Results 1 to 10 of 10
Thread: Volume randomly starts at full volume and music resumes even when set not to
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    I cannot explain this one and suspect Ride Runner, although it could be something else. It started happening a few months ago, but I also had this problem once in the past and it went away. Having the system come on at full volume is not enjoyable. I used to hibernate so it's possible this problem never went away and is resurfacing due to full system restarts.
    As a work around, I tired to set Ride Runner to not always resume music, yet it resumes playing at the main menu anyway and if I select the music button it stops playing as if Ride Runner did not fully load. This is why I suspect Ride Runner is the culprit. I even set fade in at startup to see what would happen, but it still starts playing at one volume before it does the fade in.
    I have the April version of RR
    I have tired both my Simplistque skin and Carwings, both act the same way.
    Music player is the latest winamp
    The computer is set to shutdown and restart, no hibernation, no sleep.
    Also worth mentioning, I have an autoit script that is tied to key presses and mouse wheel for volume, and I have it set the level to 10% when starting. When it does come on full volume, the second I move the volume it goes to my 10 level.
    Fusion Brain tied to my steering wheel controls also controls volume via key presses that are mapped in RR and the autoit script for OSD.
    So 1st, why does the music resume even if I have it set not to.
    2nd, is this random full volume tied to RR or my Autoit script, or something else given my explanations?
    MySQL Error
    Oct 2004
    1st off, lets assume RR doesnt try to play the music
    and the player you chose is
    this is one of the issues with RR, that it depends ALOT on 3rd party sw, ie Winamp
    ok, so rule #1 test with carwings, rule #2, review your own debug.txt, you can also ATTACH it to forum, for me to review, but you should review it yourself 1st
    so... what i would do, is REMOVE all plugins (except skintool), just copy them out of the Plugings folder, to a temp folder like Plugins Disabled
    i would then also make sure winamp has no "additional" plugins... or u could switch to say WMP as a test
    then finally disable all your other scripts, that mess with volume
    i would disable the RR option for fading volume, at least for now...
    also.. since you dont mention sound device, i wouldt be surpised if a usb sound device, did weird things...but id think they would catch that and fix their drivers
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Sep 2006
    Thanks for the suggestions, I needed another viewpoint.
    I'll try another player. I've never seen a resume auto feature built into winamp, but maybe they added it
    Then I will try debug and see what I get.
    The I will temporary move plugins
    I've already tested with cawings and it functions the same.
    I am afraid to disable the autoit script until I have ruled out other things. If volume comes on at 100% and I can't quickly trigger it to go to the low level, then my hearing will suffer.I'll try another script just to be safe.
    The soundcard is PCI (audiotrak prodigy 7.1)and it does some fancy audio processing in the VST world. This part is rock solid though and never changes levels on me.
    I'll get back after testing these.
    MySQL Error
    Oct 2004
    I'm not asking you to permanently remove/disable, just for testing... you need to narrow down issue
    you got a lot going on
    and debug.txt knows/shows all
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2006
    Quote Originally Posted by mitchjs View Post
    Indeed. Found the first problem of music resuming. You were right, I had some autoplay features enabled in winamp. I was going to post a screenshot for future reference but my home PC did not have it in winamp, only the car. I might have a few years ago installed some autoplay addon in an attempt to get my CD player to always play CD's upon insert and forgot to disable or remove it. Now that I fixed that, I don't think RR is the issue because I thought they were related, plus it came on at full again after disabling. I suspect the autoit script now, more elimination testing needed, but I will debug RR as well. It doesn't do it all the time so it's not easy to pinpoint. Will be back with more answers soon.
    Sep 2006
    Ok, so volume came on at 100% this morning. The line highlighted in red makes no sense, was it supposed to come on muted or is that indicating is was not muted when it came on? I tired a new autohotkey script for the rotary encoder tied to mousewheel, but it was givng me problems so I went back to the old one. I will disable for a few days to see what happens.
    "AudPlayerStart: player volume be 0: 0"
    Code:
    4/24/2012 6:26:46 AM: Start -- Version: 4/1/2012
    4/24/2012 6:26:46 AM: OS Type: Windows XP
    4/24/2012 6:26:46 AM: FileManager: FileMode = Legacy
    4/24/2012 6:26:46 AM: FileManager: mypath = C:\Program Files\Road Runner\
    4/24/2012 6:26:46 AM: FileManager: ProfilePath = C:\Documents and Settings\ace\My Documents\RideRunner\
    4/24/2012 6:26:46 AM: Start Sequence: Starting Player...
    4/24/2012 6:26:46 AM: PLAYER: Initialization creating object
    4/24/2012 6:26:46 AM: Winamp AudPlayer---> Attempting start of winamp.exe
    4/24/2012 6:26:46 AM: Winamp AudPlayer---> waiting for window handle
    4/24/2012 6:26:46 AM: Winamp AudPlayer---> winamp.exe started: v20578
    4/24/2012 6:26:46 AM: PLAYER: Started
    4/24/2012 6:26:46 AM: PLAYER: Winamp Version: 5.62
    4/24/2012 6:26:47 AM: PLAYER: Initialization complete
    4/24/2012 6:26:47 AM: Start Sequence: Starting Radio Device...
    4/24/2012 6:26:47 AM: Start Sequence: Starting Serial Devices...
    4/24/2012 6:26:47 AM: Start Sequence: Starting Mixer...
    4/24/2012 6:26:47 AM: Master Vol: Master Volume/4
    4/24/2012 6:26:47 AM: Master Vol reports number of channels =1
    4/24/2012 6:26:47 AM: GetLineControl Failed: 401
    4/24/2012 6:26:47 AM: No Treble Support
    4/24/2012 6:26:47 AM: No Bass Support
    4/24/2012 6:26:47 AM: No Master ON/OFF
    4/24/2012 6:26:47 AM: Source: Mixer line #1: Wave=&H1008
    4/24/2012 6:26:47 AM: Source: Mixer line #2: SW Synth=&H1004
    4/24/2012 6:26:47 AM: Source: Mixer line #3: CD Player=&H1005
    4/24/2012 6:26:47 AM: Source: Mixer line #4: Microphone=&H1003
    4/24/2012 6:26:47 AM: Source: Mixer line #5: Line=&H1002
    4/24/2012 6:26:47 AM: Source: Mixer line #6: Aux=&H100A
    4/24/2012 6:26:47 AM: Start Sequence: Starting Speech...
    4/24/2012 6:26:47 AM: DirectDraw Count: 1 - []
    4/24/2012 6:26:47 AM: Plugin Manager: loading Global Plugins...
    4/24/2012 6:26:47 AM: Plugin Manager: Plugin Found: SkinTool
    4/24/2012 6:26:47 AM: Plugin Manager: Plugin loaded (Global): SkinTool
    4/24/2012 6:26:47 AM: Plugin Manager: Plugin Found: Weather
    4/24/2012 6:26:47 AM: Plugin Manager: Plugin loaded (Global): Weather
    4/24/2012 6:26:47 AM: Plugin Manager: loading Global Plugins Completed.
    4/24/2012 6:26:47 AM: LoadSkin: C:\Program Files\Road Runner\Skins\GF-Simplistique_white\
    4/24/2012 6:26:47 AM: Plugin Manager: loading SkinDir Plugins...
    4/24/2012 6:26:47 AM: Plugin Manager: loading SkinDir Plugins Completed.
    4/24/2012 6:26:48 AM: Enter Exec: False, menu.skin, "ONRESTORED", False
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "ONRESTORED", False
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "ONSTART", False
    4/24/2012 6:26:48 AM: Leave Exec: False, menu.skin, ONSTART, False
    4/24/2012 6:26:48 AM: PLAYER: Restored rrpl.m3u8
    4/24/2012 6:26:48 AM: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    4/24/2012 6:26:48 AM: INFO: LoadResume() - Reading resume data from C:\Program Files\Road Runner\resume.ini
    4/24/2012 6:26:48 AM: AudPlayerStart: music player: PLPosition=3  TrackPosition=169801
    4/24/2012 6:26:48 AM: AudPlayerStart: player volume be 0: 0
    4/24/2012 6:26:48 AM: AudPlayerStart: player should be playing: PLAYING
    4/24/2012 6:26:48 AM: AudPlayerStart: Player.GetTrackLength: 261000
    4/24/2012 6:26:48 AM: AudPlayerStart: Player.SetTrackPosition: 169801
    4/24/2012 6:26:48 AM: INFO: CheckResume() - Resuming to music player: PLAYING
    4/24/2012 6:26:48 AM: Enter Exec: False, menu.skin, , False
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "ONSKINSTART", False
    4/24/2012 6:26:48 AM: EXECTBL Translation: ONSKINSTART -> SetApps||SetCommandLabels01||SetAppLabels||$default$
    4/24/2012 6:26:48 AM: Executing: SetApps
    4/24/2012 6:26:48 AM: Command not executed: SetApps
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "ONCOMMANDINVALID", False
    4/24/2012 6:26:48 AM: Executing: ONCOMMANDINVALID
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "SetCommandLabels01||SetAppLabels||$default$", False
    4/24/2012 6:26:48 AM: Executing: SetCommandLabels01
    4/24/2012 6:26:48 AM: Command not executed: SetCommandLabels01
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "SetAppLabels||$default$", False
    4/24/2012 6:26:48 AM: Executing: SetAppLabels
    4/24/2012 6:26:48 AM: Command not executed: SetAppLabels
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "$default$", False
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "ONSOURCECHANGE", False
    4/24/2012 6:26:48 AM: Leave Exec: False, menu.skin, ONSOURCECHANGE, False
    4/24/2012 6:26:48 AM: Que Exec: True, menu.skin, "ONSONGSTART", False
    4/24/2012 6:26:48 AM: Leave Exec: False, menu.skin, ONSONGSTART, False
    4/24/2012 6:27:18 AM: Enter Exec: False, menu.skin, , False
    4/24/2012 6:27:18 AM: Que Exec: True, menu.skin, "ONLINE", False
    4/24/2012 6:27:18 AM: Leave Exec: False, menu.skin, ONLINE, False
    4/24/2012 6:28:19 AM: Enter Exec: False, menu.skin, , False
    4/24/2012 6:28:19 AM: Que Exec: True, menu.skin, "ONSONGSTART", False
    4/24/2012 6:28:19 AM: Leave Exec: False, menu.skin, ONSONGSTART, False
    4/24/2012 6:29:31 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||AUDIO", False
    4/24/2012 6:29:31 AM: Que Exec: True, menu.skin, "ONBTNPRESS||AUDIO", False
    4/24/2012 6:29:31 AM: Que Exec: True, menu.skin, "AUDIO", False
    4/24/2012 6:29:31 AM: Executing: AUDIO
    4/24/2012 6:29:31 AM: Que Exec: True, audio_player.skin, "ONSCREENCHANGE", False
    4/24/2012 6:29:31 AM: Leave Exec: False, audio_player.skin, ONSCREENCHANGE, False
    4/24/2012 6:30:04 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:30:04 AM: Que Exec: True, audio_player.skin, "OFFLINE", False
    4/24/2012 6:30:04 AM: Leave Exec: False, audio_player.skin, OFFLINE, False
    4/24/2012 6:31:39 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:31:39 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:31:39 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:35:43 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:35:43 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:35:43 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:36:30 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:36:30 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:36:30 AM: Executing: rrnext
    4/24/2012 6:36:30 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:36:31 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:36:31 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:36:31 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:36:31 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:36:31 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:36:31 AM: Executing: rrnext
    4/24/2012 6:36:31 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:39:46 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:39:46 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:39:46 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:39:49 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:39:49 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:39:49 AM: Executing: rrnext
    4/24/2012 6:39:49 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:39:49 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:39:49 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:39:49 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:39:52 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:39:52 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:39:52 AM: Executing: rrnext
    4/24/2012 6:39:52 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:39:53 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:39:53 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:39:53 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:39:56 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:39:56 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:39:56 AM: Executing: rrnext
    4/24/2012 6:39:56 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:39:56 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:39:56 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:39:56 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:39:57 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:39:57 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:39:57 AM: Executing: rrnext
    4/24/2012 6:39:57 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:39:58 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:39:58 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:39:58 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:40:06 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:40:06 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:40:06 AM: Executing: rrnext
    4/24/2012 6:40:06 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:40:06 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:40:06 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:40:06 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:40:08 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:40:08 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:40:08 AM: Executing: rrnext
    4/24/2012 6:40:08 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:40:08 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:40:08 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:40:08 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:44:21 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:44:21 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:44:21 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:44:23 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:44:23 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:44:23 AM: Executing: rrnext
    4/24/2012 6:44:23 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:44:23 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:44:23 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:44:23 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:44:27 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:44:27 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:44:27 AM: Executing: rrnext
    4/24/2012 6:44:27 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:44:27 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:44:27 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:44:27 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:47:36 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:47:36 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:47:36 AM: Executing: rrnext
    4/24/2012 6:47:36 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:47:36 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:47:36 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:47:36 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:51:39 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:51:39 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:51:39 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:55:31 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:55:31 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:55:31 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 6:57:15 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 6:57:15 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 6:57:15 AM: Executing: rrnext
    4/24/2012 6:57:15 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 6:57:16 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 6:57:16 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 6:57:16 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:00:30 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:00:30 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:00:30 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:01:06 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:01:06 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:01:06 AM: Executing: rrnext
    4/24/2012 7:01:06 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:01:06 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:01:06 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:01:06 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:05:59 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:05:59 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:05:59 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:06:50 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:06:50 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:06:50 AM: Executing: rrnext
    4/24/2012 7:06:50 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:06:50 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:06:50 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:06:50 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:06:52 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:06:52 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:06:52 AM: Executing: rrnext
    4/24/2012 7:06:52 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:06:52 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:06:52 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:06:52 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:10:34 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:10:34 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:10:34 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:11:01 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:11:01 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:11:01 AM: Executing: rrnext
    4/24/2012 7:11:01 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:11:01 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:11:01 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:11:01 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:11:02 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:11:02 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:11:02 AM: Executing: rrnext
    4/24/2012 7:11:02 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:11:02 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:11:02 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:11:02 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:14:38 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:14:38 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:14:38 AM: Executing: rrnext
    4/24/2012 7:14:38 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:14:39 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:14:39 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:14:39 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:14:39 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:14:39 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:14:39 AM: Executing: rrnext
    4/24/2012 7:14:39 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:14:40 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:14:40 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:14:40 AM: Executing: rrnext
    4/24/2012 7:14:41 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:14:41 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:14:41 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:14:41 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:14:42 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:14:42 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:14:42 AM: Executing: rrnext
    4/24/2012 7:14:42 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:14:42 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:14:42 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:14:42 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:14:43 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:14:43 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:14:43 AM: Executing: rrnext
    4/24/2012 7:14:43 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:14:43 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:14:43 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:14:43 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:14:46 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:14:46 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:14:46 AM: Executing: rrnext
    4/24/2012 7:14:47 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:14:47 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:14:47 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:14:47 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:18:04 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:18:04 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:18:04 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:18:45 AM: Enter Exec: False, audio_player.skin, "mute", False
    4/24/2012 7:18:45 AM: Que Exec: True, audio_player.skin, "mute", False
    4/24/2012 7:18:45 AM: Executing: mute
    4/24/2012 7:18:45 AM: Leave Exec: False, audio_player.skin, mute, False
    4/24/2012 7:18:53 AM: Enter Exec: False, audio_player.skin, "mute", False
    4/24/2012 7:18:53 AM: Que Exec: True, audio_player.skin, "mute", False
    4/24/2012 7:18:53 AM: Executing: mute
    4/24/2012 7:18:53 AM: Leave Exec: False, audio_player.skin, mute, False
    4/24/2012 7:20:13 AM: Enter Exec: False, audio_player.skin, "ONLBLPRESS", False
    4/24/2012 7:20:13 AM: Que Exec: True, audio_player.skin, "ONLBLPRESS", False
    4/24/2012 7:20:13 AM: Leave Exec: False, audio_player.skin, ONLBLPRESS, False
    4/24/2012 7:20:16 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||MINIMIZE", False
    4/24/2012 7:20:16 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||MINIMIZE", False
    4/24/2012 7:20:16 AM: Que Exec: True, audio_player.skin, "MINIMIZE", False
    4/24/2012 7:20:16 AM: Executing: MINIMIZE
    4/24/2012 7:20:16 AM: Enter Exec: True, audio_player.skin, "ONMINIMIZED", False
    4/24/2012 7:20:16 AM: Queued: "ONMINIMIZED"
    4/24/2012 7:20:16 AM: Que Exec: True, audio_player.skin, "ONMINIMIZED", False
    4/24/2012 7:20:16 AM: Executing: ONMINIMIZED
    4/24/2012 7:20:16 AM: Leave Exec: False, audio_player.skin, ONMINIMIZED, False
    4/24/2012 7:20:36 AM: Enter Exec: False, audio_player.skin, "ONRESTORED", False
    4/24/2012 7:20:36 AM: Que Exec: True, audio_player.skin, "ONRESTORED", False
    4/24/2012 7:20:36 AM: Leave Exec: False, audio_player.skin, ONRESTORED, False
    4/24/2012 7:21:14 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:21:14 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:21:14 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:24:41 AM: Enter Exec: False, audio_player.skin, "rrnext", False
    4/24/2012 7:24:41 AM: Que Exec: True, audio_player.skin, "rrnext", False
    4/24/2012 7:24:41 AM: Executing: rrnext
    4/24/2012 7:24:41 AM: Leave Exec: False, audio_player.skin, rrnext, False
    4/24/2012 7:24:41 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:24:41 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:24:41 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:26:34 AM: Enter Exec: False, audio_player.skin, "mute", False
    4/24/2012 7:26:34 AM: Que Exec: True, audio_player.skin, "mute", False
    4/24/2012 7:26:34 AM: Executing: mute
    4/24/2012 7:26:34 AM: Leave Exec: False, audio_player.skin, mute, False
    4/24/2012 7:27:48 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    4/24/2012 7:27:48 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    4/24/2012 7:27:48 AM: Que Exec: True, audio_player.skin, "PLAY", False
    4/24/2012 7:27:48 AM: EXECTBL Translation: PLAY -> PLAY||SETUPANTISTATUS
    4/24/2012 7:27:48 AM: Executing: PLAY
    4/24/2012 7:27:48 AM: Que Exec: True, audio_player.skin, "SETUPANTISTATUS", False
    4/24/2012 7:27:48 AM: EXECTBL Translation: SETUPANTISTATUS -> SETVARBYCODE;VSTATUS;STATUS||EVAL;B_ANTISTATUS;strcomp("PLAY";"$VSTATUS$")||BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING
    4/24/2012 7:27:48 AM: Executing: SETVARBYCODE;VSTATUS;STATUS
    4/24/2012 7:27:48 AM: Que Exec: True, audio_player.skin, "EVAL;B_ANTISTATUS;strcomp("PLAY";"$VSTATUS$")||BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING", False
    4/24/2012 7:27:48 AM: Executing: EVAL;B_ANTISTATUS;strcomp("PLAY";"PAUSE")
    4/24/2012 7:27:48 AM: Que Exec: True, audio_player.skin, "BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING", False
    4/24/2012 7:27:48 AM: Executing: BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING
    4/24/2012 7:27:48 AM: Que Exec: True, audio_player.skin, "ISNTPLAYING", False
    4/24/2012 7:27:48 AM: EXECTBL Translation: ISNTPLAYING -> SETVAR;ANTISTATUS;PLAY||SETVAR;STATUSSYM;1
    4/24/2012 7:27:48 AM: Executing: SETVAR;ANTISTATUS;PLAY
    4/24/2012 7:27:48 AM: Que Exec: True, audio_player.skin, "SETVAR;STATUSSYM;1", False
    4/24/2012 7:27:48 AM: Executing: SETVAR;STATUSSYM;1
    4/24/2012 7:27:48 AM: Leave Exec: False, audio_player.skin, SETVAR;STATUSSYM;1, False
    4/24/2012 7:27:49 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||PLAY", False
    4/24/2012 7:27:49 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||PLAY", False
    4/24/2012 7:27:49 AM: Que Exec: True, audio_player.skin, "PLAY", False
    4/24/2012 7:27:49 AM: EXECTBL Translation: PLAY -> PLAY||SETUPANTISTATUS
    4/24/2012 7:27:49 AM: Executing: PLAY
    4/24/2012 7:27:49 AM: Que Exec: True, audio_player.skin, "SETUPANTISTATUS", False
    4/24/2012 7:27:49 AM: EXECTBL Translation: SETUPANTISTATUS -> SETVARBYCODE;VSTATUS;STATUS||EVAL;B_ANTISTATUS;strcomp("PLAY";"$VSTATUS$")||BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING
    4/24/2012 7:27:49 AM: Executing: SETVARBYCODE;VSTATUS;STATUS
    4/24/2012 7:27:49 AM: Que Exec: True, audio_player.skin, "EVAL;B_ANTISTATUS;strcomp("PLAY";"$VSTATUS$")||BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING", False
    4/24/2012 7:27:49 AM: Executing: EVAL;B_ANTISTATUS;strcomp("PLAY";"PLAY")
    4/24/2012 7:27:49 AM: Que Exec: True, audio_player.skin, "BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING", False
    4/24/2012 7:27:49 AM: Executing: BYVAR;B_ANTISTATUS;ISNTPLAYING<<ISPLAYING
    4/24/2012 7:27:49 AM: Que Exec: True, audio_player.skin, "ISPLAYING", False
    4/24/2012 7:27:49 AM: EXECTBL Translation: ISPLAYING -> SETVAR;ANTISTATUS;PAUSE||SETVAR;STATUSSYM;0
    4/24/2012 7:27:49 AM: Executing: SETVAR;ANTISTATUS;PAUSE
    4/24/2012 7:27:49 AM: Que Exec: True, audio_player.skin, "SETVAR;STATUSSYM;0", False
    4/24/2012 7:27:49 AM: Executing: SETVAR;STATUSSYM;0
    4/24/2012 7:27:49 AM: Leave Exec: False, audio_player.skin, SETVAR;STATUSSYM;0, False
    4/24/2012 7:27:50 AM: Enter Exec: False, audio_player.skin, , False
    4/24/2012 7:27:50 AM: Que Exec: True, audio_player.skin, "ONSONGSTART", False
    4/24/2012 7:27:50 AM: Leave Exec: False, audio_player.skin, ONSONGSTART, False
    4/24/2012 7:27:50 AM: Enter Exec: False, audio_player.skin, "ONBTNPRESS||EXIT", False
    4/24/2012 7:27:50 AM: Que Exec: True, audio_player.skin, "ONBTNPRESS||EXIT", False
    4/24/2012 7:27:50 AM: Que Exec: True, audio_player.skin, "EXIT", False
    4/24/2012 7:27:50 AM: Executing: EXIT
    4/24/2012 7:27:50 AM: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    4/24/2012 7:27:51 AM: Que Exec: True, menu.skin, "ONSCREENCHANGE", False
    4/24/2012 7:27:51 AM: Leave Exec: False, menu.skin, ONSCREENCHANGE, False
    4/24/2012 7:27:52 AM: Enter Exec: False, menu.skin, "ONBTNPRESS||LOAD;exit_menu.skin||run;$skinpath$Support\\Rain600_Simpel\Rainlendar.exe", False
    4/24/2012 7:27:52 AM: Que Exec: True, menu.skin, "ONBTNPRESS||LOAD;exit_menu.skin||run;$skinpath$Support\\Rain600_Simpel\Rainlendar.exe", False
    4/24/2012 7:27:52 AM: Que Exec: True, menu.skin, "LOAD;exit_menu.skin||run;$skinpath$Support\\Rain600_Simpel\Rainlendar.exe", False
    4/24/2012 7:27:52 AM: Executing: LOAD;exit_menu.skin
    4/24/2012 7:27:52 AM: Que Exec: True, exit_menu.skin, "ONSCREENCHANGE", False
    4/24/2012 7:27:52 AM: Que Exec: True, exit_menu.skin, "run;$skinpath$Support\\Rain600_Simpel\Rainlendar.exe", False
    4/24/2012 7:27:52 AM: Executing: run;C:\Program Files\Road Runner\Skins\GF-Simplistique_white\Support\\Rain600_Simpel\Rainlendar.exe
    4/24/2012 7:27:52 AM: Shell: "C:\Program Files\Road Runner\Skins\GF-Simplistique_white\Support\\Rain600_Simpel\Rainlendar.exe"
    4/24/2012 7:27:53 AM: Leave Exec: False, exit_menu.skin, run;C:\Program Files\Road Runner\Skins\GF-Simplistique_white\Support\\Rain600_Simpel\Rainlendar.exe, False
    4/24/2012 7:27:53 AM: Enter Exec: False, exit_menu.skin, "ONBTNPRESS||QUIT", False
    4/24/2012 7:27:53 AM: Que Exec: True, exit_menu.skin, "ONBTNPRESS||QUIT", False
    4/24/2012 7:27:53 AM: Que Exec: True, exit_menu.skin, "QUIT", False
    4/24/2012 7:27:53 AM: EXECTBL Translation: QUIT -> SendMsg;RRCDRip;showplugin||bye
    4/24/2012 7:27:53 AM: Executing: SendMsg;RRCDRip;showplugin
    4/24/2012 7:27:53 AM: Que Exec: True, exit_menu.skin, "bye", False
    4/24/2012 7:27:53 AM: EXECTBL Translation: bye -> QUIT
    4/24/2012 7:27:53 AM: Executing: QUIT
    4/24/2012 7:27:53 AM: Enter Exec: False, exit_menu.skin, "ONEXIT", False
    4/24/2012 7:27:53 AM: Que Exec: True, exit_menu.skin, "ONEXIT", False
    4/24/2012 7:27:53 AM: Leave Exec: False, exit_menu.skin, ONEXIT, False
    4/24/2012 7:27:53 AM: Shutdown: (1)
    4/24/2012 7:27:53 AM: Shutdown: (2)
    4/24/2012 7:27:53 AM: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    4/24/2012 7:27:53 AM: Shutdown: (3)
    4/24/2012 7:27:53 AM: Shutdown: (4)
    4/24/2012 7:27:53 AM: INFO: LoadResume() - Reading resume data from C:\Program Files\Road Runner\resume.ini
    4/24/2012 7:27:53 AM: Plugin Manager: Warning Plugin skintool does not support Terminate Method
    4/24/2012 7:27:53 AM: Plugin Manager: Warning Plugin weather does not support Terminate Method
    4/24/2012 7:27:53 AM: Plugin Manager: ALL Plugins unloaded.
    4/24/2012 7:27:54 AM: Shutdown: (5)
    4/24/2012 7:27:54 AM: Player is running
    4/24/2012 7:27:54 AM: Winamp AudPlayer---> Closing...
    4/24/2012 7:27:54 AM: Shutdown: (6)
    4/24/2012 7:27:54 AM: Shutdown: (7)
    4/24/2012 7:27:54 AM: OSUnloadMode: 1
    4/24/2012 7:27:54 AM: Global Hotkey: All keys unregistered
    Attached Files Attached Files
    MySQL Error
    Oct 2004
    that is correct, that is the PLAYER volume, nothing to do with the WINDOWS MASTER VOLUME
    and its set to 0, during track positioning...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Sep 2006
    Ok so I am really scratching my head. I set RR to not resume music so I could test the full volume issue. When I got it to restart and set the volume at 100%, (tested by pressing play/pause quickly) RR reported volume set at 10%, windows volume control showed master set at 10% and the driver control panel for the soundcard was also set at 10%. My autohotkey script I have is set the default to 10% because I think long ago it was coming on at full volume all the time. What in the world am I missing here? If all sliders show 10%, what am I missing or how is this even possible?
    In control panel I found that the onboard soundcard driver was installed (maybe from a recent chipest driver install), so I removed that. It's already disabled in BIOS. Then I found 2 extra Road Runner versions installed from 2008, one was Road Runner, the other was a Ride Runner 2008. Removed both of those and then had to re-install the April 2012 RR. Thought that would explain why sometimes I get two instances of RR that startup. I have not had a full volume startup since but the multiple instance RR still happens. I am only mentioning this in case it has any effect. I might try unistalling RR completely and then reinstall.
    MySQL Error
    Oct 2004
    you are seing "RoadRunner.exe" run, with "RideRunner.exe" thats for OLD 3rd party software that targeted "RoadRunner" window
    (prob nothing today does...)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    your volume could just be a driver/hardware issue...
    if the windows MASTER is 10% thats what RR will show.. RR only talks to the windows mixer API
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. HDRadio always starts with the volume muted
    By cruiser in forum BoomzBox HD
    Last Post: 06-16-2010, 12:16 PM
  2. Music volume vs general volume
    By flatproblem in forum Centrafuse
    Last Post: 03-27-2009, 05:16 AM
  3. Grand Cherokee Full Volume
    By mrhonnesty99 in forum Car Audio
    Last Post: 08-16-2007, 01:03 PM
  4. Volume hits 53% then starts over?
    By noreason in forum Centrafuse
    Last Post: 02-20-2006, 04:44 PM
  5. Volume in Full screen mode
    By pijo1971 in forum FrodoPlayer
    Last Post: 05-11-2005, 08:45 AM
