Results 11 to 20 of 28
Thread: SendKeys
  1. #11
    MySQL Error
    Oct 2004
    also
    "ACTIVATE||SENDKEY;3"
    would work... activate command acticvates the embedded window on current screen
    so just adding that infront of any send key would work too
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #12
    MySQL Error
    Oct 2004
    good thing about the new sendkeyx, u can use it in SKINTOOL
    the old one would try to send keys to skintool itself
    so.. on the iguidance_wide.skin, in skintool, "SendKeyx;3" would activate ig and send 3, and keep it active!
    (im debating if i want to return focus of its "skintool" just cause i love skintool!)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  3. #13
    MySQL Error
    Oct 2004
    also few errors in DFX5 skin (looking at wide now)
    whats
    B,1,1,95,70,"SENDKEY;"{enter}",""
    it should be
    B,1,1,95,70,"SENDKEY;{enter}",""
    some oddball extra "
    lots of clean up
    and now should be SENDKEYX
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #14
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Thanks. Will test the changes and report back.
    P.S. Got your PM.
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
  5. #15
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Quote Originally Posted by mitchjs View Post
    NOPE!
    the problem here is partial DFX5
    and well we dont know what else he really did
    Well I'm basing on him mentioning it didn't work in the iDriveT skin when it used to.
    Now I know the iDrive skins don't have activate before the sendkey (although the buttons for other nav engines do) they do have gps in the skin name.
    (unless of course he didn't use the config in iDrive to change the Nav to iGuidance)
  6. #16
    Sep 2006
    War-Town, GA.
    Indeed everything works now Out of all the possible solutions, i did this one: "add "ACTIVATE;IGuidance||" infront of all those commands' and now all sendkeys work.
    Will wait for release of the next RR to do it the right way.
    Thanks very much for your help.
    M2-ATX Power Supply
    Windows XP SP3
  7. #17
    MySQL Error
    Oct 2004
    Quote Originally Posted by Enforcer View Post
    exactly... its the "gps" in the skin name, and when using IG, that RR will target IG
    else.. it can go to any active window...
    so.. best solution, is the new SendKeyX, cause that will targert the embedded window on the current skin
    good for other programs too
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #18
    Sep 2006
    War-Town, GA.
    if something doesnt work in 6/1, that worked in 1/1 lets look at it
    but I SAID, and CONTINUE to SAY, IG WORKS in DFX5 IN 6/1!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    you said, you tested it, or well, something says your taking someone elses word for that
    No it don't! If you push just the right (sendkey) button it may work ONCE. This may give the impression everything is working but what's happening is that when you press the first button (when in the IG screen), IG loses focus and from then-on no (sendkey) buttons work. It didn't occur to me to click the IG window to return focus to it because YOU DIDN'T HAVE TO DO THAT BEFORE!
    So the buttom line is (based on process of elimination and common sense) is that something in the RR code changed, because the sendkey commands didn't; they (sendkeys) may have been "non-compliant" before but they worked. Something had to change in RR that may now be enforcing the "sendkey" rules or as was mentioned before, embedding is different.
    M2-ATX Power Supply
    Windows XP SP3
  9. #19
    MySQL Error
    Oct 2004
    treetop, it does work!!!
    let me guess you are using IGUIDANCE_WIDE.SKIN right?
    something is PULLING FOCUS AWAY, could BE ANYTHING!!!!! even RR process
    thats because, no "GPS" in the name, so RR doesnt know that this is for IGUIDANCE!!!
    just change the name of the skin to, "IGUIDANCE_WIDE_GPS.SKIN"
    and try
    sendkeys HAS NEVER been changed!
    do u see it in the HISTORY?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #20
    Maximum Bitrate RAWPWR's Avatar
    May 2007
    Nice fix treetop!
    Works a treat.
    Thanks bud.
  1. Sendkeys to an embedded app?
    By karrhacker in forum Coders Corner
    Last Post: 07-18-2008, 12:42 PM
  2. Sendkeys iguidance
    By pdiculous963 in forum Road Runner
    Last Post: 03-27-2008, 09:52 AM
  3. Destinator SDK & sendkeys
    By luca.decarlo in forum Coders Corner
    Last Post: 05-02-2006, 01:01 PM
  4. vb sendkeys not working ?
    By _dopehead_ in forum Map Monkey
    Last Post: 03-29-2006, 11:05 AM
  5. Another Sendkeys question
    By PURDooM in forum Road Runner
    Last Post: 11-18-2005, 09:59 PM
