Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 46
Like Tree3Likes
Thread: Fresh Install Crashes
  1. #31
    Aug 2012
    Adelaide
    mitchjs team viewer sounds like a great idea, as I am getting majorly lost!
    When suits you? Otherwise I can just leave it running and send you the details and you can log in whenever you get the spare time.
    besjr69, this ON_CLICK play sound function in the exetbl.ini... is that the sound that plays every time you hit a button? If so I wouldn't mind getting rid of that anyway.
  2. #32
    Constant Bitrate besjr69's Avatar
    Feb 2011
    Poita,
    Here are the lines i edited out of the exectbl.ini:
    "ONBTNPRESS","PLAYSOUND;$SKINPATH$ButtonPress. wav"
    "ONBTNHOLD","PLAYSOUND;$SKINPATH$osk.wav"
    I simply put "//" (without the quotes) in front of each line. Since doing this I've not had a lock up on DFX or Carwings. In another thread you will see I had the same issues as you. I really can't say the cause of it, but I noted that last event executed in the debug was playsound() and something about resume.ini.
    Bobby
    Poita likes this.
  3. #33
    Aug 2012
    Adelaide
    Ok, I opened this file:
    C:\Users\Legnum\Documents\RideRunner\Skins\Carwing s_Dynamic_Lite\exectbl.ini
    Made this edit:
    / SOUNDS
    //"ONBTNPRESS","PlaySound;$SKINPATH$Sounds\button1.w av"
    //"ONBTNHOLD","PlaySound;$SKINPATH$Sounds\button2.wa v"
    And... MUSIC I HEAR MUSIC!!!!
    BUT winamp is open in front of the RR interface... I think I have fixed that by checking the 'Hide Player' check box in rr.config
    Now I have no idea why the above would be a problem but I don't particularly want the sound every button press so not an issue for me.
  4. #34
    Aug 2012
    Adelaide
    Doesn't fix the VLC issue but I'm pretty sure I need a plugin for that to work.
    I also tested the DFX skin and that works as well now! The 'Hide Player' doesn't seem to though but forget that for now.
  5. #35
    Feb 2011
    Glad I could help. The 'Hide Player' should work if you have Winamp configured for the Winamp Classic skin. The other skins do not work. Also, you will need to close the playlist editor window and any other window to completely hide the player. I have no advise for the VLC issue, but I have noticed multiple instances of Winamp when I use anything other than 'Built-in' setting.
    Bobby
  6. #36
    Aug 2012
    Adelaide
    VLC issue fixed. Found a .rar installer on page 17 of the relevant thread and bingo it's all good. So obviously the one at the start of the thread no longer works.
    Updated my progress thread, it's getting there!
    Thanks heaps for all the help from everyone, really appreciated
  7. #37
    MySQL Error
    Oct 2004
    so are u all fixed? no loock up at start?
    does debug.txt start of winamp look right?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  8. #38
    Aug 2012
    Adelaide
    Yep all fixed, thanks heaps! Not sure why the button press beep should cause those issues, but that was the culprit!
  9. #39
    MySQL Error
    Oct 2004
    yes.. how can that be...
    PLAYSOUND command uses windows API to play the wav file
    http://msdn.microsoft.com/en-us/libr...(v=vs.85).aspx
    maybe something is intercepting, and trying to play it, not even sure thats possible
    so you didnt freeze till your pressed a button right?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  10. #40
    Aug 2012
    Adelaide
    Pressing buttons was fine. Sound on button press was fine. It's only when that button happened to be the music one trying to open winamp that there was any problem. So whatever was trying to open winamp or start playing music was conflicting with the button press sound and crashing RR.
  1. Cant run in fresh windows 7 install
    By gumby_ in forum OpenMobile
    Last Post: 04-27-2012, 06:54 AM
  2. Fresh Install of OS and RR - Problems
    By kbreeden in forum Road Runner
    Last Post: 04-25-2010, 01:31 PM
  3. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 10:33 AM
  4. Crashes on start after fresh install of XP & SD
    By bigpimpn79 in forum StreetDeck Bug Reports
    Last Post: 03-21-2007, 07:08 AM
  5. Fresh install. My PhoneControl Error.. =\
    By Yellow-Snow in forum Centrafuse
    Last Post: 08-20-2006, 02:34 PM
