Results 1 to 6 of 6
Thread: RR Mixer, second sound card
    Variable Bitrate sargeants's Avatar
    Oct 2008
    Ontario, Canada
    My goal is to have a volume control on the mobilephone screen, and possibly even on the mobilecall popup that will allow you to change the volume of the second sound card.
    For me the phone microphone and output route through the Andrea sound card and merge in with the main line going to the amp. All other audio comes from the main laptop sound and joins the main audio line to the amp.
    My problem is skinning the button for the Andrea - what would the button command look like? I doubt this would work, but to help illustrate what I want to do.
    vol+;andreamicrophone; rather than vol+;microphone;
    vol+;andreawave; rather than vol+;wave;
    Would this also work for a slider? I've got "wave" as a slider, and "vol;microphone", but not sure whether the microphone works.
    I've got the 2 sound cards working, and the Andrea is setup as the Windows default for voice, but using the laptop as the main audio output.
    Any help would be appreciated.
    Sarge
    03 Hyundai Elantra GT {Worklog}
    HP TC4400; 250GB SATA, WiFi, BT, 12.1" touch
    RideRunner; w/ mobilephone.net, OBDMPG, mediaart, RRMedia, DFXVoice and more...
    cmdRR tall skin creator
    86 Pontiac Fiero SE 2m6
    possible carpc install
    MySQL Error
    Oct 2004
    OS?
    my 1st thought is no, this is not going to work
    you can view debug.txt to see a list of mixer points rr can control
    if not in there, no control
    and OS makes a difference, hopefully you on a modern OS (aka not XP)
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    Oct 2008
    Ontario, Canada
    Okay.. booo
    I am running XP - but if there is a way for it to work in Win7, I will install that.
    As simple as it is, I never thought to check debug.. will do that later (when the pc is back in the car)
    MySQL Error
    Oct 2004
    i still say "no"
    see, what is "Andrea microphone", is it just a mic plugged into sound cards mic input
    or is it some audio device
    also.. there is limitation, that RR only controls the LINES on the primary mixer
    (i can never rememer all the time what rr can/cant do.... it does sooo much)
    also... remember there are 2 sides to windows mixers
    playback
    and
    record
    most people dont fully understand PC audio
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Oct 2008
    Ontario, Canada
    I don't fully understand it - at least not a deep-down level.
    For my setup I've got the laptop (Realtek) and the Andrea SUMA plugged in through USB. Ultimately giving me 2 outputs, and 2 inputs.
    The laptop input isn't a true input, only active with recording software is active. It's crappy not supporting echo cancelling, thus the use of the Andrea SUMA. I did try to get it to work with the Array microphone before I bought the SUMA, but it didn't work out.
    In Windows sound control I've got the audio playback set to Realtek; and voice recording and voice playback set to Andrea.
    I guess if I could run the Andrea output into the input of the Realtek, then really this wouldn't be needed - stupid Laptop! Then I'd be able to adjust the "linein" control in the mixer to control the voice output... really only needed for phonecalls.
    And I guess with RR only controlling the primary mixer - likely not gonna happen - like you say.
    I'll still check debug next week; but I won't hold my breath with that info.
    MySQL Error
    Oct 2004
    right, the andrea is a "sound card"
    RR only will enum the playback mixer, and give you lines avail to control
    they are listed in debug.txt
    im also not sure why u need to control the mic
    besides in most cases thats on the recording side of the mixer
    so program captures that data, and sends out the playback side, in your case a differnt mixer
    since u said speakers froms of the reltek
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. General sound/mixer settings help
    By ronjon228 in forum General MP3Car Discussion
    Last Post: 03-03-2008, 06:15 PM
  2. Ewww sound card + video card on dual pci mini-itx reiser card = audio interference
    By psyclobe in forum Software & Software Development
    Last Post: 01-23-2008, 02:59 AM
  3. Surround Sound Mixer
    By ryguy in forum Software & Software Development
    Last Post: 04-04-2004, 03:51 PM
  4. can i use any sound mixer on ME2?
    By iPal in forum ME Archive
    Last Post: 11-10-2003, 10:15 AM
  5. using a sound mixer for aux in ?
    By sheriff in forum General Hardware Discussion
    Last Post: 05-12-2001, 06:32 PM
