Results 1 to 6 of 6
Thread: RR 06-01-2012 Release
    MySQL Error
    Oct 2004
    June 2012.... hello summer
    Download Here: http://www.nisuautomotive.com
    For sure the least amount of RR updates in a long time!
    Added support for PC Navigator 11 Free edition
    (minor aid to help size the window for embedd into rr)
    + the RRConfig option to put the command line arguments (see image below)
    HISTORY:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    05/24/2012
    + Tweak to auto-detect and run PC Navigator 11 free correctly
    # Issue with "EmbedAppList" setting, now is case insensitive.
      ex. if the EmbedAppList=iGuidance|Notepad
          and you have an app as "Note"(window name) embedded, it will not falsely match "Notepad"
    * Apps in the "EmbedAppList" now will be closed on exit of RR("CloseApps" setting must be true)
    05/11/2012
    # Invalid json data from WeatherUnderground for Finnish Language <br> and &amul;
      replaced to proper items.
    RRConfig:
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Thanks for this new version !!!
    Mar 2011
    Thanks!!!
    May 2008
    Bordeaux, France
    I have an issue with the custom list and the CLFIND command :
    I create a custom list with a different logo on each line like that:
    Code:
                Case "rrgmail_settings"
                    SDK.SetUserVar("RRGMAIL_USERNAME", INI.ReadString("RRGmail", "Username", ""))
                    SDK.SetUserVar("RRGMAIL_PASSWORD", INI.ReadString("RRGmail", "Password", ""))
                    SDK.SetUserVar("RRGmailInfo", SDK.GetUserVar("l_set_ActualRRGmailLanguage") & " '" & Language & "'")
                    SDK.Execute("CLCLEAR;ALL||LOAD;RRGmail_Settings.skin")
                    If File.Exists(MainPath & "Languages.txt") Then
                        sArray = File.ReadAllLines(MainPath & "Languages.txt")
                        For p = 0 To UBound(sArray)
                            SDK.Execute("CLADD;" & sArray(p))
                            If File.Exists(MainPath & "Languages\" & sArray(p) & "\" & sArray(p) & ".gif") Then
                                SDK.Execute("CLSETIMG;" & p + 1 & ";" & MainPath & "Languages\" & sArray(p) & "\" & sArray(p) & ".gif")
                            Else
                                SDK.Execute("CLSETIMG;" & p + 1 & ";" & MainPath & "Languages\" & "Error.gif")
                            End If
                        Next
                        SDK.Execute("CLFIND;" & Language) 'selectionne la ligne du language actuel
                    Else
                        SDK.ErrScrn("!! Info !!", MainPath & "Languages\" & "Languages.txt file is not found !!!", "")
                    End If
                    ProcessCommand = 2
    My screen code is:
    Code:
    [Sliders]
    S,119,146,40,363,119,146,40,363,V,0,"mixersliderH.png",18,"CLSLIDER",
    [ List Definitions ]
    IL,PL,transparent.bmp,sel.bmp,end.bmp,2,50,80
    SC,172,145,153,363,255,255,255,255,255,255,64,64,64,255,128,0,TRUE,20,"Arial:B"
    But as you can see on my screen , the first logo is bad,the russian logo is copied on the first line:
    If i don't use the CLFIND command , the logos are always ok !
    So, i have tried to use the CLFIND command into the SkinTool as 'CLFIND;japan' and the japan flag is copied on the first logo.
    An idea ?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    thanks guys... I have been far away from home and my car for months.. and will be for the next year or so!! sadly i can not try it
    MySQL Error
    Oct 2004
    Quote Originally Posted by pierrotm777 View Post
    Code:
                            Else
                            End If
                        Next
                    Else
                    End If
                    ProcessCommand = 2
    My screen code is:
    Code:
    [Sliders]
    An idea ?
    COURSE NOT, but i would be happy look at it, if you provide me with all that i need to eval it
    i prob dont need the plugin, i can do it all from skintool...
    i would need the skin images, and all the flag images, and a list file, i cant load into the custom list
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 05-01-2012 Release
    By mitchjs in forum Road Runner
    Last Post: 05-21-2012, 05:53 PM
  2. RR 04-01-2012 Release
    Last Post: 04-21-2012, 01:47 PM
  3. RR 02-05-2012 Release
    Last Post: 02-25-2012, 09:37 AM
  4. RR 01-01-2012 Release - Happy New Year
    Last Post: 02-16-2012, 05:37 PM
  5. Replies: 2
    Last Post: 01-17-2012, 03:01 PM
