Results 1 to 10 of 18
Thread: Need help with C#
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Need help with C#
    I have a little issue when i use 2 lines between the if an the else .
    Code:
                        for (uint g = 0; g < CTInfo.GetCoreCount; g++)
                            index = g + (i * CTInfo.GetCoreCount);
                            if (CTInfo.IsDistanceToTjMax)
                                SDK.SetUserVar("RRCORETEMP_CORE_TEMP_" + index, Convert.ToString(CTInfo.GetTemp[index]));
                                SDK.SetUserVar("RRCORETEMP_CORE_LOAD_" + index, Convert.ToString(CTInfo.GetCoreLoad[index]));
                            else
                                SDK.SetUserVar("RRCORETEMP_CORE_INFO_" + index, "Core " + index + ": " + CTInfo.GetTemp[index] + "" + TempType + " , " + CTInfo.GetCoreLoad[index] + "% Load");
    Thanks for your help !!!
    Maximum Bitrate Borte's Avatar
    Jan 2006
    Norway
    You need to use { and } to "group" your code belonging to the if statement. If you skip these brackets then only the first line after the if and the else belongs to the statement.
    Change your code to this and it should work:
    Code:
                            else
    Failure is not an option...
    __________________________________________________ ______________________________
    The only full multizone / multiscreen cross platform open source Front End -> OpenMobile
    MySQL Error
    Oct 2004
    any why is that a USERVAR!!!!
    over use of uservars!!!
    if yout plugin uses it, and only your plugin, there is no need to make it a uservar
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    May 2008
    Bordeaux, France
    Quote Originally Posted by mitchjs View Post
    And what i do to use !
    May 2008
    Bordeaux, France
    Thanks Borte
    May 2008
    Bordeaux, France
    I want a label that use a number but i want 0 digit , so i try to use the Math.Round function but without success
    Code:
                    case "rrcoretemp_maxtemp_alarm":
                        s = Convert.ToString(Math.Round((((Convert.ToInt32(CoreTempMax) - 20 - 9) * 10) * 65535) / 20));
                        break;
    An idea ?
    Jan 2006
    Norway
    The Math.Round method has multiple calling options, some of these allowes you to specify how many decimals you want.
    Change your code to this and it it should work:
    Code:
                        s = Convert.ToString(Math.Round((((Convert.ToInt32(CoreTempMax) - 20 - 9) * 10) * 65535) / 20, 0));
                        break;
    MySQL Error
    Oct 2004
    Quote Originally Posted by pierrotm777 View Post
    variables
    just not USERVARS... unless there is some reason to, ie the USER needs direct acess to it
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    pierrot, if those variables are just to display the info in a skin, then use the return label to display them. keep them as internal variables till then
    May 2008
    Bordeaux, France
    Quote Originally Posted by Enforcer View Post
    Ok, i understand better !
    I try to modify that !
    I want to use a new thread for the timers ! I know how to do in VB.NET but not in C# !
