Results 1 to 7 of 7
Thread: WINAMPEQ not working?
    May 2005
    Rochester, NH
    Perhaps I'm using it wrong but I cannot get "WINAMPEQ" to toggle the eq/preamp on and off. If I send the command from skinner tool I get: "Command Not Executed: WINAMPEQ". Is there a setting on my machine? Both my dev machine and the car machine don't seem to work. "AUTOEQ" does work though for example. And yes, I am using carwings.
    MySQL Error
    Oct 2004
    OBSOLETE command, since its its player specific "Winxxxx"
    "PlayerEQ" is the proper command
    from history...
    2/12/2012
    # Skin Command/Indicator "PlayerEQ" correctly toggles player EQ on/off, and shows correct state.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2005
    Rochester, NH
    Thanks. Suav used it in the Elite skin and I only searched the skin command file. Probably should get removed if it no longer works. Now to fix the indicator that doesn't work either.
    Actually, seems like "WINAMPPREAMPMUTE" which is used in the elite skin and listed in the skincommands doesn't work either. It returns false no matter what state the preamp/eq is in. Is there a new command for this indicator?
    MySQL Error
    Oct 2004
    there is no such function as winamp preamp mute... it never did anything, and is removed, see history.txt
    ALWAYS READ HISTORY.txt, the skin commands text file isnt always updated..
    still looking for that volunteer to completely take over RR documentation
    usually when people post a command/label/indicator, 1st place i go to is history.txt
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2005
    Rochester, NH
    OK. Is there any way to determine if the preamp/eq is on or off?
    MySQL Error
    Oct 2004
    yes... the indicator "PlayerEQ" , btw its also a clickable indicator... ie you dont need a button with that command on it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    May 2005
    Rochester, NH
    NICE! Thanks mitchjs!
  1. Is XM Working?
    By veetid in forum Centrafuse
    Last Post: 03-14-2007, 10:00 PM
  2. so how do i get the xm working
    By djurchicprelude in forum Car Audio
    Last Post: 04-19-2006, 03:21 PM
  3. working with ABS
    By panelrodder_81 in forum Fabrication
    Last Post: 09-22-2005, 06:23 PM
  4. ubs cable working outside not working in car
    By 00christian00 in forum Newbie
    Last Post: 07-25-2005, 12:47 PM
  5. TS working... not working... work... not...
    By bulgogi777 in forum General Hardware Discussion
    Last Post: 01-11-2005, 10:25 AM
