i'm using mobile opera it's possible to support also the flash on it, it's perfect in my opinion
(is possible to see youtube, go to any website view them in mobile and desktop mode and is touch friendly)
Didn't Sonic start a chrome plugin?
Thanks Mitch
I like "TRACKNAME" because I have some songs with no id3tag..
A 'WebKit' for Chrome exist !
With it's possible to create a web form with chrome and not ie.
But i have tried to use this webkit that run very well with an exe but not into a plugin .
I suppose that my issue is that the webkit use the framework 4.0 and RR accept only 2.0,3.0 and 3.5 !
Since updating or a coincidence, RR is opening two separate instances of Winamp. Tried with Carwings Dynamic Lite and DFX5. Even if i close one instance trying to play any music hangs and crashes RR. Any ideas? This is a fresh install of RR 5-01-2012
Cross posting issue? Tisk...Tisk![]()
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
keep in mind, plugins use winamp too, my web radio uses it own instance, so does i believe shoutcast plugin, and maybe the pandora plugin
and RR will use 2 instances, if your using the winamp line in plugin... say for xmradio or hdradio...
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
I have always an indicators issue when i use a lot of indicator into the same screens !
I have an indicator that is displayed on the bad indicators:
This is my screen example:
[INDICATORS]
I have found a solution (i think) that is to delete several indicators and add it into an include file text!I01,267,10,53,53,"GMAPS_LIST_EXIST",,,"Indicators\ gmaps_itn_*.png"
I02,581,16,37,37,"ONLINE",,,"Indicators\online_*.p ng"
I03,630,14,30,42,"MOBILEPHONE_CONNECTED",,,"Indica tors\bt_*.png"
I04,518,10,48,48,"GMAPS_GPSOK",,,"Indicators\gpsok _*.png"
I05,736,191,44,40,"GMAPS_MOBILEPHONEOK",,,"Indicat ors\mobilephone_*.png"
I06,555,199,90,25,"GMAPS_CLIPBOARDOK",,,"Indicator s\sendtorr_*.png"
I07,663,193,54,36,"GMAPS_SKYPEOK",,,"Indicators\sk ype_*.png"
I08,7,544,62,53,"MUTE:b",1000,500,""
I09,667,409,64,18,"GMAPS_GPSCOOROK:b",,,""
I10,730,409,64,18,"GMAPS_GPSITINERYOK:b",,,""
I11,614,435,39,39,"GMAPS_VARTYPETOSEND",,,"Indicat ors\gmapsvartypetosend_*.png"
I12,608,486,52,9,"GMAPS_TIMERS:b",1000,500,""
I,567,367,32,27,"gmaps_trafficlayer",,,"Indicators \traffic_*.png"
I,626,367,32,27,"gmaps_bikelayer",,,"Indicators\bi cycle_*.png"
I,685,367,32,27,"gmaps_weatherlayer",,,"Indicators \temperature_*.png"
I,744,367,32,27,"gmaps_cloudlayer",,,"Indicators\c loud_*.png"
I,567,408,32,27,"gmaps_panoramiolayer",,,"Indicato rs\panoramio_*.png"
I,567,438,32,27,"gmaps_wikipedialayer",,,"Indicato rs\wikipedia_*.png"
I,567,468,32,27,"gmaps_youtubelayer",,,"Indicators \youtube_*.png"
I13,426,502,27,27,"***",,,"Indicators\gmapsvartype tosend_00.png"
INC,RRGoogleMapsTools_Ind.txt
This is a RR bug ?I,567,367,32,27,"gmaps_trafficlayer",,,"Indicators \traffic_*.png"
Good evening
THE command "DAYNIGHTGAMMASKIN" does not work for some versions.
If RR is used bloccarre ago and you have to close it to unlock it.
The commands "DAYGAMMA" and "NIGHTGAMMA" work fine.
Buonasera
IL comando "DAYNIGHTGAMMASKIN" non funziona da un pò di versioni.
Se viene utilizzato fà bloccarre RR e bisogna chiuderlo per sbloccarlo.
I comandi "DAYGAMMA" e "NIGHTGAMMA" funzionano benissimo.
