Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: SendKeys
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    SendKeys
    Is it possible the sendkeys command was broken in the new version of RR?? Specifically, sendkey buttons to call diferent functions in iGuidance are not working. I though it was only in DFX5 but they don't work in several other skins (DFX4, iDriveT, Void).
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    MySQL Error
    Oct 2004
    nope, no change to that code...
    sendkeys only works if that window is the ACTIVE window for input
    to me sendkeys blows in all cases, very unreliable...
    in anycase, if you give me an example of real usage, i can test...
    and your going to tell me when you hit say "3d" in dfx5, it doesnt work...
    well it does for me and that seems to be a sendkey as per skintool
    SENDKEY;"{3}","
    infact they all work, BTW i never looked at DFX5's support for IG, NICE!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    I think the issue may be your recent enhanced embedding upgrade
    MySQL Error
    Oct 2004
    brings up a point
    this is a better way
    ACTIVATE;IGuidance||SENDKEY;3
    add "ACTIVATE;IGuidance||" infront of all those commands, to ASSURE(well resonably assure) they actually go to IGuidance
    but you know, i can make a better SENDKEY Command...
    ALL THIS DOESNT apply, keep reading...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    it just gets more interesing look at this code
    If (InStr(1, CurSCR, "gps") <> 0 And LCase(GPS_NAME) = "iguidance") Then
    Activate iGhwnd
    SendKeys Key, True
    Else
    that means, DFX5 skin is flawed since its skin name is names "iguidance_wide" no where is "gps" in it...
    so it wont activate the iguance window!
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    course i dont like any of that code, and will rewrite some of it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    you know too, i see issues in DFX5 too...
    inconsistency
    external_gps, its going to work fine with the activate code
    but... for 3d it sends out
    B,2,77,72,71,"SENDKEY;"{3}",""
    where in the WIDE (iGuidance_wide.skin)
    B,196,1,99,70,"SENDKEY;3",""
    also see a dupped issue in wide
    DFX5 needs review
    for current code to focuse on IG
    the skin should be called
    iguidance_wide_gps.skin
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    NEW COMMAND
    SENDKEYX
    SENDKEYX;keys
    will send key, but 1st will target embedded window on current screen (in our example iguance) skin name not matter!!
    so... SENDKEYX;3
    will send the 3 key to the embedded app (in our case 3 is toggle 3d)
    also!!!
    SENDKEYX;keys;windowname
    you can with one command, activate a window, and then send keys to it (why you need to do this i dont know, but you can)
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    Quote Originally Posted by Enforcer View Post
    NOPE!
    the problem here is partial DFX5
    and well we dont know what else he really did
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    simple fix up for now... if you dont get the new rr, and USE THE NEW MUCH IMPROVED sendkeyx is
    fix the naming of the skin file to have _gps in it
    so
    like "IGUIDANCE_WIDE.skin" named "IGUIDANCE_WIDE_GPS.skin"
    then a old sendkey will know that if the name has "gps" in it, and iguidance is the the GPS_NAME it will activate the iguidance window
    OR
    BETTER
    get the new RR *6/21/2012 or newer
    and change sendkey to sendkeyx
    and fix up the skisn does {3} should be just 3 for 3d
    m
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Sendkeys to an embedded app?
    By karrhacker in forum Coders Corner
    Last Post: 07-18-2008, 01:42 PM
  2. Sendkeys iguidance
    By pdiculous963 in forum Road Runner
    Last Post: 03-27-2008, 10:52 AM
  3. Destinator SDK & sendkeys
    By luca.decarlo in forum Coders Corner
    Last Post: 05-02-2006, 02:01 PM
  4. vb sendkeys not working ?
    By _dopehead_ in forum Map Monkey
    Last Post: 03-29-2006, 12:05 PM
  5. Another Sendkeys question
    By PURDooM in forum Road Runner
    Last Post: 11-18-2005, 10:59 PM
