your really not suppling any real information to help us, help you
if you want, attach rr.ini (removing reg info), attach debug.txt of 1 session
also, pcnavigation.exe is NOT "PC_Navigator.exe" so i have no idea what that is
Printable View
on another note i have made few improvements to RR to support PC Navigator
1. proper closing of app
2. rrconfig automation
RR build 8/7 or >
Hi Mitch
I cant get it to work under xp sp3
I get the default windows "Navigator has encountered a problem" send/dont send report dialog
the debug log has
8/8/2012 11:39:30 AM: Shell: "C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc' --window_position=
8/8/2012 11:39:30 AM: Que Exec: True, external_gps.skin, "ONSCREENCHANGE", False
8/8/2012 11:39:30 AM: Leave Exec: False, external_gps.skin, ONSCREENCHANGE, False
full debug.txt file attached
rr.ini
[Navigation]
GPSMode=2
GPSPath=C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe|--atlas='C:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc'
GPSName=!BarneyMainWndCls!Navigator
Ive compared the navigator shortcut (which works fine from the desktop) with the debug log entry and cant see any typo's
cheers
Wozza
Ps
Ive also attched the error log that XP wants to send home ...not that its much use
If i can help, these are my settings:
exectbl.ini:
/ Pc Navigator 11
"PC_NAVIGATOR11","SETVAR;QUOTES;"||Load;external_g ps.skin;Pc Navigator;C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe$QU OTES$ --atlas='D:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc' --window_border=no --window_position=0,73,800,453;Navigator"
menu.lst:
PC_NAVIGATOR 11 = "PC_NAVIGATOR11",PC NAVIGATOR11,Icons\PCNAVIGATOR.png,,Pc Navigator 11 is selected
or just create a button with:
PC_NAVIGATOR11
wozza here is mine
8/8/2012 9:44:32 AM: Executing: GPS
8/8/2012 9:44:32 AM: Shell: "C:\Program Files (x86)\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\ProgramData\Navigator\11.0\atlas_pcn_fre e.idc' --window_position=2,74,797,470
8/8/2012 9:44:32 AM: Que Exec: True, external_gps.skin, "ONSCREENCHANGE", False
notice real window positions
so.. the "A"pplication definition on the sklin?
you know the RULE, TEST WITH CARWINGS!
your skin could be missing something in "external_gps.skin"
Hi Mitch
Yeah it runs fine in the April ver and stand alone.I tried it with your window name and same thing... failed to run....Its got me stumped whats wrong as its the program itself thats failing, so it has to have something o do with how the command is being sent from RR.I havnt tried the carwings skin (its not even installed :) ) so I suppose that will be next.
Also where do you enter the windows position? I didnt see it in you example above
Wozza
PS tried the default skin carwings and same error :( has to be a typo in there somewhere (but Ill be if I can see one)......or the window position
the window position comes form the SKIN
the "A" definition
it just works...
u should be using the newest RR
