Page 3 of 7 FirstFirst 1234567 LastLast
Results 21 to 30 of 69
Thread: Navigator 11 from Mapfactor
  1. #21
    MySQL Error
    Oct 2004
    Quote Originally Posted by bondango View Post
    Not working here (WIN7) (all paths correct), note :-
    1. When nav button clicked, i overserved in task manager pcnavigation.exe running for a second or two
    2. If already running PC NAV, it shows in RR nav though Partial screen
    so PCNAV is not being executed properly or being blocked from launching
    your really not suppling any real information to help us, help you
    if you want, attach rr.ini (removing reg info), attach debug.txt of 1 session
    also, pcnavigation.exe is NOT "PC_Navigator.exe" so i have no idea what that is
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #22
    MySQL Error
    Oct 2004
    on another note i have made few improvements to RR to support PC Navigator
    1. proper closing of app
    2. rrconfig automation
    RR build 8/7 or >
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  3. #23
    Apr 2012
    Radelaide South Aus
    Hi Mitch
    I cant get it to work under xp sp3
    I get the default windows "Navigator has encountered a problem" send/dont send report dialog
    the debug log has
    8/8/2012 11:39:30 AM: Shell: "C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc' --window_position=
    8/8/2012 11:39:30 AM: Que Exec: True, external_gps.skin, "ONSCREENCHANGE", False
    8/8/2012 11:39:30 AM: Leave Exec: False, external_gps.skin, ONSCREENCHANGE, False
    full debug.txt file attached
    rr.ini
    [Navigation]
    GPSMode=2
    GPSPath=C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe|--atlas='C:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc'
    GPSName=!BarneyMainWndCls!Navigator
    Ive compared the navigator shortcut (which works fine from the desktop) with the debug log entry and cant see any typo's
    cheers
    Wozza
    Ps
    Ive also attched the error log that XP wants to send home ...not that its much use
    Attached Files Attached Files
  4. #24
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    If i can help, these are my settings:
    exectbl.ini:
    / Pc Navigator 11
    "PC_NAVIGATOR11","SETVAR;QUOTES;"||Load;external_g ps.skin;Pc Navigator;C:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe$QU OTES$ --atlas='D:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc' --window_border=no --window_position=0,73,800,453;Navigator"
    menu.lst:
    PC_NAVIGATOR 11 = "PC_NAVIGATOR11",PC NAVIGATOR11,Icons\PCNAVIGATOR.png,,Pc Navigator 11 is selected
    or just create a button with:
    PC_NAVIGATOR11
  5. #25
    MySQL Error
    Oct 2004
    Quote Originally Posted by Wozza View Post
    Hi Mitch
    the debug log has
    rr.ini
    [Navigation]
    GPSMode=2
    cheers
    Wozza
    Ps
    i dont see much, othet that window postion cut off in log... (if its cut off in real use, that could explain the program crashing)
    also... the window class is quite differnt then what i found...
    pc navigator works stand alone right?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #26
    MySQL Error
    Oct 2004
    wozza here is mine
    8/8/2012 9:44:32 AM: Executing: GPS
    8/8/2012 9:44:32 AM: Shell: "C:\Program Files (x86)\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\ProgramData\Navigator\11.0\atlas_pcn_fre e.idc' --window_position=2,74,797,470
    8/8/2012 9:44:32 AM: Que Exec: True, external_gps.skin, "ONSCREENCHANGE", False
    notice real window positions
    so.. the "A"pplication definition on the sklin?
    you know the RULE, TEST WITH CARWINGS!
    your skin could be missing something in "external_gps.skin"
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #27
    MySQL Error
    Oct 2004
    Quote Originally Posted by pierrotm777 View Post
    exectbl.ini:
    / Pc Navigator 11
    menu.lst:
    PC_NAVIGATOR11
    naw, too much junk in exectbl.ini
    im anti exectlb
    try out the new rr 8/7 btw.. and the new rrconfig, has pc navigator option
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #28
    Apr 2012
    Radelaide South Aus
    Hi Mitch
    Yeah it runs fine in the April ver and stand alone.I tried it with your window name and same thing... failed to run....Its got me stumped whats wrong as its the program itself thats failing, so it has to have something o do with how the command is being sent from RR.I havnt tried the carwings skin (its not even installed ) so I suppose that will be next.
    Also where do you enter the windows position? I didnt see it in you example above
    Wozza
  9. #29
    Apr 2012
    Radelaide South Aus
    PS tried the default skin carwings and same error has to be a typo in there somewhere (but Ill be if I can see one)......or the window position
  10. #30
    MySQL Error
    Oct 2004
    the window position comes form the SKIN
    the "A" definition
    it just works...
    u should be using the newest RR
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Mapfactor PC Navigator in CentraFuse?
    By GreenBeauty in forum GPS
    Last Post: 11-09-2013, 04:32 PM
  2. Mapfactor Navigator 7 COM port Error
    By markieb in forum GPS
    Last Post: 12-12-2007, 05:41 AM
  3. Replies: 1
    Last Post: 10-19-2007, 10:55 PM
  4. MapFactor OCX
    By carmen2007 in forum GPS
    Last Post: 06-23-2007, 08:23 AM
  5. Mapfactor Navigator 6
    By Naesstrom in forum Road Runner
    Last Post: 03-02-2007, 08:50 PM
