Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 41
Thread: RR 10-01-2012 Release
  1. #11
    Feb 2011
    For the next relase could be added, on the code for embeding application, the window trasparency? (like on visualization) would be usefoul for example use a normal button again instead of the region (that isn't precise on click), just make the windows 99% (with 1% of trasparence).
    And could be added also support for the linein under the vector of activesources?
    Thanks so much
  2. #12
    Jun 2007
    Mitch please see debug log file from RR 12/01/2011
    I like old this version because...I test by load many Flac songs amount tree hundred of songs in playlist..( hard test )
    and when I run RR again it play resume from last song..so good,fast very well and corrected..
    But newer from this version can't do that...newer from this version not play resume or play last position of song
    I want to you test again
    debug.txt
    RideRunner Setup01122011.zip
  3. #13
    MySQL Error
    Oct 2004
    generally i dont go backwards... only forwards...
    far i as i know no changes to foobar code in months, but your going back almost a year
    so i would compare a debug.txt of current version to that version...
    it takes foo, very long to process the list of songs, so it is possible, that it hasnt processed the list
    when rr asks it to play
    just checked the last time foobar player was touched is 6/11/2011
    so... its not the player... there has been changes in rr... specially for custom sources, so start up has been changed
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  4. #14
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Your debug seems to show the player resuming the song within 4 seconds of starting RR. Like Mitch said, we haven't changed anything in the player plugin for over 1 year. I don't believe we have changed enough in RR lately to cause any problems - was this working on RR in the September version?
    Ride Runner RR's Myspace
  5. #15
    Jun 2007
    I keep the Old West in length compared each month. To see the difference. I have no technical knowledge. But I noticed that Version is now waiting for it to be successful rrpl continuous music playback. But Version new length. It does not wait until the rrpl success. I just want to the RR load rrpl complete before onsongstart to resume Thanks for the answer.
  6. #16
    Jun 2007
    my test RR 10 01 2012
  7. #17
    MySQL Error
    Oct 2004
    "ONSONGSTART"? thats an event...
    if i use foobar on current version it works, it always resumes correctly, but i only have a handfull of files
    foobar, maybe talking long to load the list, and asked to play a song that doesnt exist (yet)
    you should be able to prove that
    the loading of RRPL into foobar is done asynchronously, else it would hold up RR for a possible long time
    but thats nothing new, its how the foobar control plugin works, and always has worked
    and i also dont have any flac files, only mp3....
    do some logical testing, put 10 songs into a PLAYLIST, play song #8
    exit rr
    restart RR
    does song #8 resume?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #18
    MySQL Error
    Oct 2004
    ok, i got it to happen myself, RR is asking the player to play, and the player isnt ready...
    i had to put a ton of songs in PL
    seems, if you play song, exit rr
    restat rr
    and then repeat that
    it works
    since FOOBAR is caching the tags!
    foobar is taking too long to process the list, and rr asks it to play
    all you had to do is look at the DEBUG TEXT
    Code:
    23:42:44.391: INFO: AudPlayerStart() - music player: PLPosition=35  TrackPosition=107000
    23:42:44.391: Foobar2000 AudPlayer---> Set to new track: 36
    23:42:44.391: Foobar2000 AudPlayer---> To Fb2k: vol -100
    23:42:44.398: INFO: AudPlayerStart() - player volume should be 0: 255
    23:42:44.398: Foobar2000 AudPlayer---> To Fb2k: play 36
    23:42:44.398: Foobar2000 AudPlayer---> From Fb2k: VOLUME|-100.00
    23:42:44.398: Foobar2000 AudPlayer---> From Fb2k: ERROR|Playlist track index out of range
    its plain as day
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    Jun 2007
    old version ( 12 01 2011 )
  10. #20
    MySQL Error
    Oct 2004
    im going to guess we improved the start up of RR, and that shortend the time of foobar processing
    the problem is foo, processing each file... takes too long..
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. RR 09-01-2012 Release
    By mitchjs in forum Road Runner
    Last Post: 09-11-2012, 01:44 PM
  2. RR 08-01-2012 Release
    Last Post: 08-24-2012, 06:02 PM
  3. RR 05-01-2012 Release
    Last Post: 05-21-2012, 05:53 PM
  4. RR 04-01-2012 Release
    Last Post: 04-21-2012, 01:47 PM
  5. RR 02-05-2012 Release
    Last Post: 02-25-2012, 09:37 AM
