Results 1 to 10 of 12
Thread: only run a command after 2 commands?
    Sep 2012
    Germany - Munich
    Hello
    I'm using RideRunner with iGOBMW2009 Skin, but with IBuscommunicatoRR Plugin.
    Is it possible to run a command after 2 commands?
    example:
    HOLD = STARTFFWD
    IF HOLD and RELEASE = STOPFFWD
    IF PRES and RELEASE = NEXT
    regards
    Feb 2011
    if HOLD is a var that copy the original command in my opinion you could add a check-var on it (because if i understand you whant if a button pressed then do NEXT else do STOPFFWD )
    anyway this if i remember correctly can be done in a premade way (if i remember right)
    Sep 2012
    Germany - Munich
    at the moment i have these commands in exectbl.ini. the "BUT_NEXT_..." come from IBuscommunicatoRR
    "BUT_NEXT_PRES","STARTFFWD"
    "BUT_NEXT_HOLD","FFWD"
    "BUT_NEXT_REL","STOPFFWD"
    /"BUT_NEXT_REL","NEXT"
    Now if i get the Commands behind after: "BUT_NEXT_PRES" "BUT_NEXT_REL" it should do "NEXT"
    When the "FFWD" starts, it must cancel the NEXT Command, if i do "NEXT" with "BUT_NEXT_REL"
    How can i work with check-var?
    I know its very difficult to realise.
    Sep 2012
    Germany - Munich
    Now, i have added these lines to EXECTBL.ini
    "STARTFFWD","SETVAR;FASTR;NEXT"
    "FFWD","SETVAR;FASTR;STOPFFWD"
    "BUT_NEXT_REL","$FASTL$"
    But RR does not seek.
    PS. Why must every Post of me check by admin?
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    Quote Originally Posted by harryberlin View Post
    Skin:
    Code:
    Bxx,xxx,xxx,xxx,xxx,"STOPFFWD",@SETVAR;GOFFWD;1||FASTFFWD@
    ExecTBL:
    Code:
    "FASTFFWD","IFVAR;GOFFWD=1;FFWD||FASTFFWD<<"
    "STOPFFWD","IFVAR;GOFFWD=1;SETVAR;GOFFWD;0<<NEXT"
    this is taken from skincommads. code not tested but will give ou some ideas.
    another way is to use a timer. using IFVAR or BYVAR commands.
    i havent used RR code in some time but i think is a starting point for you.
    Sep 2012
    Germany - Munich
    THX. I try it at home on wednessday.
    there is a small misstake in the commandline "BUT_NEXT_REL","$FASTL$". "BUT_NEXT_REL","$FASTR$"
    For Example, i have one button, wich send following codes:
    by short push: PRESS -> RELEASE
    on hold: PRESS -> HOLD -> HOLD -> HOLD -> ... (every Hold after one second)-> RELEASE
    Because the Hold starts after one second, i'd like to start FFWD jet on PRESS.
    If i get PRESS and RELEASE fast enough behind after -> do NEXT.
    my commands in the last post are working, but RR irgnore the STARTFFWD and FFWD. is this effect normal? only my commands run.
    Sep 2012
    Germany - Munich
    Hello
    It's not working
    because FASTFFWD loops and CPU-Usage over 100% -> RR freeze.
    Sep 2012
    Germany - Munich
    this workaround is now in use. i don't know an other method.
    /SEEKING
    "ONSKINSTART","SETVAR;GOFFWD;0||SETVAR;GOFRWD; 0"
    "BUT_NEXT_PRES",""
    "BUT_NEXT_HOLD","IFVAR;GOFFWD=1;FFWD<<SETVAR;GOFFW D;1||STARTFFWD"
    "BUT_NEXT_REL","IFVAR;GOFFWD=1;SETVAR;GOFFWD;0||ST OPFFWD<<NEXT"
    "BUT_PREV_PRES",""
    "BUT_PREV_HOLD","IFVAR;GOFRWD=1;FRWD<<SETVAR;GOFRW D;1||STARTFRWD"
    "BUT_PREV_REL","IFVAR;GOFRWD=1;SETVAR;GOFRWD;0||ST OPFRWD<<PREV2"
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Ok, I see what you are doing now.
    I would have thought the IBuscommunicatoRR Plugin would handle that internally, I know at least one of the other iBus ones does
    Sep 2012
    Germany - Munich
    OK, it's very difficult. i know there is an option, that ibuscomm wait of a telegram before resume his work.
    the problem is, RR should set an var by running ffwd. if i do "FFWD","SETVAR;GOFFWD;1", RR cancel his own FFWD-command -> no sseking.
  1. Replies: 3
    Last Post: 11-07-2011, 05:24 AM
  2. LIST Command: Riderunner or skin command?
    By blazinlow in forum Road Runner
    Last Post: 10-23-2011, 02:28 PM
  3. Replies: 15
    Last Post: 10-21-2009, 09:09 PM
  4. Replies: 4
    Last Post: 12-14-2008, 07:55 PM
  5. 2 commands at once....
    By TheUni in forum Road Runner
    Last Post: 09-07-2005, 11:37 AM
