Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: RR 04-01-2012 Release
  1. #21
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I had that issue on one of my PC's and that was XP.
    Can't remember what fixed it now.
    Could be the playlist files m3u and m3u8 or possibly an extension association with winamp
    btw the way your post read looked like you had upgraded rather than did a clean install of 7
  2. #22
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Added debug and rr.ini in my original post. This is the 2nd laptop to have the issue. The first one is installed in the car and have been using the same music for as long as I have been using RR and DFX, since 2007.
    CAR: 2007 G35 Sport Coupe 5AT
    HARDWARE: Dell D630 w/ dock, internal 80G HD, internal 320G HD, Verizon Wireless Card, iBlue GM-2 GPS w/iGuidance, OBDPros w/DashCommand, Visteon HD Radio w/ Home Made Cable, Current Version of RR w/ DFX Skin. My Install.
  3. #23
  4. #24
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Is your Win 7 64 or 32 bit.
    If it is 64 bit is your winamp in the Program Files (x86) folder?
    if so you may need to specify the path to winamp in the rr.ini.
  5. #25
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Quote Originally Posted by Enforcer View Post
    All installs are 32 bit. Will redo the debug momentarily as suggested.
  6. #26
    Mod - all of it.
    Jul 2007
    Buena Park, So Cali
    Carwings debug.
    Code:
    4/11/2012 3:24:46 PM: Start -- Version: 4/1/2012
    4/11/2012 3:24:46 PM: OS Type: Windows 7
    4/11/2012 3:24:46 PM: FileManager: FileMode = Profile
    4/11/2012 3:24:46 PM: FileManager: mypath = C:\Program Files\RideRunner\
    4/11/2012 3:24:46 PM: FileManager: ProfilePath = C:\Users\Drew\Documents\RideRunner\
    4/11/2012 3:24:46 PM: Start Sequence: Starting Player...
    4/11/2012 3:24:46 PM: PLAYER: Initialization creating object
    4/11/2012 3:24:47 PM: PLAYER: Started
    4/11/2012 3:24:47 PM: PLAYER: Winamp Version: 5.62
    4/11/2012 3:24:47 PM: PLAYER: Initialization complete
    4/11/2012 3:24:47 PM: Start Sequence: Starting Radio Device...
    4/11/2012 3:24:47 PM: Start Sequence: Starting Serial Devices...
    4/11/2012 3:24:47 PM: Start Sequence: Starting Mixer...
    4/11/2012 3:24:47 PM: VMC---> Set object successful
    4/11/2012 3:24:47 PM: Start Sequence: Starting Speech...
    4/11/2012 3:24:47 PM: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    4/11/2012 3:24:47 PM: Plugin Manager: loading Global Plugins...
    4/11/2012 3:24:47 PM: Plugin Manager: Plugin Found: GpsLockout
    4/11/2012 3:24:47 PM: Plugin Manager: Plugin loaded (Global): GpsLockout
    4/11/2012 3:24:47 PM: Plugin Manager: Plugin Found: InetRadioLabels
    4/11/2012 3:24:47 PM: Plugin Manager: Plugin loaded (Global): InetRadioLabels
    4/11/2012 3:24:47 PM: Plugin Manager: Plugin Found: RRExtended
    4/11/2012 3:24:47 PM: Plugin Manager: Plugin loaded (Global): RRExtended
    4/11/2012 3:24:48 PM: Plugin Manager: Plugin Found: RRMediaDB
    4/11/2012 3:24:48 PM: Plugin Manager: Plugin loaded (Global): RRMediaDB
    4/11/2012 3:24:48 PM: Plugin Manager: Plugin Found: SkinTool
    4/11/2012 3:24:48 PM: Plugin Manager: Plugin loaded (Global): SkinTool
    4/11/2012 3:24:48 PM: Plugin Manager: Plugin Found: Weather
    4/11/2012 3:24:48 PM: Plugin Manager: Plugin loaded (Global): Weather
    4/11/2012 3:24:48 PM: Plugin Manager: loading Global Plugins Completed.
    4/11/2012 3:24:48 PM: LoadSkin: C:\Users\Drew\Documents\RideRunner\Skins\Carwings_Dynamic_Lite\
    4/11/2012 3:24:48 PM: Plugin Manager: loading SkinDir Plugins...
    4/11/2012 3:24:48 PM: Plugin Manager: loading SkinDir Plugins Completed.
    4/11/2012 3:24:48 PM: INFO: LoadKVPFromFile() - Reading KVP data from C:\Users\Drew\Documents\RideRunner\Skins\Carwings_Dynamic_Lite\Menu.ini
    4/11/2012 3:24:49 PM: Enter Exec: False, menu.skin, "ONRESTORED", False
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "ONRESTORED", False
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "SETVAR;SKINORIGWIDTH;800||SETVAR;SKINORIGHEIGHT;600||SETVAR;SKINSHOWWIDTH;800||SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
    4/11/2012 3:24:49 PM: Executing: SETVAR;SKINORIGWIDTH;800
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "SETVAR;SKINORIGHEIGHT;600||SETVAR;SKINSHOWWIDTH;800||SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
    4/11/2012 3:24:49 PM: Executing: SETVAR;SKINORIGHEIGHT;600
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "SETVAR;SKINSHOWWIDTH;800||SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
    4/11/2012 3:24:49 PM: Executing: SETVAR;SKINSHOWWIDTH;800
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "SETVAR;SKINSHOWHEIGHT;600||SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
    4/11/2012 3:24:49 PM: Executing: SETVAR;SKINSHOWHEIGHT;600
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "SETVAR;SKINXPOSITION;0||SETVAR;SKINYPOSITION;0", False
    4/11/2012 3:24:49 PM: Executing: SETVAR;SKINXPOSITION;0
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "SETVAR;SKINYPOSITION;0", False
    4/11/2012 3:24:49 PM: Executing: SETVAR;SKINYPOSITION;0
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "ONSTART", False
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "ONLINE", False
    4/11/2012 3:24:49 PM: Leave Exec: False, menu.skin, ONLINE, False
    4/11/2012 3:24:49 PM: Global Hotkey: Successfully registered keycode:2112
    4/11/2012 3:24:49 PM: PLAYER: Restored rrpl.m3u8
    4/11/2012 3:24:49 PM: INFO: CheckResume() - ResumeMusic=0 WasRadio=0
    4/11/2012 3:24:49 PM: INFO: LoadResume() - Reading resume data from C:\Users\Drew\Documents\RideRunner\Cache\resume.ini
    4/11/2012 3:24:49 PM: Enter Exec: False, menu.skin, , False
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "ONSKINSTART", False
    4/11/2012 3:24:49 PM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    4/11/2012 3:24:49 PM: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
    4/11/2012 3:24:50 PM: Enter Exec: False, menu.skin, , False
    4/11/2012 3:24:50 PM: Que Exec: True, menu.skin, "RM_UpdateDiskNames", False
    4/11/2012 3:24:50 PM: Leave Exec: False, menu.skin, rm_disklisting, False
    4/11/2012 3:26:44 PM: Enter Exec: False, menu.skin, "ONBTNPRESS||RRMenuItem;1", False
    4/11/2012 3:26:44 PM: Que Exec: True, menu.skin, "ONBTNPRESS||RRMenuItem;1", False
    4/11/2012 3:26:44 PM: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    4/11/2012 3:26:44 PM: Executing: PlaySound;C:\Users\Drew\Documents\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
    4/11/2012 3:26:44 PM: Que Exec: True, menu.skin, "RRMenuItem;1", False
    4/11/2012 3:26:44 PM: Executing: RRMenuItem;1
    4/11/2012 3:26:44 PM: Que Exec: True, menu.skin, "AUDIO", False
    4/11/2012 3:26:44 PM: Executing: AUDIO
    4/11/2012 3:26:44 PM: INFO: LoadResume() - Reading resume data from C:\Users\Drew\Documents\RideRunner\Cache\resume.ini
    4/11/2012 3:26:44 PM: AudPlayerStart: music player: PLPosition=0  TrackPosition=-568
    4/11/2012 3:26:44 PM: AudPlayerStart: player volume be 0: 0
    4/11/2012 3:26:45 PM: AudPlayerStart: player should be playing: PLAYING
    4/11/2012 3:26:45 PM: AudPlayerStart: Player.GetTrackLength: 268000
  7. #27
    Jan 2012
    I'm having trouble getting medialaunch (usb music) to work in the new version, Is anyone else having this trouble? works fine in last months release
  8. #28
    MySQL Error
    Oct 2004
    drewbp, please attach files (as .txt) or .zip
    i cannot deal with them embedded into the forum...
    also... i would disable all of the odd plugins...
    including any possible added to winamp
    easy way. just make a folder "plugins disabled" and copy them out of plugins
    gpslockout, inetradiolabels, rrextedned, rrmediadb...
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  9. #29
    MySQL Error
    Oct 2004
    Quote Originally Posted by Liam17 View Post
    no idea what medialaunch is... but im pretty sure issue is unrelated to rr relase...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #30
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    Just copy and paste them into notepad (notepad FTW)
    Told him that already.
  1. RR 12-17-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 12-19-2011, 11:53 AM
  2. RR 09-01-2011 Release
    Last Post: 11-21-2011, 04:25 AM
  3. RR 07-01-2011 Release
    Last Post: 10-06-2011, 08:32 PM
  4. RR 08-01-2011 Release
    Last Post: 08-28-2011, 03:41 PM
  5. Replies: 21
    Last Post: 04-01-2011, 09:59 AM
