all fixed
the bug is not in RR, its in the Foobar Control server .dll
it wasnt playing from right playlist...
i also increased the time the RR Player will wait for a foobar process of files from 5sec to 10sec
m
possible to load RRPL complete then resume ?? However If alittle songs or more many songs ( flac mp3 ...) RR 12 01 2011 it seem to wait RRPL complete..( I dont know about its) new RR if its have alittle songs in PL ..It's no prob. Thanks you ...for your interest ( this my prob )
all fixed
m
-Thanks
Mitch
www.rush2112.net
Sun, Come shine my way
Wind, Carry me home
The piece of me that died
Will return To live again
Foobar Control server .dll 1.0.3 notwork
I think It's about your exe sourcecode..
whats wrong with 1.0.3?
works here
exe sourcecode? what are you talking about???
blanket statements like above, wont get you anywhere...
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
just a fyi, if you dont see this in order
20:14:15.008: Foobar2000 AudPlayer---> To Fb2k: addpl C:\Users\mitchjs\Documents\RideRunner\Cache\rrpl.m 3u8
20:14:16.148: Foobar2000 AudPlayer---> From Fb2k: PL_LOAD_COMPLETE
20:14:16.156: PLAYER: Restored rrpl.m3u8
foobar took TOO long to load the PL, im already waiting up to 10 sec!
i would then take it up with the foobar dev team to add an option not to parse the files for tags!
disable all tag support!
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
No.Just notwait
I not found about several lines in debug log ( old version ) on new EXE
10/25/2012 7:08:05 AM: Foobar2000 AudPlayer---> To Fb2k: rrreset
10/25/2012 7:08:05 AM: Foobar2000 AudPlayer---> From Fb2k: VOLUME|0.00
10/25/2012 7:08:05 AM: Foobar2000 AudPlayer---> From Fb2k: RRRESET|Foobar2000 is read
10/25/2012 7:08:05 AM: Foobar2000 AudPlayer---> To Fb2k: addpl C:\Program Files\RideRunner\rrpl.m3u8
10/25/2012 7:08:06 AM: Foobar2000 AudPlayer---> From Fb2k: PL_LOAD_COMPLETE
10/25/2012 7:08:06 AM: PLAYER: Restored rrpl.m3u8
10/25/2012 7:08:06 AM: Foobar2000 AudPlayer---> To Fb2k: order default
10/25/2012 7:08:06 AM: Foobar2000 AudPlayer---> From Fb2k: 333|Default
10/25/2012 7:08:08 AM: CheckResume: ResumeMusic=2 WasRadio=0
10/25/2012 7:08:08 AM: AudPlayerStart: music player: PLPosition=28 TrackPosition=191000
10/25/2012 7:08:08 AM: Foobar2000 AudPlayer---> Set to new track: 29
10/25/2012 7:08:08 AM: Foobar2000 AudPlayer---> To Fb2k: vol -100
10/25/2012 7:08:08 AM: Foobar2000 AudPlayer---> From Fb2k: VOLUME|-100.00
10/25/2012 7:08:08 AM: AudPlayerStart: player volume be 0: 0
10/25/2012 7:08:08 AM: Foobar2000 AudPlayer---> To Fb2k: play 29
10/25/2012 7:08:08 AM: Foobar2000 AudPlayer---> Play, position
I remembered...I told u about this issue last year.. and u fix it for me...
But the newer EXE ..Don't have this lines
The corrected sequence should be the new ...
Wait rrpl complete before executing other commands.
I disagree about break time.
If the music is alittle. It runs normal sensitivity.
If the music are more than, it will have to wait automatic before rrpl complete to load
I test more several times ....old EXE(12 01 2011) it's good to play resume..
I think,It's not about the foobar..
yes i found a bug in the controller code... its fixed in 1.0.3 (yesterday)
and your debug, shows that the PL is loaded, i cant tell what happed next, cause you cut off a bit of your log
i am waiting for the playlist to load, up to 10 seconds
no idea what this means "Wait rrpl complete before executing other commands." (the word commands is loose term)
there is NOTHING i fixed for you last year, that isnt in current code...
i have 1124 items in MY RRPL, and it resumes exactly where it left off
every time
if u attach a debug.txt vs posting context limited snips, i might be able to see more
maybe your doing something out of the box
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
btw, that you tried 1/1/2012 of RR?
how about 2/1/2012 of RR?
etc...
if you didnt try... i can give you those versions
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
Also test with carwings please
-Thanks
Mitch
www.rush2112.net
Wind, Carry me home
The OSK with GMPC on DFX5 is not closing, it was working fine before I upgraded to this version.
