Sutff.Hunter, ?? what changelog?
looks good to me, its paused, and positioned
18/07/2012 12:43:28: INFO: AudPlayerStart() - player should be playing: PLAYING
18/07/2012 12:43:28: INFO: AudPlayerStart() - Player.GetTrackLength: 261512
18/07/2012 12:43:28: INFO: AudPlayerStart() - Player.SetTrackPosition: 5560
18/07/2012 12:43:28: INFO: CheckResume() - Resuming to music player: PAUSED
and i tested WMP myself now, works, fine, rr starts up with track in pause
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
He may have found a reference to the old phonecontrol code that was in the core by RobbyBMW.
Current Status of release:
Phone Control
what exactly is that mean
the problem is solved.
I don't know why, I found an old rr.ini which functioned normally. When I compared with rr.ini posing problem, the only difference I saw is "CircularList". In rr.ini posing problem CircularList = true, so I change it but no effect, I reset it to true and now the shuffle working properly ????
Thanx again Mitchjs
Edit: false joy because when I save another change in rrconfig the problem returns.
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
That is sooooooo out of date.
As I said earlier that refers to code that was in the core that could access phone control software called PhoneContol AKA Phoco by a user called Zoran, but that has long gone and is so out of date it would not work with modern phones. And thus the code has been taken out of the core (I'm sure mitch will correct me if it hasn't. And then remove it)
yea, that is OLD.... and phone control has long been removed
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
well, all clear nowhi Mitch, any plans for implementing hands-free and phone control without using bluesoleil
