you should be able to make an exe, and create the rr sdk obj...
you can talk to RR
v = SDK.GetUserVar("blabla")
SDK.SetUserVar("blabla", "1")
I have a C# console program that I would like to have get and set user variables in RR.
I know I am missing something because if I use the code provided with the C# plugin example, I get the following execution error:
The program in question can't be made into a DLL for a number of reasons.Code:COM target does not implement IDispatch
Anyone have a C# sample of a console program that access RR?
Regards,
Jim
you can talk to RR
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Mitch,
That is exactly what I did.
I created a Console app under Visual C# Express 2008.
I copied the SDK class source from the RR Plugins C# example.
I activate that class in "main" with
Code:if (SDK.Created == false) { SDK.SetSDK(); }
I made no changes to the default properties or build configuration except for the .exe output directory and to build for x86.
The app compiled fine.
When I run it, I get the "COM target does not implement IDispatch" on the first attempt to use any of the RR SDK methods.
Curiously, if instead of a Console app, I make a Windows Form app, it works fine in the main part of the app, but fails if I try to call RR from a thread that I create in the Window Form app.
I even tried an old code fragment from either you or guino and it failed. That code is somewhat similar to the plugin SDK code:
I am at a loss.Code:// In main System.Type SDKType = System.Type.GetTypeFromProgID("RoadRunned.SDK"); object SDK = System.Activator.CreateInstance(SDKType); // invoke RR private String RRcom ( cmd, message ) { Object o = SDKType.InvokeMember(cmd, System.Reflection.BindingFlags.InvokeMethod, null, SDK, new object[] { message }); return (string) o; }
What am I missing?
Have there been any changes to the RR COM object?
I am using .Net 3.5 on Windows 7 Pro on both 64bit and 32bit machines with the same result.
Regards,
Jim
I dont know jim, it just works
here is my demo for ya
oh, you poped a zip on my ftp.... it was corrupted, failed crc
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
