Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
Thread: RR 10-01-2012 Release
  1. #31
    MySQL Error
    Oct 2004
    prob not related... dont even know exactly what a OSK with GMPC is
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  2. #32
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Quote Originally Posted by mitchjs View Post
    On Screen Keyboard with Garmin Mobile PC
    Mine disappeared as well on this release of RR. I am in the middle of re installing everything with a purchased version of W8 then I will see if the problem still persists.
  3. #33
    MySQL Error
    Oct 2004
    is this osk generated by garmin mobile pc?
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  4. #34
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    I misread zyr55's issue, mine is different. His issue is the OSK won't go away, mine was it was not available.
    I thought it was part of the skin files but maybe not. That might make sense for my problem now that I think about it because I didn't get Elite installed this time so I just ran the default Carwings. Maybe it's skinned into Elite but not Carwings. When I re install Elite this time, it will be there?? I will let you know, Should be late today or first thing in the morning.
  5. #35
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    The OSK is a skin file in Elite, it's spelled wrong but it's "gamrin-osk.png
  6. #36
    MySQL Error
    Oct 2004
    ok... well maybe its one of those overlay things...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  7. #37
    MySQL Error
    Oct 2004
    clearly if rr closes, any SCREEN it generates, will be gone...
    if this OSK is some overly screen, seperate exe, then something has to tell it to close
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  8. #38
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    garmin osk , use's elcomenu , or a version of it ,,
    check your cmd lines in the exectbl.ini ,, there should be 3 - 5 lines on garmin osk ,, check paths etc,,
    now if done correctly the exe for elcomenu should be in the the skin folder plugins , but doubt it
    so you need to find out where the exe is , it will be in the skin folder somewhere , or in your rr plugins folder ,,
    this is a skin issue not a rr issue , well form what i can see anyway
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
  9. #39
    Dec 2007
    Sydney Australia
    Just uninstalled Winamp and RR, installed Foobar and reinstaled RR.
    Now when I start RRconfig I get the following .net error
    VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE-CF & SATA-CF adapters, 8GB (Sys) & 32GB (MP3s) CF, ELMscan5USB, Slot-load DVD, Craig Brass DAB+/FM USB module, Odyssey Navigator
    Build 90% Apps 50% Install 10%
  10. #40
    Low Bitrate rtgree01's Avatar
    Aug 2007
    STL
    @RevheadKev - What version of RR are you installing? Your screenshot shows RRConfig v 1.0.0.0. Mine shows v1.0.0.13 (granted I'm using 11/01/2012 build) But I'd think the version of RRConfig in the 10/01/2012 would be something more than v1.0.0.0. That being said, could you please attach the info that is presented when you click the details button? That should give some more info to work on....
    Thanks!
  1. RR 09-01-2012 Release
    By mitchjs in forum Road Runner
    Last Post: 09-11-2012, 01:44 PM
  2. RR 08-01-2012 Release
    Last Post: 08-24-2012, 06:02 PM
  3. RR 05-01-2012 Release
    Last Post: 05-21-2012, 05:53 PM
  4. RR 04-01-2012 Release
    Last Post: 04-21-2012, 01:47 PM
  5. RR 02-05-2012 Release
    Last Post: 02-25-2012, 09:37 AM
