Results 1 to 7 of 7
Thread: Ride Runner freezing on exit
    Jun 2005
    I just updated to the march 2012 riderunner from a 2009 version and i've got a few unsolvable issues that I'll create different threads for.
    As the topic states, it freezes on exit, hibernate, reboot, etc. Havent tried lock or shutdown, but cancel and going back to the skin works. I loaded carwings v2 and tested exit with that, same freeze. When froze, it will use the entire cpu core (solid 25% from dual core with HT) and ride runner has to be killed with taskmgr.
    i have tried disabling "quit embedded program on exit" for iguidance 4 and winamp 5, but neither of these seem to help
    here is the log file, but it does not seem to include anything interesting.
    Code:
    3/17/2012 3:03:26 PM: Start -- Version: 3/1/2012
    3/17/2012 3:03:26 PM: OS Type: Windows XP
    3/17/2012 3:03:26 PM: FileManager: FileMode = Legacy
    3/17/2012 3:03:26 PM: FileManager: mypath = C:\Program Files\Road Runner\
    3/17/2012 3:03:26 PM: FileManager: ProfilePath = C:\Documents and Settings\Administrator\My Documents\RideRunner\
    3/17/2012 3:03:26 PM: Start Sequence: Starting Player...
    3/17/2012 3:03:26 PM: PLAYER: Initialization creating object
    3/17/2012 3:03:26 PM: Winamp AudPlayer---> waiting for window handle
    3/17/2012 3:03:26 PM: Winamp AudPlayer---> winamp.exe started: v20530
    3/17/2012 3:03:26 PM: PLAYER: Started
    3/17/2012 3:03:26 PM: PLAYER: Winamp Version: 5.32
    3/17/2012 3:03:26 PM: PLAYER: Initialization complete
    3/17/2012 3:03:26 PM: Start Sequence: Starting Radio Device...
    3/17/2012 3:03:26 PM: WinTVRadio---> RadioStart
    3/17/2012 3:03:31 PM: WinTVRadio---> radio.exe failure
    3/17/2012 3:03:31 PM: Start Sequence: Starting Serial Devices...
    3/17/2012 3:03:31 PM: Start Sequence: Starting Mixer...
    3/17/2012 3:03:31 PM: Master Vol: Master Volume/4
    3/17/2012 3:03:31 PM: Master Vol reports number of channels =2
    3/17/2012 3:03:31 PM: GetLineControl Failed: 401
    3/17/2012 3:03:31 PM: No Treble Support
    3/17/2012 3:03:31 PM: No Bass Support
    3/17/2012 3:03:31 PM: No Master ON/OFF
    3/17/2012 3:03:31 PM: Source: Mixer line #1: Wave=&H1008
    3/17/2012 3:03:31 PM: Source: Mixer line #2: SW Synth=&H1004
    3/17/2012 3:03:31 PM: Source: Mixer line #3: CD Player=&H1005
    3/17/2012 3:03:31 PM: Source: Mixer line #4: Front=&H100A
    3/17/2012 3:03:31 PM: No Mute for Source
    3/17/2012 3:03:31 PM: Source: Mixer line #5: Rear=&H100A
    3/17/2012 3:03:31 PM: Source: Mixer line #6: Subwoofer=&H100A
    3/17/2012 3:03:31 PM: Source: Mixer line #7: Center=&H100A
    3/17/2012 3:03:31 PM: Source: Mixer line #8: SPDIF=&H1001
    3/17/2012 3:03:31 PM: Can't Open Source
    3/17/2012 3:03:31 PM: Source: Mixer line #9: Line Volume=&H1002
    3/17/2012 3:03:31 PM: Source: Mixer line #10: Mic Volume=&H1003
    3/17/2012 3:03:31 PM: Source: Mixer line #11: PC Beep=&H100A
    3/17/2012 3:03:31 PM: Source: Mixer line #12: PC Speaker=&H1008
    3/17/2012 3:03:31 PM: Start Sequence: Starting Speech...
    3/17/2012 3:03:32 PM: DirectDraw Count: 1 - []
    3/17/2012 3:03:32 PM: Plugin Manager: loading Global Plugins...
    3/17/2012 3:03:32 PM: Plugin Manager: Plugin Found: MovieTimes plugin found but will be unable to create (most likely NOT registered)[skipped].
    3/17/2012 3:03:32 PM: Plugin Manager: Plugin Found: RRFuelPrices
    3/17/2012 3:03:32 PM: Plugin Manager: Plugin loaded (Global): RRFuelPrices
    3/17/2012 3:03:33 PM: Plugin Manager: Plugin Found: RRGas
    3/17/2012 3:03:33 PM: Plugin Manager: Plugin loaded (Global): RRGas
    3/17/2012 3:03:33 PM: Plugin Manager: Warning Plugin RRGas does not support Enabled Method
    3/17/2012 3:03:33 PM: Plugin Manager: Warning Plugin RRGas does not support Initialize Method
    3/17/2012 3:03:33 PM: Plugin Manager: Plugin Found: RRWebBrowser(.NET)
    3/17/2012 3:03:33 PM: Plugin Manager: Plugin loaded (Global): RRWebBrowser
    3/17/2012 3:03:34 PM: Plugin Manager: Plugin Found: SkinTool
    3/17/2012 3:03:34 PM: Plugin Manager: Plugin loaded (Global): SkinTool
    3/17/2012 3:03:34 PM: Plugin Manager: Plugin Found: Weather
    3/17/2012 3:03:34 PM: Plugin Manager: Plugin loaded (Global): Weather
    3/17/2012 3:03:34 PM: Plugin Manager: loading Global Plugins Completed.
    3/17/2012 3:03:34 PM: LoadSkin: C:\Program Files\Road Runner\Skins\Crystalblue\
    3/17/2012 3:03:34 PM: Plugin Manager: loading SkinDir Plugins...
    3/17/2012 3:03:34 PM: Plugin Manager: loading SkinDir Plugins Completed.
    3/17/2012 3:03:34 PM: Plugin Manager: Error loading (menu.skin): Playlist (ActiveX component can't create object, check spelling of plugin, or its is COM registration missing.)
    3/17/2012 3:03:34 PM: Plugin Manager: Warning loading rrgas (Attempt load more then once, most likely duped in globals and/or in skin).
    3/17/2012 3:03:34 PM: Plugin Manager: Warning loading rrfuelprices (Attempt load more then once, most likely duped in globals and/or in skin).
    3/17/2012 3:03:35 PM: Enter Exec: False, menu.skin, "ONRESTORED", False
    3/17/2012 3:03:35 PM: Que Exec: True, menu.skin, "ONRESTORED", False
    3/17/2012 3:03:35 PM: Que Exec: True, menu.skin, "ONSTART", False
    3/17/2012 3:03:35 PM: Que Exec: True, menu.skin, "ONLINE", False
    3/17/2012 3:03:35 PM: Leave Exec: False, menu.skin, ONLINE, False
    3/17/2012 3:03:35 PM: PLAYER: Restored rrpl.m3u8
    3/17/2012 3:03:35 PM: INFO: CheckResume() - ResumeMusic=1 WasRadio=0
    3/17/2012 3:03:36 PM: Enter Exec: False, menu.skin, , False
    3/17/2012 3:03:36 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
    3/17/2012 3:03:36 PM: EXECTBL Translation: ONSKINSTART -> SETALLFUNCTION
    3/17/2012 3:03:36 PM: EXECTBL Translation: SETALLFUNCTION -> SETVAR;ALLMENUFUNCTION;AUDIO<<VIDEO<<DVD<<GPS<<RADIO<<TV<<TELEPHONE<<CAM<<CARWEB<<CDRIP<<LAUNCH<<PICTURE
    3/17/2012 3:03:36 PM: Executing: SETVAR;ALLMENUFUNCTION;AUDIO<<VIDEO<<DVD<<GPS<<RADIO<<TV<<TELEPHONE<<CAM<<CARWEB<<CDRIP<<LAUNCH<<PICTURE
    3/17/2012 3:03:36 PM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    3/17/2012 3:03:36 PM: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
    3/12/2017 3:03:41 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||EXIT", False
    3/12/2017 3:03:41 PM: Que Exec: True, menu.skin, "ONBTNPRESS||EXIT", False
    3/12/2017 3:03:41 PM: Que Exec: True, menu.skin, "EXIT", False
    3/12/2017 3:03:41 PM: Executing: EXIT
    3/12/2017 3:03:42 PM: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
    3/12/2017 3:03:42 PM: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
    3/12/2017 3:03:43 PM: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||CANCEL", False
    3/12/2017 3:03:43 PM: Que Exec: True, exit_menu.skin, "ONBTNPRESS||CANCEL", False
    3/12/2017 3:03:43 PM: Que Exec: True, exit_menu.skin, "CANCEL", False
    3/12/2017 3:03:43 PM: Executing: CANCEL
    3/12/2017 3:03:43 PM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    3/12/2017 3:03:43 PM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    3/12/2017 3:03:45 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||EXIT", False
    3/12/2017 3:03:45 PM: Que Exec: True, menu.skin, "ONBTNPRESS||EXIT", False
    3/12/2017 3:03:45 PM: Que Exec: True, menu.skin, "EXIT", False
    3/12/2017 3:03:45 PM: Executing: EXIT
    3/12/2017 3:03:45 PM: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
    3/12/2017 3:03:45 PM: Leave Exec: False, exit_menu.skin, ONSCREENCHANGE, False
    3/12/2017 3:03:49 PM: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||REBOOT", False
    3/12/2017 3:03:49 PM: Que Exec: True, exit_menu.skin, "ONBTNPRESS||REBOOT", False
    3/12/2017 3:03:49 PM: Que Exec: True, exit_menu.skin, "REBOOT", False
    3/12/2017 3:03:49 PM: Executing: REBOOT
    3/12/2017 3:03:49 PM: Enter Exec: False, exit_menu.skin, "ONEXIT", False
    3/12/2017 3:03:49 PM: Que Exec: True, exit_menu.skin, "ONEXIT", False
    3/12/2017 3:03:49 PM: Leave Exec: False, exit_menu.skin, ONEXIT, False
    3/12/2017 3:03:49 PM: Shutdown: (1)
    3/12/2017 3:03:49 PM: Shutdown: (2)
    3/12/2017 3:03:49 PM: Shutdown: (3)
    Let me know if you have any sugguestions I can try
    Jun 2005
    now i'm getting a message:
    "run time error '9' subscript out of range"
    instead of freezing. this only happens when the option to unload winamp on exit is checked, and also does not happen every time (maybe 3 out of 4 times). I can click ok to this message and riderunner.exe is no longer in the process list, but it will not return a mouse/keyboard/desktop if they were hidden. I just updated to the latest winamp as of todays date (to fix some playlist bugginess).
    could this all be caused by winamp? is there a recommended version to use with the march 2012 riderunner?
    MySQL Error
    Oct 2004
    yes.. and or a plugin, and or a rr plugin
    use the NEWEST Winamp!
    remove some plugins, like RRGAS and RRFuelPrices
    for sure remove, MOVIETIMES, that hasnt worked in years
    since u got to stage 3 of shutdown, i suspect:
    1. XM or Sirius or Radio
    2. a RR plugin
    Test with carwings_dynamic
    RUN RRCONFIG at least once, to clean up your OLD rr.ini!!!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    MySQL Error
    Oct 2004
    if you need some personal help, im avail... not sure if you got you set up going yet
    remember old Road Runner .exe and .dlls are not compatable with the new RideRunner, so both cannot be installed
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jun 2005
    well, my solution thus far is just to leave winamp running on close, since rr closing it results in said error. I dont exit out of RR much anyway.
    was also having some freezing issues the other day when switching between a few menus, but only once was control not returned after 15 or so seconds. These issues have seemed to work themselves out, however, as it hasnt froze once since a few days ago.
    MySQL Error
    Oct 2004
    maybe its a plugin you have in winamp?
    true you dont exit rr much...
    but it should be able to exit cleanly
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jun 2005
    i dont think winamp has any plugins installed, its the new version i just downloaded a couple of days ago. I dont think my old winamp had any plugins either except for the default avs. either way, not a huge issue for now. i'll revisit this if it ever becomes more than an occasional nucance
  1. Replies: 18
    Last Post: 09-28-2011, 02:10 PM
  2. Upgrade Road Runner to Ride Runner
    By dmistry in forum Road Runner
    Last Post: 03-21-2010, 01:42 PM
  3. Replies: 58
    Last Post: 09-20-2009, 08:19 AM
  4. road runner freezing on startup :(
    By skiman in forum Road Runner
    Last Post: 03-13-2007, 10:37 AM
  5. Road Runner wont exit after reformat?
    By Sonicxtacy02 in forum Road Runner
    Last Post: 06-09-2006, 07:07 PM
