Results 1 to 10 of 11
Thread: ACTIVESOURCEIDs
    Constant Bitrate besjr69's Avatar
    Feb 2011
    ACTIVESOURCEIDs
    I've searched and can't find an answer to this question. Does anyone know where the ACTIVESOURCEIDs are defined or have a listing for them:
    Example 0 - Radio, 2 - XM Radio, 3 - Sirius ...
    My plan is to define an image on my skin that changes based on the ACTIVESOURCEID.
    Bobby
    Sent from my iPhone using Tapatalk
    Feb 2011
    So far I've figured out the following:
    0-HD Radio
    1-FM Radio
    2-XM Radio
    3-Sirius Radio
    4-Audio
    5-Video??
    I read in some documentation there are up to 9 definitions.
    Bobby
    MySQL Error
    Oct 2004
    "ACTIVESOURCEID" - returns 1 = HD Radio, 2 = Radio, 3 = XM Radio, 4 = Sirius Radio, 5 = Audio(mp3), 6 = Video, 7 = DVD, 8 = TV
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Variable Bitrate Dartman_71's Avatar
    Feb 2009
    Finland
    and for plugins.
    9 = DVB, 10 = WebRadio
    Feb 2011
    Thanks Mitch and Dartman_71. I have one other questions. In the code below, I'm trying to display a different graphic based on the source ID. Here is a sample:
    IMG,376,546,48,48,"BYVAR;ACTIVESOURCEID;<<ICONS\HD _TUNE.PNG<<ICONS\FM_TUNE.PNG<<ICONS\XM_TUNE.PNG<<I CONS\SR_TUNE.PNG<<ICONS\PLAY.PNG<<ICONS\PLAY.PNG<< ICONS\PLAY.PNG",all
    The code appears to be in the correct syntax, but none of the images are displayed. What am I doing wrong?
    MySQL Error
    Oct 2004
    there is NO support of byvar in IMG (Images) they are static!
    Indicators yes, and hmm.. i could see a neat use of a multistate indicator here...
    Code:
    + Indicators now support "byvar"
      ex. I,xxx,yyy,hhh,www,"byvar;myuservar;image0.png<<image1.png<<image2.png"
       when myuservar is 1 or true, and will show image2.png when myuservar is 2]
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    MySQL Error
    Oct 2004
    oh, and any activesourceid > 9 is ambigous
    10 being web radio isnt always true!
    so.. this concept doesnt work past 10
    but each active source has a GUID
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Feb 2011
    Mitch,
    Thanks for the replies. You've been a great help. I was able to do it mimicing code on another skin. I used the [I]mage command with the Mask option:
    I,356,540,88,60,"VAR;ACTIVESOURCEID",,,"icons\play _*.png"
    I'm thinking that the "VAR;ACTIVESOURCEID" can be trimmed to simply "ACTIVESOURCEID". In the future, I will use your syntax as it will prevent me from copying and renaming a bunch of files.
    Bobby
    Low Bitrate rtgree01's Avatar
    Aug 2007
    STL
    So.... how does a skin get the GUID?
    How can the skinners do the various things based on the active source? I'd like to see something with a unique ID (guid) for each source that we can byvar or byvarx.
    But.... there are probably only a few uses for something like this...
    Just my 2 cents
    Ryan
    MySQL Error
    Oct 2004
    "ACTIVESOURCEGUID" is a Uservar, use skintool to view it!
    byvar and byvarx not going to work on it...
    since its not a singular number
    Web Radio's GUID is {97D76E60-0F9A-4328-A1A4-C99967655630}
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
