Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
Thread: *** New RideRunner Dynamic Menus ****
  1. #11
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Been testing this new great feature and I must say this will simplify menu system greatly! No need to hassle with code anymore... if you don't want to hehe.
    Also documentation is more than sufficient.
    Excellent work Mitch as usually.
  2. #12
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    In fact , i have tested this new feature that is a great news for RR .
    Very good job and easy to use .
  3. #13
    Low Bitrate rtgree01's Avatar
    Aug 2007
    STL
    Mitch...
    I just started looking into adjusting the Elite2 skin to use this new dynamic menu system. This definitely makes the menu system easy and clean. One thing that Elite2 uses is colored themes... He's got awesome icons in several different colors for each of the menu items. I was unable to get the new system to use a variable to add a specific theme color to the path of the icon....
    An example:
    Old way:
    Code:
    IMG,93,132,100,100,"$usethemeiconpath$\icons\menus\$MENUBUTTONICON01$.png",ALL
    New way:
    Code:
    I,93,132,100,100,"RRMenuItem;1"
    Menu.lst has
    Code:
    I tried making the Menu.lst
    Code:
    Where $usethemeiconpath$ is "theme\RED" according to SkinTool, but it didn't work.
    With the April RideRunner version, is it possible to do the themed menu icons?
    If not, I have a couple of suggestions...
    1) process the variables in the icon path... or
    2) let a variable specify the filename of a Menu.lst.... a Menu-Red-Theme.lst
    What do you think?
    Ryan
  4. #14
    MySQL Error
    Oct 2004
    thats correct... the path cannot be a variable, it is never processed by engine, since its not skin language
    anyway.. we have a solution
    #2
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  5. #15
    Aug 2007
    STL
    Ok.... one more feature request.......
    Elite 2 has a nifty feature in it's legacy menu item selection method.... a description for the action. That really makes a nice, easy to use configuration tool.
    Another thing that wasn't totally obvious.... how to clear out a button... I had to add a "Clear Button" menu item option to the menu.lst file. I'm not a huge fan of that method, and I think an image still showed up after I "cleared" the button.
    Thanks Mitch for all your efforts...
    Ryan
  6. #16
    MySQL Error
    Oct 2004
    ** New Features RR Build 4/18/2012 **
    please read posts about menu.lst and plugins (if you're a developer)
    there is a new 5th argument (optional) text description, which is avail on "RRMenuItemSelDesc" LABEL during "MenuItemSet.skin"
    i highlighted the NEW Stuff in RED
    Example Menu.list line:
    Code:
    AUDIO(mp3s)     = "AUDIO",MUSIC,Icons\MUSIC.png,,This is the Audio Player
    SKIN LABEL; "RRMenuItemSelDesc"
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #17
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    Just have to say - this is Great!!
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
  8. #18
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Hi Mitch,
    very nice work. I used the APP Choser before and had enough problems with icons showing.
    now its fast and works perfect.
    for my skin...i coded a possibility of popup a menu skin in most themen skins...i had problems to start.
    to live in a language or speak it from time to time makes the different for understanding what you wrote and what you mean.
    all time i thought "RRMenuItem;1" is a variable information and i can use it in every skin i want.
    that the information is fixed by number of the menu.skin, i learn.
    only one thing would be nice for changing.....inside the select function list, the distance between the icon and text should be a little bit more.
    regards GF_ler
  9. #19
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by GF-ler View Post
    Hi Mitch,
    regards GF_ler
    Hey - it's not a complete fix, but should do the trick. Since you can change the size of icon to display in the ilist, you could just edit the icons to have a invisible border on the right. That would give you the extra distance. A little photo-editing and a slight change in the ilist.
  10. #20
    Aug 2005
    germany
    hi sargeants,
    at the moment i go the easier way and put a "_" in front of the text.
    a "space" character isnt possible while rr ignore it in front of text.
    so its looking in this way
  1. dynamic transitions possible???
    By dlane2155 in forum Road Runner
    Last Post: 11-14-2011, 05:21 PM
  2. Dynamic buttons and XM...
    By Custommx3 in forum RR Skins
    Last Post: 03-14-2011, 05:47 PM
  3. Dynamic Menus/images help (nGen Skin)
    By Deric in forum RR Skins
    Last Post: 08-16-2009, 01:16 AM
  4. Help with dynamic commands ???
    By tolisn in forum Road Runner
    Last Post: 01-29-2005, 03:29 AM
  5. Dynamic Skins???
    By hd54321 in forum FrodoPlayer
    Last Post: 11-01-2004, 05:57 PM
