Results 1 to 10 of 20
Thread: RR 07-01-2012 Release
    MySQL Error
    Oct 2004
    July, dam 2012 flying by...
    Download Here: http://www.nisuautomotive.com
    A new option for Sliders....really nice for Mice users (or people still without a carpc (me))
    myself using mode 1(loose mode)
    mode 2, is loose mode with roaming, ie your finger can move off the slider, really interesting on a screem
    with a bunch of sliders, like an EQ screen.
    I will add these new options to RRCONFIG, when i get a few mins, been very busy of late
    well between a new Plugin; Carnetix P2140, that i will release shortly, only documentation holding it up
    Highlights:
    • + NEW Setting; "rrSliderMode=x", Where x = 0-2 (defaults to 0).
    • + NEW Skin Command; "SendKeyX"
    History:
    Code:
    LEGEND:
    - = Removed
    + = Added
    * = Changed
    ! = Major code change
    # = Bug fix
    ^ = Note
    6/24/2012
    # Indicators with NOT(-) prefixed to it, sent into plugins incorrectly.
    6/20/2012
      0 = Default behavior.
      1 = Loose mode.
      2 = Loose mode with roaming.
    # Fixed issue with Map Factor's PC Navigator 11 support when resizing skins.
      ex. "SendKeyX;3                 - sends the 3 key stroke to the application currently embedded on current screen.
      ex. "SendKeyX;hello;notepad"    - sends the key strokes of "hello" to the application window named "notepad".
                                        (This will return focus back to embedded window if any)
    06/19/2012
    # Fixed issue with labels that were defined in .skin as the same as internal size,
      causing incorrect background painting on label.
    06/17/2012
    # Slider out of bounds values passed into plugins.
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    OLD SYSTEM (DEAD)
    Intel D945GCLF2 Dual Core ATOM
    Lilliput 7" 629GL 2008 LED Backlight
    BU-353 USB GPS Receiver / iGuidance / IGO8
    M2-ATX Power Supply
    RideRunner Front End / Various Skins
    Windows XP SP3
    Maximum Bitrate DaveDog's Avatar
    Mar 2004
    Greenacres, WA
    Quote Originally Posted by mitchjs View Post
    [/CODE]
    Can't wait to see if it's worthy.
    Still need sleep.
    TruckPC - gutted, being used for test setup
    BoatPC - All in 1 in cuddy, N7 using VNC on dash, RR
    BlazerPC - Nexus 7 with Timur's USBROM
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    The sliders run very well, and this was a point that i didn't like into RR . Now it's coool
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    Quote Originally Posted by DaveDog View Post
    Still need sleep.
    Well I can assure it is worthy!
    Jun 2007
    Oct 2010
    Ivry-Sur-Seine (France)
    Hi Mitchjs,
    I still have the same problem with the shuffle function. I tried with skin CARWINGS and without plugin installed, I use windows 7.
    If the shuffle is enabled and that I relaunch playing the song when it was paused, the song starts from the beginning.
    Thanx
    MySQL Error
    Oct 2004
    not me, when i relaunch rr, the song resumes (in pause) at the right possition
    with RR 7/1/2012, with carwings , with WINAMP as player
    also provide some real info btw!
    RR.ini:
    AudioShuffle=Last
    DEBUG:
    Code:
    7/15/2012 1:13:28 PM: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    7/15/2012 1:13:28 PM: INFO: LoadResume() - Reading resume data from C:\Users\mitchjs\Documents\RideRunner\Cache\resume.ini
    7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - music player: PLPosition=4  TrackPosition=-54831
    7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - player volume should be 0: 0
    7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - player should be playing: PLAYING
    7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - Player.GetTrackLength: 291000
    7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - Player.SetTrackPosition: 54831
    7/15/2012 1:13:28 PM: INFO: AudPlayerStart() - no fadeinvolume, player volume should be 255: 255
    7/15/2012 1:13:28 PM: INFO: CheckResume() - Resuming to music player: PAUSED
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Jun 2012
    ..just spotted in changelog :
    mobile phone support - does that mean no need for mp.net plugin anymore ? cheers
    Oct 2010
    Hi Mitchjs,
    It's not when I relaunch RR but when I pause and play the song.
    with RR 7/1/2012, with carwings, with WMP as player
    RR.ini
    AudioShuffle=last
    DEBUG:
    Code:
    18/07/2012 12:43:22: Start -- Version: 01/07/2012
    18/07/2012 12:43:22: OS Type: Windows 7
    18/07/2012 12:43:22: FileManager: FileMode = Legacy
    18/07/2012 12:43:22: FileManager: mypath = D:\Applications\RideRunner\
    18/07/2012 12:43:22: FileManager: ProfilePath = C:\Users\Administrateur\Documents\RideRunner\
    18/07/2012 12:43:22: Start Sequence: Starting Player...
    18/07/2012 12:43:22: PLAYER: Initialization creating object
    18/07/2012 12:43:24: PLAYER: Started
    18/07/2012 12:43:24: PLAYER: WMP Version: WMP (12.0.7601.17514)
    18/07/2012 12:43:24: PLAYER: Initialization complete
    18/07/2012 12:43:24: Start Sequence: Starting Radio Device...
    18/07/2012 12:43:24: Start Sequence: Starting Serial Devices...
    18/07/2012 12:43:24: Start Sequence: Starting Mixer...
    18/07/2012 12:43:24: VMC---> Set object successful
    18/07/2012 12:43:24: VMC---> SOURCE: Mixer line #1: "Microphone"
    18/07/2012 12:43:24: Start Sequence: Starting Speech...
    18/07/2012 12:43:25: DirectDraw Count: 2 - [] [{67685559-3106-11D0-B971-00AA00342F9F}]
    18/07/2012 12:43:25: Plugin Manager: loading Global Plugins...
    18/07/2012 12:43:25: Plugin Manager: Plugin Found: SkinTool
    18/07/2012 12:43:25: Plugin Manager: Plugin loaded (Global): SkinTool
    18/07/2012 12:43:25: Plugin Manager: Plugin Found: Weather
    18/07/2012 12:43:25: Plugin Manager: Plugin loaded (Global): Weather
    18/07/2012 12:43:25: Plugin Manager: loading Global Plugins Completed.
    18/07/2012 12:43:25: LoadSkin: D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\
    18/07/2012 12:43:25: Plugin Manager: loading SkinDir Plugins...
    18/07/2012 12:43:25: Plugin Manager: loading SkinDir Plugins Completed.
    18/07/2012 12:43:25: INFO: LoadKVPFromFile() - Reading KVP data from D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Menu.ini
    18/07/2012 12:43:25: Enter Exec: Faux, menu.skin, "ONRESTORED", Faux
    18/07/2012 12:43:25: Que Exec: Vrai, menu.skin, "ONRESTORED", Faux
    18/07/2012 12:43:25: Que Exec: Vrai, menu.skin, "ONSTART", Faux
    18/07/2012 12:43:25: Que Exec: Vrai, menu.skin, "ONLINE", Faux
    18/07/2012 12:43:25: Leave Exec: Faux, menu.skin, ONLINE, Faux
    18/07/2012 12:43:26: Global Hotkey: Successfully registered keycode:2112
    18/07/2012 12:43:27: PLAYER: Restored rrpl.m3u8
    18/07/2012 12:43:27: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    18/07/2012 12:43:27: INFO: LoadResume() - Reading resume data from D:\Applications\RideRunner\resume.ini
    18/07/2012 12:43:27: INFO: AudPlayerStart() - music player: PLPosition=0  TrackPosition=-5560
    18/07/2012 12:43:27: INFO: AudPlayerStart() - player volume should be 0: 0
    18/07/2012 12:43:27: Enter Exec: Faux, menu.skin, , Faux
    18/07/2012 12:43:27: Que Exec: Vrai, menu.skin, "ONSKINSTART", Faux
    18/07/2012 12:43:27: Que Exec: Vrai, menu.skin, "ONSOURCECHANGE", Faux
    18/07/2012 12:43:27: Leave Exec: Faux, menu.skin, ONSOURCECHANGE, Faux
    18/07/2012 12:43:28: Enter Exec: Faux, menu.skin, , Faux
    18/07/2012 12:43:28: Que Exec: Vrai, menu.skin, "ONSONGSTART", Faux
    18/07/2012 12:43:28: Leave Exec: Faux, menu.skin, ONSONGSTART, Faux
    18/07/2012 12:43:28: INFO: AudPlayerStart() - player should be playing: PLAYING
    18/07/2012 12:43:28: INFO: AudPlayerStart() - Player.GetTrackLength: 261512
    18/07/2012 12:43:28: INFO: AudPlayerStart() - Player.SetTrackPosition: 5560
    18/07/2012 12:43:28: INFO: CheckResume() - Resuming to music player: PAUSED
    18/07/2012 12:43:30: Enter Exec: Faux, menu.skin, "ONBTNPRESS||PLAY", Faux
    18/07/2012 12:43:30: Que Exec: Vrai, menu.skin, "ONBTNPRESS||PLAY", Faux
    18/07/2012 12:43:30: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    18/07/2012 12:43:30: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
    18/07/2012 12:43:30: Que Exec: Vrai, menu.skin, "PLAY", Faux
    18/07/2012 12:43:30: Executing: PLAY
    18/07/2012 12:43:30: Leave Exec: Faux, menu.skin, play, Faux
    18/07/2012 12:43:37: Enter Exec: Faux, menu.skin, "ONBTNPRESS||PLAY", Faux
    18/07/2012 12:43:37: Que Exec: Vrai, menu.skin, "ONBTNPRESS||PLAY", Faux
    18/07/2012 12:43:37: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    18/07/2012 12:43:37: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
    18/07/2012 12:43:37: Que Exec: Vrai, menu.skin, "PLAY", Faux
    18/07/2012 12:43:37: Executing: PLAY
    18/07/2012 12:43:37: Leave Exec: Faux, menu.skin, play, Faux
    18/07/2012 12:43:40: Enter Exec: Faux, menu.skin, "ONBTNPRESS||PLAY", Faux
    18/07/2012 12:43:40: Que Exec: Vrai, menu.skin, "ONBTNPRESS||PLAY", Faux
    18/07/2012 12:43:40: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    18/07/2012 12:43:40: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
    18/07/2012 12:43:40: Que Exec: Vrai, menu.skin, "PLAY", Faux
    18/07/2012 12:43:40: Executing: PLAY
    18/07/2012 12:43:40: Leave Exec: Faux, menu.skin, play, Faux
    18/07/2012 12:43:51: Enter Exec: Faux, menu.skin, "ONBTNPRESS||EXIT", Faux
    18/07/2012 12:43:51: Que Exec: Vrai, menu.skin, "ONBTNPRESS||EXIT", Faux
    18/07/2012 12:43:51: EXECTBL Translation: ONBTNPRESS -> PlaySound;$SKINPATH$Sounds\button1.wav
    18/07/2012 12:43:51: Executing: PlaySound;D:\Applications\RideRunner\Skins\Carwings_Dynamic_Lite\Sounds\button1.wav
    18/07/2012 12:43:51: Que Exec: Vrai, menu.skin, "EXIT", Faux
    18/07/2012 12:43:51: Executing: EXIT
    18/07/2012 12:43:51: Enter Exec: Faux, menu.skin, "ONEXIT", Faux
    18/07/2012 12:43:51: Que Exec: Vrai, menu.skin, "ONEXIT", Faux
    18/07/2012 12:43:51: Leave Exec: Faux, menu.skin, ONEXIT, Faux
    18/07/2012 12:43:51: Shutdown: (1)
    18/07/2012 12:43:51: Shutdown: (2)
    18/07/2012 12:43:51: INFO: CheckResume() - ResumeMusic=2 WasRadio=0
    18/07/2012 12:43:51: Shutdown: (3)
    18/07/2012 12:43:51: Shutdown: (4)
    18/07/2012 12:43:51: INFO: SaveResume() - Saving resume data to D:\Applications\RideRunner\resume.ini
    18/07/2012 12:43:51: INFO: LoadResume() - Reading resume data from D:\Applications\RideRunner\resume.ini
    18/07/2012 12:43:53: Plugin Manager: Warning Plugin skintool does not support Terminate Method
    18/07/2012 12:43:53: Plugin Manager: Warning Plugin weather does not support Terminate Method
    18/07/2012 12:43:53: Plugin Manager: ALL Plugins unloaded.
    18/07/2012 12:43:53: Shutdown: (5)
    18/07/2012 12:43:53: Player is running
    18/07/2012 12:43:55: Shutdown: (6)
    18/07/2012 12:43:55: Shutdown: (7)
    18/07/2012 12:43:55: OSUnloadMode: 1
    18/07/2012 12:43:55: Global Hotkey: All keys unregistered
    Thank you
  1. RR 06-01-2012 Release
    By mitchjs in forum Road Runner
    Last Post: 06-25-2012, 06:42 PM
  2. RR 05-01-2012 Release
    Last Post: 05-21-2012, 05:53 PM
  3. RR 04-01-2012 Release
    Last Post: 04-21-2012, 01:47 PM
  4. RR 02-05-2012 Release
    Last Post: 02-25-2012, 09:37 AM
  5. RR 01-01-2012 Release - Happy New Year
    Last Post: 02-16-2012, 05:37 PM
