Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
Thread: RR 03-02-12 Release
    MySQL Error
    Oct 2004
    RR 03-02-12 Release
    So its March...the year is flying by, even with the "leap" day...
    Download Here: http://www.nisuautomotive.com
    Fixed a bunch of little things...some old bugs... thanks to Dartman_71
    some minor fixes in RRConfig too
    Weather Plugin, has an improved RRConfig addon.
    Highlights:
    • Skin Command; "IFVAR" variable to variable compare (equals or not equals only)
    • Skin Command; EVENT: "ONDIRDBLCLICK" fires when a DIRectory is double cicked on (SD file browser lists)
    • On intial show of a list, LISTxxxx user variables are now refreshed
    • "resume.ini" is now a unicode file(UCS2-LE) this allows unicode paths/filnames inside(last browse paths)
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    2/26/2012
    # On intial show of a list, LISTxxxx user variables are now refreshed
    2/24/2012
    + Skin Command; EVENT: "ONDIRDBLCLICK" fires when a DIRectory is double cicked on (SD file browser lists)
    + Skin Command; "Band;AM" direct switch to AM (HD Radio only)
    + Skin Command; "Band;FM" direct switch to FM (HD Radio only)
    2/20/2012
    * "resume.ini" is now a unicode file(UCS2-LE) this allows unicode paths/filnames inside
    2/16/2012
    # Tweaked "back", properlly goes back, and now sets previous item selected
    2/12/2012
    - Skin Command/Indicator "winamppreampmute" removed (no such function in winamp).
    # Skin Command/Indicator "PlayerEQ" correctly toggles player EQ on/off, and shows correct state.
      (is also a clickable indicator)
    # Skin Command/Indicator "AutoEQ" now shows correct state (on = true).
    2/11/2012
    # Fixed issue where activesource when on a radio_player skin, could get set to audio
    2/8/2012
    # Fixed Start Audio source issue, would seemly cause rr to freeze (momentarlly)
    2/7/2012
    + Skincommand; "IFVAR" variable to variable compare (equals or not equals only)
      ex. "IFVAR;myvar==myothervar;DOTRUE<<DOFALSE"
          "IFVAR;myvar!==myothervar;DOTRUE<<DOFALSE"
      (note the double = (equal), denotes a var to var compare)
    02/06/2012
    # Tweak to skin command "HIDECONTROLS" to not move the cursor out of resolution of display
    02/05/2012
    # Issue fixed for finding iGuidance window
    ! Fundamental change in how ".." / "back" command works in file browser
    02/2/2012
    + Screen Object; Textbox now supports alignment. "left" (default), "center", "right"
      ex.T01,225,25,350,56,0,0,0,200,200,200,38,"Arial Narrow:B","TEXTBOX","CENTER"
    02/1/2012
    # XML file issue in weather plugin, now properlly saves unicode files
    # Fix to installer for PLabs (digitalCar Radio) install folder
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    NOTE, for those people using WeatherUnderground (Weather plugin)
    if using a Language translation...
    in rr.ini, my advice is set rr.ini setting to
    WeatherLanguage=
    to not use the language translation file,
    but use the NEW WeatherUndergroundLangID= setting
    to have WeatherUnderground.com give you back data in the language you want...
    RRConfig v1.0.7, has all the IDs in the new Weather Plugin Config area, or visit the WeatherUnderground.com API Page
    example: (Italian)
    WeatherUndergroundLangID=IT
    yes, the old translation support is still there, but leaning towards obsolete, at the very least depreciated
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Cool, another version
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    thanks for the new version,
    now my mixer indicator works the right way.
    May 2008
    Bend, OR
    *deleted*
    May 2008
    Bordeaux, France
    It's possible to know how to create a RRconfig plugin please ?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Logically the installer will install the lastest RRExtension version example which should have all the new features in it.
    May 2008
    Bordeaux, France
    I have an issue with my indicators into my last plugin that are superimposed !
    my code is:
    [INDICATORS]
    I01,266,10,53,53,"GMAPS_LIST_EXIST",,,""
    I02,575,12,42,40,"ONLINE",,,""
    I03,634,12,30,40,"MOBILEPHONE_CONNECTED",,,""
    I04,518,10,48,48,"GMAPS_GPSOK",,,"Indicators\gpsok _*.png"
    I05,736,191,44,40,"GMAPS_MOBILEPHONEOK",,,"Indicat ors\mobilephone_*.png"
    I06,555,199,90,25,"GMAPS_CLIPBOARDOK",,,"Indicator s\sendtorr_*.png"
    I07,663,193,54,36,"GMAPS_SKYPEOK",,,"Indicators\sk ype_*.png"
    I08,7,544,62,53,"MUTE:b",,,""
    I09,667,409,64,18,"GMAPS_GPSCOOROK:b",,,""
    I10,730,409,64,18,"GMAPS_GPSITINERYOK:b",,,""
    I11,614,435,39,39,"GMAPS_VARTYPETOSEND",,,"Indicat ors\gmapsvartypetosend_*.png"
    I12,608,486,52,9,"GMAPS_TIMERS:b",1000,500,""
    I13,426,502,27,27,"FILE;$skinpath$Indicators\gmaps vartypetosend_00.png"
    What is my error please ?
    Mar 2006
    Installed latest release and RRConfig throws an error on startup and when I try to use any of the buttons (save, exit, etc). The error is:
    Code:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Value of '120' is not valid for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'.
    Parameter name: Value
       at System.Windows.Forms.NumericUpDown.set_Value(Decimal value)
       at RRConfig.nodeGPSServicesNative.DeserializeThisFormFromINI()
       at RRConfig.ConfigForm.DeserializeFromINI()
       at RRConfig.ConfigForm.DeserializeChildNodesFromINI()
       at RRConfig.MainForm.MainForm_Load(Object sender, EventArgs e)
       at System.Windows.Forms.Form.OnLoad(EventArgs e)
       at System.Windows.Forms.Form.OnCreateControl()
       at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
       at System.Windows.Forms.Control.CreateControl()
       at System.Windows.Forms.Control.WmShowWindow(Message& m)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
       at System.Windows.Forms.ContainerControl.WndProc(Message& m)
       at System.Windows.Forms.Form.WmShowWindow(Message& m)
       at System.Windows.Forms.Form.WndProc(Message& m)
       at RRConfig.MainForm.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
        Assembly Version: 2.0.0.0
        Win32 Version: 2.0.50727.1433 (REDBITS.050727-1400)
        CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
    RRConfig
        Assembly Version: 1.0.0.7
        Win32 Version: 1.0.0.7
        CodeBase: file:///C:/Program%20Files/RideRunner/RRConfig.exe
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    System.Drawing
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Core
        Assembly Version: 3.5.0.0
        Win32 Version: 3.5.21022.8 built by: RTM
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
    System.Xml
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
    RRConfigPluginWeather
        Assembly Version: 1.0.0.0
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files/RideRunner/Plugins/Weather/RRConfigPluginWeather.dll
    Accessibility
        CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
        <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    May 2008
    Bordeaux, France
    I have already ask this question.
    Is it possible to add the same tooltip option <crlf> as MIDDLE for the WRAP and WRAP-RIGHT , that would be a very cool option !!!
    Thanks for all your job on RR.
  1. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
  2. New Release: 0.9
    By chunkyks in forum OBDII GPS Logger
    Last Post: 09-26-2009, 01:07 AM
  3. New Release RC4
    By veetid in forum Centrafuse
    Last Post: 10-18-2006, 01:57 PM
  4. The New NMC Release?
    By NiN^_^NiN in forum NeoCar Media Center
    Last Post: 09-14-2005, 06:55 PM
  5. A.I.M.E.E XM - **Release**
    By Confused in forum Software & Software Development
    Last Post: 08-12-2005, 03:13 PM
