Page 7 of 7 FirstFirst 1234567
Results 61 to 69 of 69
Thread: Navigator 11 from Mapfactor
  1. #61
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Quote Originally Posted by navputer View Post
    I have PC Navigator 12 opening/sizing correctly but it's not closing out. When you select menu/exit, you still have to click on the screen somewhere to get it to finally close. Also, when you exit RR, it still will not close until you click on the window. How is anyone using this getting it to close out?
    RR 3/1/14
    DFX5
    Win 7 32bit
    Use RRConfig !
    General/Embedded Apps Add --> !MPFCWindow!Navigator
  2. #62
    Variable Bitrate navputer's Avatar
    Jan 2007
    DFW Area
    Ok...yeah. I forgot about that part in RRConfig. I will add to the list.
    Thanks for your help.
    Gee
  3. #63
    Jan 2007
    DFW Area
    I added this option in RRConfig (added different window name as well) and it still will not "force" close PC Navigator. You have to click on the app somewhere to finally get it to close. Any other ideas?
    Gee
  4. #64
    May 2008
    Bordeaux, France
    What skin do you use ? Try before with Carwings and when all is ok with an other skin !
  5. #65
    Jun 2007
    Colorado
    Using PC Navigator 12 with DFX and all the latest updates. Has anyone gotten this to work as smoothly in DFX as it does in carwings? For some reason in DFX, RR will just push the navigation window behind the RR window if I click almost any menu button and I can never bring the GPS window back. Useless. The only thing I edited was in the skin.ini file, I replaced....
    MenuExec_19=Load;$GpsScreen$;$GPSNAME$;$GPSPATH$;$ GPSNAME$||ACTIVATE;iGuidance||SENDKEY;{p}{p}
    with
    MenuExec_19=GPS
    and
    MainMenuExec_05=Load;$GpsScreen$;$GPSNAME$;$GPSPAT H$;$GPSNAME$||ACTIVATE;iGuidance||SENDKEY;{p}{p}
    with
    MainMenuExec_05=GPS
    Any helpful hints? Am I at least on the right track? Thanks.
  6. #66
    May 2008
    Bordeaux, France
    Quote Originally Posted by goldenley View Post
    with
    MenuExec_19=GPS
    and
    with
    MainMenuExec_05=GPS
    Can you try:
    Code:
    MainMenuExec_05=GPS||ACTIVATE;!BarneyMainWndCls!Navigator
  7. #67
    Jun 2007
    Colorado
    Thank you for your hint, I should have specified I'm using PC Navigator FREE. Anyway, I tried it with both
    and
    GPS||ACTIVATE;!MPFCWindow!Navigator
    It is reacting the same way with both. When I open the navigator screen, everything displays correctly, but as soon as I hit any button outside of the GPS window (like the next audio track button), the GPS window disappears underneath RR and I can't bring it back without Alt-tabbing which won't work in a car environment. In Carwings, I can use the audio buttons without losing the GPS window. I'm not sure what the two skins are doing different. Any help is appreciated, thank you!
  8. #68
    May 2008
    Bordeaux, France
    Into your external_gps.skin try to replace the line A,2,74,797,470, by AX,2,74,797,470,"OPT_NOFOCUS"
  9. #69
    Jun 2007
    Colorado
    Thanks! Works much better now!
  1. Mapfactor PC Navigator in CentraFuse?
    By GreenBeauty in forum GPS
    Last Post: 11-09-2013, 04:32 PM
  2. Mapfactor Navigator 7 COM port Error
    By markieb in forum GPS
    Last Post: 12-12-2007, 05:41 AM
  3. Replies: 1
    Last Post: 10-19-2007, 10:55 PM
  4. MapFactor OCX
    By carmen2007 in forum GPS
    Last Post: 06-23-2007, 08:23 AM
  5. Mapfactor Navigator 6
    By Naesstrom in forum Road Runner
    Last Post: 03-02-2007, 08:50 PM
