Results 1 to 10 of 18
Thread: current location weather using GPS?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    what the title says... anyone has any idea?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Provided you have:
    -gps2city plugin
    -zips.dat installed
    -GPS correctly configured in RR
    -No GPS application running (or use XPort)
    It should just be setting the localdatacaptureinterval=X setting to have it load the weather by current GPS city/location every X minutes. You should also be able to execute 'reloadweather' to load the weather from your current location if the above requirements are met.
    Ride Runner RR's Myspace
    Apr 2006
    Greece
    thanks, guino.. very interesting.. i will try that. The Zips.dat only includes USA coordinates, right? we need to find cities for the rest of the world...
    can u explain the format of the file eg:
    "00641","+18.250027","-066.698957","UTUADO","PR","UTUADO"
    a. the first is just a number? (EDIT: it is the US zip code..ok)
    b. longitude
    c. laatutude
    d. ????
    e. ???
    f. ???
    i just want city and country
    Apr 2006
    Greece
    ok i used the search button solved most of my problems!!
    never the less.. i have 1 question..
    i don't care about the zip codes of the country, what can i put instead of the zip codes to just ignore that..?
    EDIT: solved everything.. i created a zips.Dat for Greece
    here is a nice link for all countries (no zip codes i am afraid, only coordinates)
    http://www.world-gazetteer.com/
    Apr 2006
    Greece
    there's seems to be a unicode problem when the city is in greek, it works fine in RR and displays OK but the weather returns nothing when it refreshes
    "w_dnam"
    "w_tm"
    "w_lat"
    "w_lon"
    "w_sunr"
    "w_suns"
    etc
    return nothing.. they are not populated.. they only display when i select from a weather preset
    How does it search for weather? using CURRENTCITY? or CURRENTSTATE?
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    This is my .dat for the france !
    An another link:http://download.geonames.org/export/zip/
    Attached Files Attached Files
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The weather plugin will search using: CURRENTCITY, CURRENTSTATE ... considering how wunderground works, I'd make sure CURRENTCITY returns the city name and that CURRENTSTATE always returns your COUNTRY NAME. (So it always searchs in the format: CITY, COUNTRY -- this is how international searches should be done)
    Apr 2006
    Greece
    thank you guys for your answers.. i will try and see.. even though weather underground is not very good in looking up small to medium greek cities..
    Apr 2006
    Greece
    Yes, there is something wrong transfering the greek characters to WU.. i try the same search in WU web site and it finds the city OK.. But via RR No..
    changing the CURRENTCITY and CURRENTSTATE to English, works OK also.
    I have CURRENTSTATE=CURRENTCOUNTRY. Here is my zips.dat
    Zips.zip
    EDIT: It would be nice if we could choose how the weather plugin searches..(choose between, city, state, country)
    MySQL Error
    Oct 2004
    1st question, did u test GPS2City?
    "currentcity"
    "currentstate"
    and so fourth?
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  1. Is it possible to use a non US location for weather
    By Aboliton in forum Road Runner
    Last Post: 05-23-2009, 01:03 AM
  2. Current location?
    By PontiacGA in forum GPS
    Last Post: 05-11-2007, 09:53 PM
  3. Save current location?
    By techy101 in forum StreetDeck
    Last Post: 03-03-2007, 08:16 PM
  4. Weather by Location
    By pshadwick in forum Road Runner
    Last Post: 04-03-2006, 11:34 AM
  5. copilot2003+saving current location
    By musicthebee in forum GPS
    Last Post: 06-10-2004, 11:59 AM
