Results 1 to 4 of 4
Thread: Getting crazy with an indicator
    Feb 2011
    hi all, i got a little problem and i can't find a solution
    i'm trying to make an indicator that switch ON/OFF when a cd/dvd is inside the reader, the problem is that the indicator is dinamic so i need the command if ride runner has it.
    So the problem is that i can't find the indicator under the list object.txt..i've just found:
    "CDMUTE" - CD Mute
    The question is: The command exist or have to be made manually? using "ONMEDIAINSERT" and "ONMEDIAREMOVED"
    Any suggestion is apreciated Thanks you
    MySQL Error
    Oct 2004
    all you want to know is if there is a CD in the drive?
    easy.. read history.txt
    + Skin Indicator; "RRMediaInserted" is true when a disc is inserted into the media drive
    (must have some filesystem on it \ volume name)
    note, media drive, you have to have that set too, rrconifg...
    MediaDrive=
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Feb 2011
    ahh thanks so much i think is better to read the hystory thant objects.txt
    Thanks again
    MySQL Error
    Oct 2004
    objects.txt isnt part of RR, its for skin editor, which is really a 3rd party program... while bluezx3 does update it from time to time, its FAR from perfect
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. See a second indicator if the first indicator is 'True'
    By pierrotm777 in forum Road Runner
    Last Post: 03-27-2012, 03:06 AM
  2. indicator help
    By Nomader in forum Road Runner
    Last Post: 12-06-2009, 08:59 AM
  3. EQ on-off indicator
    By Fuegomp3 in forum RR Skins
    Last Post: 11-27-2009, 11:18 AM
  4. How to IMG over INDICATOR
    By dan32500 in forum RR Skins
    Last Post: 02-28-2008, 11:20 PM
  5. Is there a Vis Indicator ?
    By CdRsKuLL in forum Road Runner
    Last Post: 02-24-2006, 03:14 AM
