Page 5 of 5 FirstFirst 12345
Results 41 to 46 of 46
Like Tree3Likes
Thread: Fresh Install Crashes
  1. #41
    MySQL Error
    Oct 2004
    pressing the music on doesnt open winamp... winamp should be running long before that..
    so very weird, i never experienced the problem on any installs
    so... i say there still is a problem
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #42
    Aug 2012
    Adelaide
    Ok...
    RR operated perfectly fine. Made sounds when I pressed buttons etc.
    BUT when I press the 'Music' button it completely froze, I couldn't do anything, just locked up.
    Removed those 2 'play sound on button press' commands or whatever they were and everything worked perfectly.
    Debug file also shows that winamp is opening properly and its picking up the version as well this time.
    Those 2 commands also seemed to be affecting the DFX skin as well. It froze on started previously, but once they were removed it worked fine.
    So whatever those commands do on initialisation in RR was causing problems in bootup to a couple other things (DFX skin and winamp in my case).
    New debug now everything is working:
    debugRR.txt
  3. #43
    MySQL Error
    Oct 2004
    see its just too weird..
    now u got
    31/08/2012 4:52:37 PM: PLAYER: Initialization creating object
    31/08/2012 4:52:37 PM: Winamp AudPlayer---> Attempting start of winamp.exe
    31/08/2012 4:52:37 PM: Winamp AudPlayer---> waiting for window handle
    31/08/2012 4:52:38 PM: Winamp AudPlayer---> winamp.exe started: v20579
    31/08/2012 4:52:38 PM: PLAYER: Started
    31/08/2012 4:52:38 PM: PLAYER: Winamp Version: 5.63
    which is perfect
    to prove it, would be to put those lines back in and test...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #44
    Aug 2012
    Adelaide
    Added them back into the Reborn skin... no issues! Debug file is perfect.
    Tried the default Carwings_Dynamic_Lite skin... no issues! Debug file is perfect.
    Ok now I am hopelessly confused. I hate problems like this. Oh well Mitch... guess this hasn't made it any easier for you, but at least you don't have anything to fix until I can replicate the issue again...
  5. #45
    Aug 2012
    Adelaide
    Quote Originally Posted by Poita View Post
    Repeated the process again today and this time it didn't work. I give up. Don't need the button 'click' noise anyway.
  6. #46
    Sep 2012
    Brisbane, Australia
    Hi Poita & Others
    I have almost identical problems to what you are experiencing RE the freezing after pressing Music. I have found one thing with my hardware - my motherboard is one of the ASROCK AD2700-ITX boards with built in Atom 2.13ghz dual core CPU's, 4 gig DDR and a 32gb SSD. This motherboard is only supported to DirectX 9.0. However Win7 installs DirectX 11 (after running dxdiag). I'm not sure how much rendering RR does with DirectX but this could be an issue?? Do you have similar problems Poita?
    I am all new to the carputer scene but have a very good understanding technically how it's all compiled and operates, as that's what I do for a living as a Sys Admin.
    Sitting at idle, RR is running approx. 45-50% CPU which I thought was kinda high... thoughts?
    Occasionally things work great, but the next time the PC is started it freezes then crashes... it's becoming more and more frustrating!!
    Please let me know how you get on as I'm willing to try anything!!
    Cheers,
    Jared
  1. Cant run in fresh windows 7 install
    By gumby_ in forum OpenMobile
    Last Post: 04-27-2012, 05:54 AM
  2. Fresh Install of OS and RR - Problems
    By kbreeden in forum Road Runner
    Last Post: 04-25-2010, 12:31 PM
  3. Fresh Install on New PC, Rebooting
    By phc in forum StreetDeck
    Last Post: 12-23-2007, 09:33 AM
  4. Crashes on start after fresh install of XP & SD
    By bigpimpn79 in forum StreetDeck Bug Reports
    Last Post: 03-21-2007, 06:08 AM
  5. Fresh install. My PhoneControl Error.. =\
    By Yellow-Snow in forum Centrafuse
    Last Post: 08-20-2006, 01:34 PM
