Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 52
Thread: Navigator 11 from Mapfactor
  1. #31
    Constant Bitrate besjr69's Avatar
    Feb 2011
    Mitch,
    I am only able to get PC Navigator 11 to run and embed only after I run the program first then start Riderunner. When I attempt to run it through RR pops up to an all white screen then it disappears and shows the external_gps.skin with no Navigation window. The task manager shows the program load and immediately closes. Below are my settings:
    [Navigation]
    GPSMode=2
    GPSPath=C:\Program Files (x86)\Navigator11\PC_Navigator\PC_Navigator.exe|--atlas='C:\ProgramData\Navigator\11.0\atlas_pcn_fre e.idc'
    GPSName=!MPFCWindow!Navigator
    The skin used is the Carwings_Dynamic_Lite. Another note is that it does not close the Navigation window when you exit RR as with iGuidance and GMPC. What am I doing wrong?
    Bobby
    PS I tried uploading both my RR.ini and Debug.txt, but both came up as invalid files.
  2. #32
    MySQL Error
    Oct 2004
    zip the files, but im not going to find anything i bet, but ill look
    i just installed it(while back), and it works for me...1st try too. hehe
    i assume by that stuff you show your running windows7 x64 right?
    and yes, it doesnt close when rr exits, because, they have a NAG screen....
    but i forced that close in RR > 8/8 builds
    m
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #33
    Feb 2011
    I didn't see anything in RR.ini or the debug.txt either. The issue appears to be when the window gets resized. The free version has a splash screen (advertisement) for mapfactor products. Once it goes away, there is a dialog warning, then the map appears. The information from above is from my desktop PC. When tried on the CarPC (x86), I get a different result. It just crashes Navigator for one of the VB dlls (Mvc???.dll), but it does not crash RR (good thing). I'll keep tinkering with it. I think the best I'll be able to do is start Nav 11 and then RR. It appears some one else on this forum has my same issue. Things may be different with the paid version.
    Bobby
  4. #34
    Feb 2011
    Wozza,
    Let me know if you have any luck. I'm having the same issues you are. I've defined an A definition in the skin (already there) and even did it as a program argument with "--window_position=" and same coordinates as in the A definition. No luck either. However, if were to start the program outside of RR and then start RR, it links as described by others. This is happening on both my desktop PC (Win7 x64) and Car PC (Win7 x86). Looking at both RR.ini files on desktop and carpc, both had the same issues with --window_position= [blank]. With the window position defined, it has both window_positions listed with the blank one being second. It is as if, on my system at least, the A definition is being ignored somehow.
    Bobby
  5. #35
    MySQL Error
    Oct 2004
    are u guys sure its loading that skin?
    skintool...
    if its blank window position, id say the is no A on the skin... the skin that is expected to be used is external_gps.skin
    i bet debug.txt would help...
    Code:
    8/10/2012 7:36:20 PM: Que Exec: True, menu.skin, "GPS", False
    8/10/2012 7:36:20 PM: Executing: GPS
    8/10/2012 7:36:20 PM: Shell: "C:\Program Files (x86)\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\ProgramData\Navigator\11.0\atlas_pcn_free.idc' --window_position=2,74,797,470
    8/10/2012 7:36:20 PM: Que Exec: True, external_gps.skin, "ONSCREENCHANGE", False
    8/10/2012 7:36:20 PM: Leave Exec: False, external_gps.skin, ONSCREENCHANGE, False
    when u get the cords i bet it works
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  6. #36
    Feb 2011
    Mitch,
    Here is an excerpt directly from my debug.txt:
    8/10/2012 8:27:57 PM: Que Exec: True, menu.skin, "RRMenuItem;6", False
    8/10/2012 8:27:57 PM: Executing: RRMenuItem;6
    8/10/2012 8:27:57 PM: Que Exec: True, menu.skin, "GPS", False
    8/10/2012 8:27:57 PM: Executing: GPS
    8/10/2012 8:28:08 PM: Shell: "C:\Program Files (x86)\Navigator11\PC_Navigator\PC_Navigator.exe" --atlas='C:\ProgramData\Navigator\11.0\atlas_pcn_fre e.idc' --window_position=
    8/10/2012 8:28:08 PM: Que Exec: True, external_gps.skin, "ONSCREENCHANGE", False
    8/10/2012 8:28:08 PM: Leave Exec: False, external_gps.skin, ONSCREENCHANGE, False
    8/10/2012 8:28:11 PM: Enter Exec: False, external_gps.skin, "ONBTNPRESS||exit", False
    8/10/2012 8:28:11 PM: Que Exec: True, external_gps.skin, "ONBTNPRESS||exit", False
    8/10/2012 8:28:11 PM: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    8/10/2012 8:28:11 PM: Executing: PlaySound;C:\Users\Bobby\Documents\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
    8/10/2012 8:28:11 PM: Que Exec: True, external_gps.skin, "exit", False
    I believe this is happening because PC Navigator 11 shows a banner for MapFactor (I can't get info on it with winspectorspy because it happens too fast) and a warning message (Windows Class "Edit") before the navigation window opens. The warning message must be acknowledged before you can open the nav window. I've been trying to get a class name on the banner just to test my theory. Are there any program arguments that stop that banner and warning message? If so, I firmly believe this will fix the problem.
    Bobby
  7. #37
    Maximum Bitrate Mickz's Avatar
    Sep 2009
    Australia
    Apology for not being RR specific and if I’m just stating the bleeding obvious.
    My FE is not RR but just out of interest, when I was playing around with embedding Navigator 11 free, I found that all resize commands were being directed to the Warning window, which won’t respond to them (Win7-64). I was only testing so didn’t look any further, just auto-sent an ENTER key stroke to close the warning window before resize and everything was perfect after that. Perhaps there is a command line argument to bypass that screen, never looked.
    GA-Z77N-WIFI, i5-2400S, 8GB, Intel 520 128GB SSD, M4-ATX Modified, 2 Rev Cams, 2 Web Cams
    8" 16:9 TRANSFLECTIVE, Win8-64, Dual GPS RX and Garmin PC + Odyssey Nav, FM-DAB+, BB-Rec
    T-Screen HVAC control, custom microcontrollers, code and FE. CarPC Project
  8. #38
    Apr 2012
    Radelaide South Aus
    Hi Mitch
    I re downloaded RR from NISU Automotive Online Store on 9/8/12 (aus time) just to be sure,and it didnt have navigator11 listed in the drop down menu in RRconfig,
    yet the other ftp ver did and nav11 now works as advertised
    I also noticed that the riderunner.exe date was 2/7/12 when I first download RR aug update on the 2/8/12...... then when I re downloded it on the 9/8/12 the riderunner .exe was dated 2/8/12
    Im only mentioning this as there might have been a snafu between updates on the NISU site
    Wozza
  9. #39
    Feb 2011
    Mickz, Mitch, Wozza thanks for the tips. I'll go and try to find the FTP version of RR. I too downloaded the version from NISUAutomotive. BTW, where is the FTP site?
  10. #40
    Feb 2011
    Looked all over the web. Don't see an FTP site to download the most up to date version of RR. The only download location I can find is www.nisuautomotive.com. I have the Aug release basic install on my PC. Is there another location to download RR other than nisu?
  1. Mapfactor PC Navigator in CentraFuse?
    By GreenBeauty in forum GPS
    Last Post: 04-09-2008, 03:13 AM
  2. Mapfactor Navigator 7 COM port Error
    By markieb in forum GPS
    Last Post: 12-12-2007, 04:41 AM
  3. Replies: 1
    Last Post: 10-19-2007, 09:55 PM
  4. MapFactor OCX
    By carmen2007 in forum GPS
    Last Post: 06-23-2007, 07:23 AM
  5. Mapfactor Navigator 6
    By Naesstrom in forum Road Runner
    Last Post: 03-02-2007, 07:50 PM
