Skin tool doesn't see a value either![]()
Good evening all,
I'm having a few problems getting sliders to work from plugins (the two I've tried are "wifiman_signal" and "DFXVOICE_SCANPROGRESS" allbeit DFXVoice is under development). The code used with the single image file is:
S,461,258,300,22,461,258,300,22,,"DFXVoiceslider.p ng",,,"DFXVOICE_SCANPROGRESS",
If I replace "wifi_signal" or "DFXVOICE_SCANPROGRESS" with "SONGPOS", the sliders works as advertied.
Any advice would be welcomed.
TIA,
Dave
Vauxhall Astra SXi Car PC installed.
Bump before the holidays![]()
skintool, technically is a plugin, and if its loaded before the said plugin, it wont be able to show you a plugin's slider
if you follow my drift
as for the two sliders you mention, im not familar with both...you actually need help with the wifiman plugin i guess
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
