Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 69
Thread: Navigator 11 from Mapfactor
  1. #41
    Aug 2012
    Hi there! I'm currently in the process of setting up my carPC, and I definitely need some help here! Hope you guys know how to fix my problem!
    I tried configuring Navigator 11 (free version) into RR (skin carwings, for testing), but had no succes. Despite the four pages in this topic. Then I tried downloading the latest version from nisu. This gave me a dropdown with 4 options: MapMonkey, MapPoint, External, iGuidance. MapPoint. I think this is not the version which contains the MapFACTOR PC Navigator 11 support? Or am I doing something wrong?
    A link to the discussed FTP version might help me further! Thanks in advance!
  2. #42
    MySQL Error
    Oct 2004
    it will be in the next rr, but u dont need it to get it working in rr now
    just to get it working better
    and easier
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  3. #43
    Aug 2012
    I downloaded the september release and now pc navigator 11 works fine! Only one problem... The gps port cannot be opened (so my gps is not working). When i start pc navigator free om the shortcut on the desktop everything works fine.
    Weird?!
    Anyone had the same problem or someone knows fix?
    Thanks in advance!
  4. #44
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Your problem is that you need to split your gps port, so that two applications (RR & PCNav) can both use its data. Search for X-Port (free SW written by forum member), set it to the port that your GPS COM is and then spit into how ever many separate ports that you need. Open up the RR config and set its gps port to one of the separate ports, doing the same in your pcnav app. Then you will be all good.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  5. #45
    Aug 2012
    Thanks!! That program works fantastic! Amazing little piece of software!
  6. #46
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    I have a little issue with Pc_Navigator.
    When i run it the first time , it's hidden, i need to return on the main menu and launch again Pc_Navigator !!!
    This is my rr.ini settings:
    [Navigation]
    GPSMode=4
    GPSPath=
    GPSName=
    [Navigation - iGuidance]
    igNative=False
    igAutoSw=False
    PauseOnVoice=False
    GPSOnVoice=False
    LastScreenSwitchTime=0
    [Navigation - PC Navigator]
    RRPCNavigatorPath=D:\Program Files\Navigator11\PC_Navigator\PC_Navigator.exe|--atlas='D:\Documents and Settings\All Users\Application Data\Navigator\11.0\atlas_pcn_free.idc'
    RRPCNavigatorName=!MPFCWindow!Navigator
    Thanks for your help !!!
  7. #47
    MySQL Error
    Oct 2004
    how is it embedded on screen, i found best best.. is to not only use an A but use a C skin object definitions
    due to how it embeddes
    and depends on skin
    parenting the window to rr, may help too
    the AX is the solution with option parent
    try my skin
    Attached Files Attached Files
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #48
    May 2008
    Bordeaux, France
    Quote Originally Posted by mitchjs View Post
    and depends on skin
    try my skin
    I use the external_gps.skin file:
    RoadRunner Skin
    RRScreen external_gps
    [ Top Screen Title Image ]
    IMG,87,19,252,38,"NAVIGATION.png",out
    [ Include File ]
    INC,Bottomtext.txt
    [ Standard RideRunner Label ]
    L,346,23,220,27,255,255,255,18,"Arial:B","TRACKNAM E","SCROLLCENTER",,"DS=2,2,0,0,0"
    [ Standard RideRunner Buttons ]
    B,675,4,119,59,"exit",
    [ Indicators ]
    I,624,9,47,53,"PHONE_CONNECTED_PHOCO"
    I,572,12,50,45,"ONLINE"
    [ Application Embed defined Area ]
    /A,2,74,797,470,
    AX,2,74,797,470,"OPT_NOTOUCH,OPT_PARENT"
    END
    The difference between your screen is that i use AX,2,74,797,470,"OPT_NOTOUCH,OPT_PARENT" and you use AX,2,74,797,470,"OPT_PARENT,OPT_NOTOUCH"
  9. #49
    MySQL Error
    Oct 2004
    order shouldnt matter, but who knows...since u didnt say...
    but im not having any issues that its hidden on 1st show
    use a named skin, vs the external gps one
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #50
    Apr 2012
    Radelaide South Aus
    Hi
    Just noticed navigator11 has been upgraded to 12 anyone tried the new ver ? just wanted to check before I stuff my system up again
  1. Mapfactor PC Navigator in CentraFuse?
    By GreenBeauty in forum GPS
    Last Post: 11-09-2013, 04:32 PM
  2. Mapfactor Navigator 7 COM port Error
    By markieb in forum GPS
    Last Post: 12-12-2007, 05:41 AM
  3. Replies: 1
    Last Post: 10-19-2007, 10:55 PM
  4. MapFactor OCX
    By carmen2007 in forum GPS
    Last Post: 06-23-2007, 08:23 AM
  5. Mapfactor Navigator 6
    By Naesstrom in forum Road Runner
    Last Post: 03-02-2007, 08:50 PM
