES
    but the right way is use the TOOL, i published months ago to move legacy to profile... its in the forum
    (after using it, just review rr root folder, no .ini should should remain, other than media player classic and mpc-hc)
    i will add manifest to rrconfig, to request elevation...
    my advice is run in profile mode
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Fixed for next release, RRConfig will ask for elevation
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2005
    Rochester, NH
    Short term work around I do on my testing box is right click on the shortcut I use to launch RR, click on compatibility tab and select "Run this program as an administrator"
    Now it will ask every time you launch the program but it will work right.
    Alternatively you could probably change permissions on the program files directory but if you are going to do that... just disable UAC.
    Edit: or you could just change permissions on the ride runner directory...
    Last edited by dmcdlrn; 02-24-2012 at 06:54 AM. Reason: thought of something else :)
    MySQL Error
    Oct 2004
    the proper way, is run as administator... BUT you know, if you were properly in PROFILE mode, it wouldn't need you to do anything....
    (RR will ask for elevated rights, since it does a few trick things that are protected in vista/win7)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Replies: 13
    Last Post: 01-13-2012, 08:15 AM
  2. Replies: 9
    Last Post: 12-13-2006, 11:18 AM
  3. Cinergy radio config in RR Config ?
    By pike in forum Road Runner
    Last Post: 06-11-2006, 07:16 AM
  4. Store keypress config? and remote config troubles.
    By lilmansplace in forum Media Engine
    Last Post: 04-08-2005, 06:07 PM
  5. Replies: 2
    Last Post: 11-08-2004, 03:40 PM
