Results 1 to 5 of 5
Thread: Minimum Hardware Requirement for RR
    Dec 2007
    Sydney Australia
    Hi Mitch,
    With all the development and changes to RR functionality through the years is there a recommended minimum hardware requirement (processor,speed,memory,graphics) to run the latest version efficiently such that video is smooth and music can run in the background while navigation is active ?
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
    Newbie Doogle's Avatar
    Jun 2006
    Sherwood Forest
    I'd like to know this too as I've been out of the carPC game for a while and my old carPC is using an Epia SP13000 motherboard, 1Gb Ram and M2-ATX power supply, also still using a really old version of Road Runner from before July 2007!
    Will this machine spec be able to run the new version of Road Runner, or Ride Runner as it is now called, ok?
    Getting back into the game...
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    depends on what you wanna do. What PNG support/GDI+? You probably be starting with 1ghz, but on carwings with limited plugins and fastmode off you could probably still get by with 800mhz epia board
    Live mp3Car Facebook Chat
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by Sonicxtacy02 View Post
    +1
    My Atom single core craps on itself with multiple plugins + DFX5, not much better with Carwings + just a couple plugins, depends on the plugins, maybe, or possibly the planet alignments...
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Woodbridge, VA
    Blog Entries
    55
    Quote Originally Posted by DaveDog View Post
    +1
    disable GDI+ in rrconfig and you should see an increase in performance.
  1. Minimum power supply requirement???
    By firstjazzu in forum General MP3Car Discussion
    Last Post: 10-13-2008, 08:07 AM
  2. hardware requirement *long*
    By ashzero in forum General Hardware Discussion
    Last Post: 09-03-2004, 05:50 AM
  3. Epia - PSU minimum requirement
    By XtremEnginea in forum Power Supplies
    Last Post: 06-18-2003, 04:42 PM
  4. Minimum hardware requirements for DVD and MP3's
    By wysiwyg in forum General Hardware Discussion
    Last Post: 12-15-2002, 11:40 AM
  5. Requirement for a Touchscreen LCD
    By Mastero in forum Classified Archive
    Last Post: 11-06-2001, 05:02 AM
