Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: *** New RideRunner Dynamic Menus ****
    MySQL Error
    Oct 2004
    ALL New for Ride Runner is the Dynamic Menus
    I've had this idea for over a year... just takes something to get me to do it...
    So... I spent a good 2 days coding this... its available NOW for testers (ftp)
    Q What is Dynamic Menus?
    A. A menu system that RideRunner manages, based on skin designer options and automatic plugin subscription.
    Q. Whats a menu system?
    A. Generally the buttons on menu.skin, menu1.skin.... menu9.skin
    Q. What is plugin subscription?
    A. When a plugin is instantiated, RR will ask the plugin for a property, and this is added to Dynamic Menu Selector.
    Pros:
    • No more lines and lines of cryptic code in Exectbl.ini.
    • Fast, no more long delay at skin load for all the commands to build the menus to run.
    • No more reloading skin just to change the menu.
    • Standardized, now all skins can use this method.
    • Plugin Subscription, plugins can subscribe to the Dynamic Menu to provide easy end user integration.
    • Menu skins are easily expandable, a new menu can be added at any time.
    • Skin object code for menu navigation simplified.
    Cons:
    • None
    I prob can use some help documenting this new feature.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    Lets talk Commands, specifically the Dynamic Menu Navigation commands.
    Starting with:
    "RRMenuNext" & "RRMenuPrev"
    Referring to the Image in POST #1
    I have in this example, "RRMenuNext" on the button circled in Green on menu.skin
    B00,76,509,138,29,"RRMenuNext"
    I also have the SAME command on the same button, in menu2.skin,
    infact MENU.skin and Menu2.skin are basicaly identical (only the top right button different)
    now what the commands do
    "RRMenuNext" will load the next menu in the sequence up to menu9, and loop around.
    example; if you have "menu.skin" and "menu2.skin" (yes you can have "menu1.skin")
    and you are on "menu.skin" it will go "menu2.skin" the same command on "menu2.skin" goes to "menu.skin".
    (since you dont have 3-9)
    "RRMenuPrev" will load the previous menu, and loop around.
    example; if you have "menu.skin" and "menu1.skin" and "menu3.skin" and "menu4.skin", and you are
    on "menu3.skin" it will go to "menu2.skin", the same command on "menu.skin" goes to "menu4.skin".
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Next lets talk about Dynamic Menu Item; Commands, Labels, and Indicators, and that one variable
    Commands:
    "RRMenuItem;x" - where "x" is 1-n
    "RRMenuItem;x;Set" - where "x" is 1-n
    "RRMenuItemSave;key;(menuitem)" - where "key" is the MenuItemKey, "menuitem" is the MenuItemValue
    Labels:
    Indicators:
    Important, USER Variable:
    "RRMenuItemKey" - contains the current MenuItemKey when "Set" is used.
    looking at the item in the RED circle, actually its two obects there, a Button Object and a Label Object
    The Button:
    lets look at the Skin Object Code on that:
    B02,53,079,352,57,"RRMenuItem;1",@RRMenuItem;1;set @
    We got a click command of "RRMenuItem;1", and a HOLD command of "RRMenuItem;1;set", where 1 is the 1st button on the menu.skin, so on this menu.skin, we have 6 menu buttons
    they would be (1-6):
    B03,62,152,370,52,"RRMenuItem;2",@RRMenuItem;2;set @
    B04,66,222,370,54,"RRMenuItem;3",@RRMenuItem;3;set @
    B05,72,296,356,53,"RRMenuItem;4",@RRMenuItem;4;set @
    B06,65,368,361,53,"RRMenuItem;5",@RRMenuItem;5;set @
    B07,53,438,358,50,"RRMenuItem;6",@RRMenuItem;6;set @
    Simple enough
    Now the Label:
    L05,107,081,277,31,255,255,255,28,"Arial:B","RRMen uItem;1","LEFT",,"DS=3,3,0,0,0"
    L06,122,153,294,34,255,255,255,28,"Arial:B","RRMen uItem;2","LEFT",,"DS=3,3,0,0,0"
    L07,134,225,293,38,255,255,255,28,"Arial:B","RRMen uItem;3","LEFT",,"DS=3,3,0,0,0"
    L08,139,298,279,36,255,255,255,28,"Arial:B","RRMen uItem;4","LEFT",,"DS=3,3,0,0,0"
    L09,133,371,283,35,255,255,255,28,"Arial:B","RRMen uItem;5","LEFT",,"DS=3,3,0,0,0"
    L10,119,440,279,37,255,255,255,28,"Arial:B","RRMen uItem;6","LEFT",,"DS=3,3,0,0,0"
    simple enough
    now the Indicator images, the violet circle (ok they all ovals, but thats not important )
    The Indicators:
    I,355,080,56,56,"RRMenuItem;1"
    I,376,151,56,56,"RRMenuItem;2"
    I,387,223,56,56,"RRMenuItem;3"
    I,388,294,56,56,"RRMenuItem;4"
    I,384,366,56,56,"RRMenuItem;5"
    I,369,435,56,56,"RRMenuItem;6"
    simple enough
    thats it, no more skin code is needed to create a menu... and yes Menu2.skin or Menu3.skin, is IDENTICAL!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Now we talk about Data...where is the data coming from...
    There is a new "menu.ini" file with that keeps the Dynamics of the menu.
    This file is not ment to ever be hand edited (you can) but you dont need to...realy! (even the 1st time without one)
    this file is with the skin, just like "general.ini" and "skin.ini"
    using say button #1
    now what lets detail "RRMenuItem;1;set" the set is the trigger, rr will now show a menu popup (Reserved skin name) of "MenuItemSet.skin".
    This is a required skin if you are going to have user changable menus.
    Its content is up to the skinner... here is a quick one put together for Carwings
    There is nothing that special here, its just a CustomList, and in this case with ICONS
    RR will populate it for you. No code is required, the skin name is how rr knows what to do
    While on this skin, an Indicator "RRMenuItemSelIcon" is active, with the icon of the selected list item. (more this later, im not even using it)
    lets look at the SELECT button code:
    B,67,370,109,55,"RRMenuItemSave;$RRMenuItemKey$;($ ListText$)||EXIT"
    "RRMenuItemSave" is the command, with 2 arguments, 1 is the KEY and 2 is the Value
    note the ( ), they are required! as they define the value start/end.
    The Key is the Dynamic Menu Key, as soon as you go into this popup, from a menu.skin, the key is set in User Var: "RRMenuItemKey"
    Example, if on menu.skin, the key is "RRMenuItem1"
    Example, if on menu2.skin the key is "RRMenu2Item1"
    (remember we are talking about the 1st button, hense the 1, the 6th button would be "RRMenuItem6")
    The Value is the metadata for the menu item, which is, the COMMAND rr is to exec when pressed, the LABEL of the button, and the INDICATOR image.
    Ill show you what that looks like... lets do Radio
    the format is
    "COMMAND",LABEL,Iconpath,,discription
    Command is in qoutes
    Iconpath is path to the indicator image relative the SKINPATH
    4th argument is blank
    description is a textual description available in LABEL "RRMenuItemSelDesc"
    simple still hu?
    the USER never touches this stuff (unless he wants to tweak/add MenuItems)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Metadata
    This is the Skin Designers job, to create the Metadata list
    of course a User may add to it.. tweak it too, if one wants to change the text
    the list is in a file called "menu.lst"
    its a Key Value Pair text file
    KEY=VALUE
    (yea, like just a ini file)
    lets look at the one in CARWINGS, at least the one i created so far...
    (spaces are trimmed)
    Code:
    [ Available Menu Items]
    # LISTITEM = "COMMAND",LABEL,[ICON_PATH][,,[DESCRIPTION]]
    CLEAR BUTTON	= "",,,,Clear the Buttons functionality
    AUDIO(mp3s)     = "AUDIO",MUSIC,Icons\MUSIC.png,,This is the Audio Player
    # Other Navigation
    the KEY (left side of the equals) is what is SHOWN in the LIST on the "MenuItemSet.skin"
    the VALUE is the MenuItem Data, that RR uses to create the menu
    so.. if you want an option for say some Fuel plugin... ill make it up
    add to the file:
    oh, by the way, if you dont have the icon, no biggy, its not required, it just shows nothing in the list and on the indicator...
    Well, thats the Dynamic Menu System in Ride Runner (build 3/8/2012 onward)
    I might tweak a thing or two, but thats why we testing... its avail on my FTP now
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    RECAP:
    New reserved files:
    Menu.ini
    Menu.lst
    New reserved skin files:
    MenuItemSet.skin
    Standard RR Reserved skin files:
    Menu.skin, Menu1.skin... Menu9.skin
    New Commands, Indicators, labels:
    Skin Command: "RRMenuItem;x;[set]"
    Skin Label: "RRMenuItem;x"
    Skin Indicator: "RRMenuItem;x"
    Skin Command: "RRMenuItemSave;key;(menuitem)"
    Skin Indicator: "RRMenuItemSelIcon" shows icon(if any) of selected item in the MenuItemSet.Skin List
    User Variable: "RRMenuItemKey"
    Skin Command: "RRMenuNext" goes to next menuX.skin (looping)
    Skin Command: "RRMenuPrev" goes to previous menuX.skin (looping)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Plugins,
    Plugins that support Property : "menuitem" will be subscribed to the Dynamic Menu Item list
    c# (in the properties method)
    Code:
    // Dynamic Menu
    case "menuitem":
        properties = "\"WEBRADIO\",WEB RADIO,Icons\\WebRadio.png,Web Radio (Internet)";
        break;
    note a 4th item (Web Radio (Internet)), its the text that shows in the "MenuItemSet.skin" list
    vb6:
    Code:
    Case "menuitem"
        Properties = Chr(34) + "MAPPOINT" + Chr(34) + ",MAPPOINT,Icons\GPS.png,Mappoint by Microsoft as Navigation"
    note the 4th item, the text in the list will be the PLUGIN Assembly Name, in this case "Mappoint"
    note the 5th item, is a textual description, which is available in the label "RRMenuItemSelDesc" on the "MenuItemSet.skin"
    Plugins start with PI-
    as you can see
    All these plugins, now support this property
    My plugins are on my DropBox, Web Browser, and Web Radio already updated
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Been working with mitch on this and its simply awesome. Noone will ever have to edit a exectbl.ini or menu.skin file again to customize their setup. It's a simple hold of the command and replace with an alternative from the list. THIS is the simplicity that RR has been missing... outside of DFX and a few other skins lol
    Live mp3Car Facebook Chat
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    This is funny actually...I did tinker in the RR Code awhile ago (~6 months) to make an attempt at making the that whole process easier and better then doing it through one of the old methods...skin plugin/exectbl/skin.ini/ect... Good thing that my attempt never made it into the svn...would have been "re-written"....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    This is a great feature for RR.
    Greats thanks
  1. dynamic transitions possible???
    By dlane2155 in forum Road Runner
    Last Post: 11-14-2011, 04:21 PM
  2. Dynamic buttons and XM...
    By Custommx3 in forum RR Skins
    Last Post: 03-14-2011, 04:47 PM
  3. Dynamic Menus/images help (nGen Skin)
    By Deric in forum RR Skins
    Last Post: 08-16-2009, 12:16 AM
  4. Help with dynamic commands ???
    By tolisn in forum Road Runner
    Last Post: 01-29-2005, 02:29 AM
  5. Dynamic Skins???
    By hd54321 in forum FrodoPlayer
    Last Post: 11-01-2004, 04:57 PM
