Results 1 to 8 of 8
Thread: Help with list and embeding applications
    Feb 2011
    Hi all, i'm making some custom skin files, working right now on Game skin; it consist in load a custom list with .lnk files (shortcut of the games)
    so it will list all the shortcuts of games.
    But i have some problems:
    - is possible to block the path of a list? i mean exactly like music and video, so is possible to go on sub folders but not up
    - is possible to run an apllication embed like applications list do? (with notepad, and calc) with a dinamic button so one button for run the element embed
    This is the code i use right now for the list:
    SD,00,03,22,22,"C:\Giochi","*.lnk*",
    IL,DL,RGBFF00FF,RGBcfcfcf,,2,70,50
    Thanks to all that have read
    MySQL Error
    Oct 2004
    answer to 1st question is of course... reading the history.txt helps...
    (i know, if you dont know what to look for its really hard... even i have to figure it out every time, and i wrote it)
    OPTIONS: "OPT_LOCKROOT" - prevents browsing upwards from the
    directory supplied in path argument
    example:
    SD,00,00,32,32,"C:\Giochi","*.lnk",False,"OPT_LOCK ROOT","",""
    see in history: 2/4/2011
    your second quesiton is yes too...
    you could make a button load the selected item in the list
    "load;game.skn;;$LISTPATH$$LISTTEXT$;windownam e"
    like that... look at the load command...
    windowname is going to be hopefully the same...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2011
    thanks so much mitch, i'm going to read it asap; i've read the object txt and saw some example, is still hard for me to figure out how to make a variable / register an event and make also simple commands... the relased skins helps alot without them i think i was not able for example to make a button with multiple commands
    update:
    -I 've read the history but it stops at:
    12/5/2010
    # Fixed Skin Editor Crash when deleting all items on screen
    -I've also testet the line you've make but i can't get it to work, i can still change directory from "C:\Giochi" to "C:\"
    -About the load command the problem is exactly the window name because i have a list of for example 10 games, every game has its window name (Angry Birds, Fruit Ninja, and so on) there isn't a way to make the window parameter dinamically?
    Thanks again, i'm trying to make a skin for games on list with on right an image example
    Feb 2011
    i have make something using some examples, i will use a txt file for list:
    - path of the game and window name
    - name label on list
    - icon of the game
    for example:
    LSTC:\Users\Administrator\Desktop\Fruit Ninja HD - PC\FruitNinja.exe;Fruit Ninja||Fruit Ninja
    The list works, i can see Fruit Ninja and his icon, the command i used is CLLOAD
    The problem is that i don't know how to get the path on the text file "C:\Users\Administrator\Desktop\Fruit Ninja HD - PC\FruitNinja.exe;Fruit Ninja"
    so i'm stuck here.. the command for now is: load;external_application.skin||RUN;--variable of the path in text file--"
    some one got the solution?
    MySQL Error
    Oct 2004
    1st history stops? what does that mean... are u using a riderunner from this YEAR, not 2010!!! best get latest!!
    assuming the latest
    in you example there
    $LISTTEXT$ would contain the selected item in your case "C:\Users\Administrator\Desktop\Fruit Ninja HD - PC\FruitNinja.exe"
    so
    Code:
    load;external_application.skin;;$LISTTEXT$;windowname
    thats all u need
    but, windowname... for embedding that could be tricky
    learn by using SKINTOOL!!!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2011
    Thanks! it works! but applications doesn't embed i will try to fix
    you mean use RRSkinEditor? because i'm using right now notepad and the object.txt list; i can't understand much RRSkinEditor but i think to learn it if i whant to fix problems like this without help..
    now it works, i used "load;external_application.skin;;$LISTTEXT$" and in the file "LSTPath;Window Name||Label"
    MySQL Error
    Oct 2004
    no i didnt mention Skineditor
    SKINTOOL!!!
    make sure u got the right window name, use SPY to figure it out
    easy to test in skintool
    cmd:
    run;;windowname
    if it embedds u got it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2011
    ahhh i got it, didn't knew about skintool never saw it before, i fell a bit ignorant
    anyway it works right now i had to add on list the "path;windowname" i had before only the path that's why it wasn't embed
    now for install games (for put them on list) i will make a decent tool in vb or vbscript that will let select the game, locate the exe and upload "gamelist" and ofcourse the same tool will let unistall the game (phisically or only from list)
  1. coverjuke 1.51 embeding?
    By dotcom1 in forum Road Runner
    Last Post: 09-25-2009, 02:27 PM
  2. Applications list empty
    By ajdale in forum Road Runner
    Last Post: 05-25-2007, 06:08 PM
  3. I need a little help with embeding in CF 1.4
    By wodie in forum Centrafuse
    Last Post: 08-02-2005, 09:31 AM
  4. APPS_Cannot see text when viewing added applications in list
    By clean customs in forum FP Bug Reports
    Last Post: 01-29-2005, 01:12 AM
  5. Add Applications - Applications Screen
    By frodobaggins in forum FP FAQ
    Last Post: 12-01-2004, 06:38 PM
