Results 1 to 10 of 20
Thread: Testing RR and having issues with HD Radio.
    Jan 2012
    I'm just not really sure how to set what input the audio is coming into? It seems to be tuning everything fine but I don't see a setting for audio input?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Let's start by "Where on the computer did you plugged it in?"
    Run RRconfig and under the radio section, select your HD Radio and the line where you plugged it in.
    If its the LINE IN on your computer then select LINE IN in RRconfig.
    I have mine plugged in in the motherboard header for the cd rom, and in RRconfig, I selected CD IN.
    Jan 2012
    It only has one device listed and it didn't work. Currently I have the onboard sound working and I'm using a USB sound card as well. Works fine in Centrafuse but not seeing my device in the list on RR.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    What you mean by IT.
    What HD Radio do you have? Visteon or Directed? Do you have mitch's cable?
    Do you have Radio drivers installed?
    Jan 2012
    The radio it self works fine, it tunes it and everything. It's the Visteon, the issue I'm having is that I don't see where to program it to what input the audio portion is coming in at? The input option in the RRConfig has one thing under it, I can't recall what it is at this moment but when I select it, I still get no sound. But RR is tuning the radio and what not.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    RR will show the lines available in you mixer. Check your windows mixer where you pluged it in and see if its muted.
    Jan 2012
    Inputs are generally always muted otherwise you'd always hear it?
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    You right SIR, but RR needs to know where you pluged it in, so it can UNMUTE the line when you select RADIO.
    Jan 2012
    Ok, thanks I'll give that a try in a bit here.
    Jan 2012
    Ok, I figured out how the whole input thing works with the input plug-in. But now I'm having another issue.
    I installed TinyXP and have started setting up RR. I selected Radio Type - HD Radio and setup all the options. The problem is when I load up RR after saving the settings it tells me I've not installed a radio? Not sure what's going on.....
  1. radio/hdradio/obdII testing in nghost
    By tripzero in forum Linux
    Last Post: 03-20-2009, 05:46 PM
  2. testing car radio with psu
    By Snortonnorton in forum Car Audio
    Last Post: 07-09-2007, 09:29 AM
  3. Issues while testing latest version: 1.0.4.1
    By replicant in forum StreetDeck
    Last Post: 03-04-2006, 07:18 AM
  4. Issues Testing a New GPS
    By ukchris in forum GPS
    Last Post: 08-30-2005, 08:23 AM
