Page 1 of 5 12345 LastLast
Results 1 to 10 of 43
Thread: RR 04-01-2012 Release
    MySQL Error
    Oct 2004
    OK, should i say we going back to the Road Runner name? i think i already used that April fools joke..
    April already? sheeze, time does fly faster the older you are!
    Download Here: http://www.nisuautomotive.com
    The biggest thing here is the Dynamic Menus, I should have done this code years ago
    removes tons of cryptic Exectbl.ini code, and allows plugins(if the plugin supports it)
    to have a menu automatically available to the user
    the dynamic menu system is completely demonstrated in the Carwings_Dyanamic_lite
    skin installed by the installer
    see the thread: http://www.mp3car.com/road-runner/15...mic-menus.html
    Highlights:
    • + Dynamic Menus
    • + Skin Object; "RG" Clickable Region - RG,x,y,w,h,"CODE"
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    3/29/2012
    + Skin Label; "ByIndX" support added.
      ex:   L,x,y,w,h,"ByIndX;indicatorcode;(false<<true)"
      ex:   L,x,y,w,h,"ByIndX;MJSG_1Wire;Adaptor;(=<<=1-Wire Installed)"
      ex:   L,x,y,w,h,"ByIndX;Online;(=Disconnected<<=Connected)"
            (shows "1-Wire Installed" when indicator "MJSG_1Wire;Adaptor" is true)
    + Skin Label; "ByVarX" support added.
      ex:   L,x,y,w,h,"ByVarX;myvar;(=Zero<<=One<<=Two<<=Three)"
    		(shows "Two" when value of UserVar "myvar" is 2)
    * Skin Label; if they are of the "ByVar, ByVarX, ByInd, ByIndX"
                  they are now correctly supported outside of a physical skin,
                  ie in skintool or other plugins.
    + Allow window targeting of the parented embedded window on the video/dvd player screen.
      ex:	sendwmcommand;!MediaPlayerClassicW!;952;0
            (would target MPC-HC and send the WM_COMMAND 952 (next audio))
    3/22/2012
    # Skin Indicator; "OverSpeed" now takes in account setting IsUnits
      (before the value was in KNOTS!)
    3/18/2012
    * Added one additional Splash screen status label status, after loading the last preloaded screen
    3/16/2012
      This is clickable anywhere at anytime(as long as rr is visable), even on top of application windows
      ex:  RG,0,0,800,20,"ESC"   creates a clickable region 800px wide x 20px high at 0,0
                                 when clicked command "ESC" is run
    + Skin Event; "ONRGNPRESS" event for "RG" clickable region command.
    3/13/2012
    # fixed iPOD database read, caused RR to freeze
    3/8/2012
    # FMPresets folder failed to create on 1st time use
    3/7/2012
    + Dynamic Menus: (see New Dynamic Menus.txt)
        Skin Command:   "RRMenuItem;x;[set]"
        Skin Label:     "RRMenuItem;x"
        Skin Indicator: "RRMenuItem;x"
        Skin Command:   "RRMenuItemSave;key;(menuitem)"
        Skin Indicator: "RRMenuItemSelIcon" shows icon(if any) of selected item in the MenuItemSet.Skin List
        User Variable:  "RRMenuItemKey"
        Skin Command:   "RRMenuNext" goes to next menuX.skin (looping)
        Skin Command:   "RRMenuPrev" goes to previous menuX.skin (looping)
    + Skin Indicator; "RRMediaInserted" is true when a disc is inserted into the media drive
      (must have some filesystem on it \ volume name)
    * Skin Command; "plginmgr" now "RRPluginMgr" (alias of "Load;pluginmgr.skin")
    3/5/2012
    + Skin Command; "CLPOS" sets selection position (1 - number of items)
    + Skin Command; "ListPos" sets selection position of current selected list (1 - number of items)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    53
    Thank you kind sir for another RR fix. What are we tackling next? If you need a tester for 6 screen support i'm your guy
    Live mp3Car Facebook Chat
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Great thanks for this new version :-)
    May 2008
    Bordeaux, France
    What is this new issue with the video option ?
    When i click on the video command that load well the video screen but also a folder where RR is installed !
    May 2008
    Bordeaux, France
    I have modified the launch path 'LaunchPath=D:\Program Files\Ride Runner\Launch' but RR try always to load calc or notepad from LaunchPath=C:\Program Files\Ride Runner\Launch and not found them .
    MySQL Error
    Oct 2004
    Quote Originally Posted by pierrotm777 View Post
    i have no idea what you're talking about, there is NOTHING new with the video option...
    i dont even know what a video option is
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    btw... you should move to profile mode, your folder looks a complete mess
    (yea, im picky i like organization!!!)
    I have set my launch path to...
    LaunchPath=E:\RRTest\Launch
    and it works fine...
    its not looking at the old location (which i temporarily renamed)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2008
    Bordeaux, France
    Quote Originally Posted by mitchjs View Post
    Sorry , i speak about the video command !
    But i don't understand why i haven't this issue now !
    All is ok now !
    May 2008
    Bordeaux, France
    For my tests (xp sp3 only), i prefer to use the normal mode and my launchpath isn't seen !
    MySQL Error
    Oct 2004
    i tested it here... and its simplistic... all it does it set the initial Directory path of the List on the skin named "launch.skin"
    hardly any code in RR related to launch path, maybe 4 lines total
    im sure u will figure it out...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 12-17-2011 Release
    By mitchjs in forum Road Runner
    Last Post: 12-19-2011, 10:53 AM
  2. RR 09-01-2011 Release
    Last Post: 11-21-2011, 03:25 AM
  3. RR 07-01-2011 Release
    Last Post: 10-06-2011, 07:32 PM
  4. RR 08-01-2011 Release
    Last Post: 08-28-2011, 02:41 PM
  5. Replies: 21
    Last Post: 04-01-2011, 08:59 AM
